Harmony 550 Official Thread. For all info and FAQs - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 361 Old 01-14-2009, 01:14 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Originally Posted by john1528golf View Post
Has anyone else had their 550 lock-up on them? My 1st 550 lasted 2 days and quit working, the LCD screen said "welcome to your remote" and the arrow to turn the page in bottom right corner was on but remote would not respond to any command at all, the glow button wouldnt even work. Tech support could not fix the problem so I returned it for a new one which worked great for about 2 months and guess what, it says "welcome to your remote" on the screen and will do absolutely nothing. Anyone seen this before?
My 3 week old 550 did this just last night. Long story short, there was a button stuck, cocked in such a way that it wasn't releasing. Once I realized it I easily got it unstuck which got the remote working again.
I almost missed this at first (played around, changed the batteries and what not) and was about to call Harmony when I saw the stuck button so I'd suggest taking a close look at all the buttons before you give up on it. Good luck.
Vin
Vin is offline
post #182 of 361 Old 01-14-2009, 06:48 PM
john1528golf's Avatar
^Thanks for the info Vin. Thats the same thing Tech Support suggested so I checked every button but could not find one that was stuck. I guess I'll have to double check it tonight.
john1528golf is offline
post #183 of 361 Old 01-16-2009, 12:12 AM
I found it, the "B" button in the bottom right corner was stuck down, I can put my 4 remotes back in the drawer
post #184 of 361 Old 01-16-2009, 05:18 AM
miker104's Avatar
Quoted: 17 Post(s)
because more people posted in the 880 forum..?? :0
miker104 is offline
post #185 of 361 Old 01-16-2009, 09:21 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Glad to hear it John.
Vin
Vin is offline
post #186 of 361 Old 01-20-2009, 05:37 PM
SamDaMan's Avatar
Just got my HR22-100 DirecTV DVR/Receiver and tried to reprogram my Harmony 550 but it only sees it as a PVR. So when I try to add the Watch TV activity it doesn't think it can change channels so it asks for another device to be added. I just added a different receiver device to it to allow for the activity to be created and switch to the HR22's controls via the devices button but that's a pain. I have sent an email to Logitech but haven't received any reply yet.
I'm sure others have had this issue with a receiver, so what did you guys do? Any help would be great.
SamDaMan is offline
post #187 of 361 Old 01-21-2009, 02:08 AM
jbdawson's Avatar
Quoted: 37 Post(s)
Does anyonbody know how we can shut off the light up of the screen whenever a button is pushed? And have it set to manual, where it only works when we push activities or glow ?
I find myself having to lower and higher the volume a lot, or change through channels, this cant be good for my batteries life
jbdawson is offline
post #188 of 361 Old 01-21-2009, 07:34 AM
Crunkile's Avatar
for your activity, in the set up, try customize buttons. You can go in and it will give you a drop down list for each button, select your DVR and then select the proper DVR control that you want for each button.
I would also say to try to set it up again, something must have gotten crossed in your set up, especially if you can switch on the remote to DVR and it works.
Crunkile is offline
post #189 of 361 Old 01-21-2009, 10:09 AM
SamDaMan's Avatar
I guess I was just trying to get around the manual setup deal.
I have tried the setup multiple times. Deleting the previous devices and putting them back in, restarting the software, restarting the computer, etc. Maybe the Mac OS version of this thing is buggy, not sure.
SamDaMan is offline
post #190 of 361 Old 01-21-2009, 12:57 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I have the same set-up (Harmony 550 controlling an HR22-100) and have no issues...all functions work. This is all I did to set it up:
Starting with the Device drop down menu, choose Video Recorder > PVR
Then from the Select Manufacturer drop down > DirecTV
Then enter HR22 as the Model.
And then of course, set up the Activity...done.
Vin
Vin is offline
post #191 of 361 Old 01-21-2009, 01:28 PM
SamDaMan's Avatar
Thanks, I will try it again. I tried that with other renditions as well, like HR22-100, HR-22, H22, etc. I guess something went screwy and I just have to try again.
SamDaMan is offline
post #192 of 361 Old 01-21-2009, 02:22 PM
Beerstalker's Avatar
Liked: 24
If I remember right when you first start to set up a watch TV activity the next question is what kind of watch TV activity and there should be one for Watch PVR. Or maybe there was a seperate activity for Watch PVR, I don't remember for sure. Are you selecting that one? I've only worked on the 880/890 and One so maybe that is just for those (it has a different icon with a pause button icon in front of the TV screen).
