Harmony 890 RF Directionality - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-14-2008, 07:02 PM - Thread Starter
jagphys90's Avatar
I'd like to purchase the Harmony 890 remote for its RF capabilities for use in my home theater. My question has to do with the directionality of the RF signal. All of my equipment is located behind the chairs in a simple cabinet. Is the RF signal sent in all directions or is it directional? In other words will I have to point the remote at the cabinet even when using RF?
Thanks in advance,
Jeff
jagphys90 is offline
post #2 of 6 Old 08-14-2008, 11:31 PM
ashkooly's Avatar
fyi, if you didn't know, you have to have the logitech ir wireless extender to be able to utilize the rf function on the remote. the remote does not control rf devices. so the direction you're pointing the remote depends on where you position the wireless extender.
ashkooly is offline
post #3 of 6 Old 08-15-2008, 12:49 AM
Florida's Avatar
Thanks in advance,
Jeff
RF isn't directional - you can point the remote anywhere.
Florida is offline
post #4 of 6 Old 08-15-2008, 06:05 AM
bryansj's Avatar
Quoted: 1129 Post(s)
Liked: 559
True. It is just like using a cordless phone. The phone = remote and the base = extender.
However, you can use the 890 as a normal IR remote. In that case you would need to point the remote towards the device.
bryansj is offline
post #5 of 6 Old 08-15-2008, 10:17 AM
SaltiDawg's Avatar
Originally Posted by ashkooly View Post
...so the direction you're pointing the remote depends on where you position the wireless extender.
Actually, you do not need to "point" the remote at all if you are only using RF. The IR is directional, the RF is omnidirectional.
SaltiDawg is offline
post #6 of 6 Old 08-15-2008, 06:43 PM - Thread Starter
jagphys90's Avatar
Thanks for the confirmation, everyone. I was just curious as the Logitech website shows the "RF waves" being emitted in a forward direction. Obviously the purpose of RF is to send a broad signal I just wanted to make sure.
Thanks again.
Reply Remote Control Area
