comcast remote code??? panasonic th-42pz80u - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-29-2008, 08:03 PM - Thread Starter
isimpson's Avatar
Hello all- Looking to program my comcast universal remote control for control of my panasonic th-42pz80u. the supplied codes (0250, 0051) aren't working. Anyone had any luck with any other codes? Tried searching to no avail.
Thanks in advance.
isimpson is offline
post #2 of 3 Old 12-09-2008, 12:35 PM
faithful227's Avatar
I'm having this same problem with my parents new 42PX80U. So frustrating. Did you ever find a code that worked?
****Update
As soon as i posted this I found a link to an updated code list. It worked.
http://www.comcast.com/corporate/cus...t/remotes.html
I downloaded the manual for their remote and it worked like a champ. Even changes the Input on the TV.
faithful227 is offline
post #3 of 3 Old 02-24-2013, 02:38 PM
StephanA's Avatar
I'm not sure if someone will find this information helpful but I really hope someone does as I spent a lot of time myself searching for the right codes to program my comcast universal remote for panasonic.
Finally I come across these codes 10250, 10051, 10055, 10650, 11291, 11941 and actually the first one worked for me.
The data I found is from TV Remote Codes comcast platinum tv 5
StephanA is offline
Reply Remote Control Area
