Urc r50 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 150 Old 03-07-2013, 01:49 PM
journey4life's Avatar
Has anyone been able to program the URC R50 to control the volume up/down and mute for the Samsung E450 sound bar?
I have power on/off working but that's it.
journey4life is offline
post #122 of 150 Old 03-07-2013, 02:49 PM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
Could there be punch through enabled blocking the volume keys? Try punching through volume keys from that device to that device, then reteach.
Edmund is offline
post #123 of 150 Old 03-07-2013, 03:17 PM
Thanks Edmond - unfortunately I'm a novice and not familiar with 'punch through' however ... a poster on the previous page provided this link http://www.remotecentral.com/reviews/urc_r50/index6.htm. I tried the 'inside device' thing eek.gif and that appeared to be my problem. My LCD screen goes totally blank but the volume works and I'm good with that. I'm so totally pumped that the volume works now I forgot to even try mute.tongue.gif
Huge thank you for taking the time to offer some advice!! Next - try to program macros and then teach my husband how to use this remote (we've only had it for 3 or 4 years already).biggrin.gif
Step 1: Bookmark that link above and hope it never goes away - or find a way to print all the instructions and guidance the owner has provided - totally invaluable!
post #124 of 150 Old 03-07-2013, 03:35 PM
mdavej's Avatar
Quoted: 1982 Post(s)
Liked: 900
Making the vol buttons control another device besides the tv (like a sound bar or receiver for example) is called punch through or volume lock.
mdavej is offline
post #125 of 150 Old 03-07-2013, 04:01 PM
thanks
post #126 of 150 Old 04-09-2013, 02:06 AM
mijotter's Avatar
Liked: 59
Can the R50 and R40 control IR lights and dim them as well?
mijotter is offline
post #127 of 150 Old 04-09-2013, 03:21 PM
mijotter's Avatar
Liked: 59
Anyone know?
mijotter is offline
post #128 of 150 Old 04-09-2013, 04:38 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 442 Post(s)
Liked: 741
Originally Posted by mijotter View Post
Anyone know?
It would be helpful if you tell us what kind/brand of dimmable lighting system you have so we can look for it in the list.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Series3 & Premiere, TWC Cisco 8742HDC DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, R40, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #129 of 150 Old 04-09-2013, 07:18 PM
mijotter's Avatar
Liked: 59
my apologies.
http://www.smarthome.com/2477D/SwitchLinc-INSTEON-Remote-Control-Dimmer-Dual-Band-White/p.aspx
http://www.smarthome.com/2472DWH/OutletLinc-Dimmer-INSTEON-Remote-Control-Outlet-Dual-Band-White/p.aspx
I'm torn between the Harmony 890 and the R40. The Harmony 900 is gone because of the steep price and inability to do sequencing. In my setup, My A/V equipment will be in a cabinet in the front of the room and I will also have 2 fish tanks in the wall with the outlets on the adjacent rooms wall. What would need to be done and bought to control these other than the R40 remote? Thanks.
mijotter is offline
post #130 of 150 Old 04-10-2013, 11:38 AM
tkurkowski's Avatar
I took the time to convert it to a Word File. Send me a Private Message here with your email address and I'll send it to you. (Mouse over my name on the left here, then click on Send PM.)
Ted
tkurkowski is offline
post #131 of 150 Old 04-12-2013, 11:18 AM
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #132 of 150 Old 04-15-2013, 07:29 PM
mijotter's Avatar
Liked: 59
my apologies.
/Bump
mijotter is offline
post #133 of 150 Old 04-15-2013, 11:10 PM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
No, the URC r50 will not communicate directly with those fixtures. Look for an IR device that does communicate with them, and then you might be able teach the r50 the commands.
Edmund is offline
post #134 of 150 Old 04-15-2013, 11:19 PM
mijotter's Avatar
Liked: 59
mijotter is offline
post #135 of 150 Old 04-16-2013, 01:40 AM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
Yes, that would do it.