Beerstalker is offline
post #193 of 361 Old 01-22-2009, 05:39 AM
SamDaMan's Avatar
I tried it again last night and it does work. I guess after trying so many different ways with the Satellite category and then the PVR category, I skipped one or two. All is well now though, thanks for the advice.
SamDaMan is offline
post #194 of 361 Old 01-22-2009, 11:37 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Glad to hear you got it going.
Vin
Vin is offline
post #195 of 361 Old 01-27-2009, 08:29 AM
HotInEER's Avatar
Just received mine last night from Tiger Direct...Must say..so far...It's the best $50 i've spent. I'll wait till i'm off on Saturday and Sunday to really get a feel for it..Just in time for the Super Bowl..GO STEELERS!
HotInEER is offline
post #196 of 361 Old 01-28-2009, 11:19 PM
tripleM's Avatar
Does the 550 use the same software as the H1?
I ask because I have an H1 & I plan on getting a 550 for the gf & wanted to see if anything could be used from the H1 setup to load onto the 550.
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #197 of 361 Old 01-28-2009, 11:49 PM
Liked: 24
It uses the same software, but you can't really copy any settings over. About the closest thing you could do would be to login to your account and then plug in her remote. Hit the update button and it should come up with a screen that says that it is a different remote and it gives you the option to either change your setup for the new remote, or copy your settings to a new account for the new remote. Use the copy option and set up a new account for her remote.
Be aware if this screen doesn't come up, or if you accidently pick the wrong selection it will screw up a lot of your settings (custom button mappings) and you will have to redo-them.
You aren't going to try to use these both in the same room are you? That usually doesn't work out well because they can't keep track of the state of all of the devices correctly.
post #198 of 361 Old 01-29-2009, 12:03 AM
snow99dohc's Avatar
Just stopping in to say I love my 550 make things alot easier.
snow99dohc is offline
post #199 of 361 Old 01-29-2009, 06:42 AM
tripleM's Avatar
Appreciate the feedback! The remotes will be @ 2 different locale.
tripleM is offline
post #200 of 361 Old 01-30-2009, 01:13 PM
dludingt's Avatar
Is there a Brick and Mortar store that is still selling this remote? BB no longer carries it, and I can't seem to find it anywhere. Any help?
dludingt is offline
post #201 of 361 Old 01-31-2009, 07:21 AM
tripleM's Avatar
I am checking a CC today & will let you know if they have any on close out/GOOB.
tripleM is offline
post #202 of 361 Old 01-31-2009, 03:01 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
You can get it here.
Vin
Vin is offline
post #203 of 361 Old 02-02-2009, 08:08 AM
tripleM's Avatar
CC doesn't carry it.
btw, there are reasons CC is going out of business.
Even in liquidation, their prices sucks & their customers leave the store empty handed.
tripleM is offline
post #204 of 361 Old 02-07-2009, 08:51 PM
lemywinks2's Avatar
just got my 550 a little while ago and i'm lovein it. only problem i can't figure out with it is when i change from play game to watch tv, it dont go to the right channel. its supposed to be on channel 3 but changes it to 13. if everything is off it goes to the right channel. it only does this when i change from something to watch tv. i went through the settings many times and it's set to change to channel 3. anybody know what i'm doing wrong here?
lemywinks2 is offline
post #205 of 361 Old 02-08-2009, 06:05 AM
schmiggyjk's Avatar
Anyone know how to program a timer with like a "all off" command? I realize I could set a cable box timer, but that would still leave the TV on. I could program them both but then the receiver is still on.
Is there an option in the harmony to do a setup wide off after a certain amount of time like a sleep option?
schmiggyjk is offline
post #206 of 361 Old 02-10-2009, 12:24 PM
hookie37's Avatar
can anyone tell me how you post a new thred
hookie37 is offline
post #207 of 361 Old 02-10-2009, 07:18 PM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
Go to the forum's main page. There is a New Thread button to the left of those popup list of all forums. That should do it.
Arvy
Arvy is offline
post #208 of 361 Old 02-11-2009, 04:45 AM
schmiggyjk's Avatar
Any help with this?
post #209 of 361 Old 02-11-2009, 07:29 AM
pmilin's Avatar
This is not possible. I wish it were because I want to do the same thing.
pmilin is offline
post #210 of 361 Old 02-11-2009, 07:31 AM
pmilin's Avatar
I have seen them at Home Depot.
pmilin is offline
Reply Remote Control Area
