880 Hard Button Pushing Problem - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 50 Old 10-08-2008, 03:54 PM
Jon_c's Avatar
Add me to the list of 880s that are failing. For me it's the 'Off' button, which really just sucks. I've had mine approx 2years.
I'll be looking to open up the remote and try to figure out how to possibly fix it myself.
Here's the thread on Logitech's site for this issue.
Jon_c is offline
post #32 of 50 Old 11-11-2008, 02:45 PM
Gujustud's Avatar
+1 for the Volume+ button failing on my 880 as well. Warranty gone, no luck with logitech.
Gujustud is offline
post #33 of 50 Old 11-15-2008, 09:27 AM
whcc's Avatar
Same here. Warranty expired. Had the 880 for almost 2 years. Now the Volume+ button doesn't work and the right directional button doesn't respond sometimes. Disappointed in the 1 year warranty considering Logitech provides 5 years for their keyboard and mouse products. Hope they can recognize that this is a common issue and rectify it somehow.
whcc is offline
post #34 of 50 Old 11-15-2008, 10:43 AM
jayoldschool's Avatar
Quoted: 12 Post(s)
Volume + for me. Started a few months ago. Out of warranty, of course. I tried calling anyways. I spent a lot of time on the phone with a tech, then they finally put in for an RMA. I got an email saying it was out of warranty, and I could send it in for an estimate. I called back, and told them that offer was pretty disappointing, since there is plenty of info on their own forum about the exact problem I was having. Eventually, they agreed to replace it for only the cost of shipping.
I'll take apart the broken one and figure out how to fix it, and post up my results...
jayoldschool is offline
post #35 of 50 Old 12-03-2008, 07:05 PM
Guildenstern42's Avatar
I just got a replacement Harmony under warranty (old one had problems charging unless I placed pieces of aluminum foil on the charger connectors), and from day 1 the volume up button didn't work, the mute button was very iffy, and the device button was also iffy. I'm going to see if Logitech will send me a second replacement, and in the meantime try take the remote apart and see what I can do with it.
I was planning to buy my parents one of these for Christmas, but after two remotes with problems I'm not sure.
Guildenstern42 is offline
post #36 of 50 Old 12-20-2008, 07:33 PM
RexRuther's Avatar
Like many of you above, I had a bad VOL + button - it was not responsive. I dealt this with for 6+ months (used another remote to control volume....), was close to throwing it out, then I read this thread and another on the Logitech forums
Here is how I repaired my remote (took less than 5 min for whole process)
1) Removed battery cover (gently remove with hands - apply pressure on the indent to release the tab)
2) removed the two screws (one at top of remote and the other beneath the battery)
3) Then there are FOUR locking tabs at midway through the top curve and the bottom on either side of the remote - near the "1" and the "3" and on either side of the screen, respectively. Getting these tabs to unlock is a pain, and it's accomplished by pushing rather hard with an object against the LOWER part of the remote case. I recommend doing it with a very small screwdriver lodged into the groove.
4) Once opened, I simply took a pencil eraser, cut off a very small, thin piece (just enough to cover the metal contact for the vol + button) which becomes a bridge between the rubber knub from the top of the remote and the metal contact.
Now, the button works great!
RexRuther is offline
post #37 of 50 Old 12-22-2008, 12:49 AM
gemad9's Avatar
Don't quite understand "4)". What's a "knub"? Could you elaborate a bit on what you did in this step and does it affect other buttons as well? Mine has several buttons that are not responding properly without multiple pushes and lots of pressure.
Thanks...
gemad9
gemad9 is offline
post #38 of 50 Old 01-03-2009, 11:14 AM
ktabel01's Avatar
Same exact problem with 880 here. Had it for about 18 months and the volume + button went first. It actually decreases colume now. Prev and mute buttons are slowly fading. Agree their software is nice but their hardware is clunky.
ktabel01 is offline
post #39 of 50 Old 07-23-2009, 11:45 AM
lexus350's Avatar
Ditto... Volume up requires a hard press and sometimes causes the volume to go down.
lexus350 is offline
post #40 of 50 Old 07-23-2009, 12:19 PM
dharel's Avatar
Liked: 33
When you press a button, there is a small piece of rubber or plastic that makes contact with the metal contact on the circuit board. For some reason, these seem to stop working. When you open the remote, you need to place something on top of the metal contact for the buttons that are not working. This will build up the area and when you press, the "knub" will make better contact.
dharel is offline
post #41 of 50 Old 07-23-2009, 06:43 PM
tokerblue's Avatar
Quoted: 94 Post(s)
Liked: 66
I have two 880's. One has a failing Guide button, which I use a lot and a failing volume up button. The other 880 has a failing Channel Up button. Love the software and remote. Not a huge fan of the build quality.
I wonder if the One is more durable. Although I will miss 8 LCD commands.
tokerblue is offline
post #42 of 50 Old 07-23-2009, 06:54 PM
dharel's Avatar
Liked: 33
dharel is offline
post #43 of 50 Old 07-29-2009, 03:25 PM
Yakatak's Avatar
A 890 reviewer on the Harmony website said he repaired his 890 volume-up by opening the unit (as described a couple posts above) and placing a small drop of hot glue to the base of the button to increase pressure to the switch pad. I'm going to try this with my 880 tonight.
Yakatak is offline
post #44 of 50 Old 07-29-2009, 06:11 PM
tokerblue's Avatar
Quoted: 94 Post(s)
Liked: 66
- I'll probably have to try this. I tried the erase trick that was posted elsewhere and I didn't have any success with it. Now I just have to find someone with a glue gun.
post #45 of 50 Old 12-24-2009, 10:58 PM
sonydude1966's Avatar
Quoted: 14 Post(s)
The eraser trick works well. You just have to get a really small thin piece. Hot glue sounds like an accident waiting to happen.
sonydude1966 is offline
post #46 of 50 Old 12-25-2009, 02:58 PM
Treeroot's Avatar
Stupid question coming. I assume you are gluing the eraser to something? If so what type of glue did you use? I'm having the same problem with my 880 and getting no response from Logitech. Was considering a "One" but if I can fix the 880...
Treeroot is offline
post #47 of 50 Old 12-27-2009, 02:55 PM
Treeroot's Avatar
Well I got no response so I tried it. Used a tiny piece of double sided tape to attach a tiny piece of eraser to metal contacts. Volume up works now. Saved myself a couple hundred bucks.
Treeroot is offline
post #48 of 50 Old 12-28-2009, 07:08 AM
scribe5's Avatar
I had the same problem with the volume button..so I used electronic contact cleaner that comes in a spray can. I shot some spray under the volume button and let it sit for about an hour to make sure the liquid evaporated. The volume buttons work great and no apparent harm to the remote. YMMV.
scribe5 is offline
post #49 of 50 Old 12-31-2009, 01:15 AM
Quoted: 14 Post(s)
I didn't use anything but the small piece of eraser. I was careful to snap the remote back together again without disturbing the placement.
post #50 of 50 Old 12-31-2009, 01:18 AM
Quoted: 14 Post(s)
Yours must have been sticky. Mine didn't fix after cleaning. I had to do the eraser trick.
Reply Remote Control Area
