comcast remote codes for toshiba tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-08-2008, 11:41 AM - Thread Starter
razorjane's Avatar
i have a toshiba theaterwide sd tv and i tried the codes comcast recommends; 0154, 0156, and 0060, with no luck. the remote does not flash twice when i enter a 4 digit code like it is supposed to. if you have any help i'd really appreciate it!
razorjane is offline
post #2 of 8 Old 05-08-2008, 11:48 AM
Kupakai's Avatar
Does it flash one long flash, or not at all. If it doesn't flash at all, you may have a version of the remote that takes 5 digit setup codes. Try the codes again with "1" in front of them, i.e. 10154, 10156, 10060. If one of the codes work, but you are missing some functions that you need, there is a way to those. Post which one at least gives you some functions.
If it gives you one long flash, it means either that code is not built in, or perhaps you have the device for TV button set to a different one. There's a way to change that back, if that's the case.
Kupakai is offline
post #3 of 8 Old 05-08-2008, 11:51 AM - Thread Starter
razorjane's Avatar
when i do the four digit codes, it just flashes a regular flash like when you push any old button. when i try the five digit codes, it does one long flash. it is a new remote we got today to replace a broken one, so it has never been set to anything AFAIK.
post #4 of 8 Old 05-08-2008, 12:38 PM - Thread Starter
razorjane's Avatar
the three digit code, 991, that is supposed to help you search for the code, does make the light flash twice if that helps...
post #5 of 8 Old 05-08-2008, 12:42 PM - Thread Starter
razorjane's Avatar
oh i figured it out, thanks for your help! my remote does take 5 digit codes, but the first digit for tv codes is 1. thanks again!
post #6 of 8 Old 08-08-2010, 08:40 PM
anh1272's Avatar
the suggestion from kubakai worked for me. I had the same problem as razorjane. Interesting that they don't state that in the manual.
anh1272 is offline
post #7 of 8 Old 04-09-2013, 03:20 PM
magicman123's Avatar
hey 10156 worked for me but not all the buttons work (channel - & + and the "onfo" button) if you've got anything on that i would be gr8full! biggrin.gif
magicman123 is offline
post #8 of 8 Old 04-10-2013, 09:45 AM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 986
What model TV? HERE are several discrete codes for many recent Toshiba LCD models.
mdavej is offline
Reply Remote Control Area
