How to take apart Harmony One remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2008, 10:36 PM - Thread Starter
lstorm's Avatar
I've had the remote for about 5 months and it works fine, except I notice a slight rattling sound inside the remote like a little piece of something is shaking around in there. Now it doesn't affect the performance in any way, however it is annoying the bejesus out of me, it's starting to drive me nuts. Is there a way to take this thing apart, I just want to see what is causing the rattle.
lstorm is offline
post #2 of 3 Old 10-02-2008, 11:30 PM
acsubie's Avatar
i think what you are referring to is the "tilt" sensor that turns on the display when you pick it up..they all have that "rattling" sound
acsubie is offline
post #3 of 3 Old 10-03-2008, 09:32 AM - Thread Starter
lstorm's Avatar
Ah ok silly me , thanks!
lstorm is offline
Reply Remote Control Area
