how do you find the IR Sensor on your equipment?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-24-2008, 07:48 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
i have a cable box, a denon blu-ray player, reciever, I cant figure out where the IR sensor is where I can put the mouse from Xantech. How do you find it?? I have no idea how to look for it if it isnt explicitly marked... please help?
I really cant find it on the Comcast HDMI cable box
Ou8thisSN is online now
post #2 of 9 Old 09-24-2008, 09:37 PM
WayneDB123's Avatar
I shine a flashlight through the front panel, hold it right on the surface and it should be easy to see, also sometimes the manual has a good picture of where it is located.
WayneDB123 is offline
post #3 of 9 Old 09-24-2008, 10:06 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
i didnt get a manual with my comcast HD cable box, its a hdmi silver box... i guess i'll try to shine one tomorrow. what exactly am i looking for?
post #4 of 9 Old 09-25-2008, 01:13 AM
Symbios's Avatar
A camcorder with nightvision mode makes it extremely easy to see through the panel. But if you don't have one, a flashlight works too.
The IR sensor will look like an LED, except it'll probably look black. They typically have a metal shroud around them.
Symbios is offline
post #5 of 9 Old 09-25-2008, 06:12 AM
eddielives's Avatar
If it's a DCTxxxx box, it's on the far left side of the oval display. If it's a newer DHCxxxx box, it's above the ch+ button. I really wish they would have put an IR input on the back pannel.
"People are very open-minded about new things -- as long as they're exactly like the old ones"
Kettering
eddielives is offline
post #6 of 9 Old 09-25-2008, 08:25 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
yeah i have a camcorder, i tried the night vision thing but i could only see the emitters on the remotes, never on the receiving devices. Anyway, I took each of the boxes up to the sun and then I saw the IR receivers, so I made my connections. so far so good, thanks for the help
they really should mark off the IR sensor on every electronic manual. thats just rediculous to have to hunt for it.
post #7 of 9 Old 09-26-2008, 05:48 AM
eddielives's Avatar
So... was I right?
Kettering
post #8 of 9 Old 09-26-2008, 07:50 AM
SaltiDawg's Avatar
If all else fails, have someone stand in front of the gear and take a 3"X5" card and move it in front of each piece of gear until the remote stops working. Then fold the card in half - now a 3"X2½" card and narrow it further. Finally your thumb or similar will nail it down. (Would that be a thumb nail? )
SaltiDawg is offline
post #9 of 9 Old 09-26-2008, 10:07 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
Originally Posted by eddielives View Post
So... was I right?
yea you were.
Reply Remote Control Area