Edmund is offline
post #136 of 150 Old 04-16-2013, 10:49 PM
mijotter's Avatar
Liked: 59
Is there an RF module that goes well with the R40 for controlling equipment in a cabinet?
mijotter is offline
post #137 of 150 Old 07-30-2013, 12:01 PM
Voyeur's Avatar
I got this remote on ebay. After some serious trial and error, I finally got my components programmed. It took a while to find the "right" codes for them. One thing I realized is you have to check other buttons to test the code other than the ones recommended by the screen instructions. In particular, the skip buttons for the DVD/Bluray players...even then, the internal menu might not look quite right. I have them as close as I'm gonna...then I used the learning instructions to complete it.
As far as macros. I ultimately decided to use the main menu buttons. One for turning my cable system on. Another to turn off. Another to turn my bluray on. Another to turn off and switch back to cable. 2 more to switch my CD player on and off. And finally a button to switch off the cable system entirely. I just like having the macros on the main screen instead of internal to one of the components. Heck, I don't have 18 components anyway.
So far, I love it. It took a lot of time, but I can't say it was hard once I started to get adjusted. Not sure about using the punch through. I don't think I'll really need to use it...except regarding the audio. I did use it to make sure my volume/mute buttons defaulted to the surround sound receiver.
Voyeur is offline
post #138 of 150 Old 07-31-2013, 06:24 AM
tkurkowski's Avatar
I found the punch through to be quirky back when I programmed mine but maybe I didn't do it right. Nevertheless I'm with you - I love mine and once I was on a roll, programming it was easy. The only thing about it that bothers me is that there's no computer interface so we can't back up the programming. I hate to think about re-doing it if my R50 quits.
Ted
post #139 of 150 Old 07-31-2013, 07:47 AM
Voyeur's Avatar
Ted
Well, hopefully this remote lasts. I love the heft and how durable it feels. Some of those Harmony remotes felt a little....cheap to me. This feels rock solid. If I have to replace it, then it won't be the first time I had to start all over with programming.
Voyeur is offline
post #140 of 150 Old 07-31-2013, 11:13 AM
tkurkowski's Avatar
I've had mine for a year and a half and it's holding up well (although it doesn't get a huge amount of use - I'm not a TV user but not an addict).
I'm a senior manager in an IT company so it wouldn't be the first time for me to re-do a code set either. But I also know better than most folks how unnecessary re-doing it should be. A USB connection to a simple software interface isn't rocket science - that's been available on cell phones from the beginning. Yes, I know that the pro series URC remotes are all set up using a computer but they're in a different price range and anyway that doesn't mean the consumer remotes can't have a backup/restore capability.
post #141 of 150 Old 07-31-2013, 11:51 AM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
They do have consumer remote with backup features, its the mx-450. And older models like mx-350 & mx-650 could back up there contents via the pcl300.
Edmund is offline
post #142 of 150 Old 08-01-2013, 06:05 AM
tkurkowski's Avatar
Hmmm. Thanks - I had thought the 450 required the URC professional programming software but looking at their web site I see it doesn't.
Have you used the backup software? Does it only do backup and restore, or can you actually program the remote through the software? I understand that it is normally programmed on the unit, like the R50, but after doing that once I suspect I'd rather program it thru software...
post #143 of 150 Old 08-01-2013, 11:30 AM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
Yes, I have used the mx-450 archiver, it allows you to back up your setup, and it even updates the code database, but no you can not program the remote via your computer.
Edmund is offline
post #144 of 150 Old 08-31-2013, 08:25 AM
Voyeur's Avatar
I'm surprised so few people have this remote on this site. Anyway, I finally programmed my favorite channels. It's pretty nifty, but I'm a bit disappointed it didn't have the emblems of certain channels like BBC America....
...then I realized I probably will never even use the favorite channel buttons since I use my guide most of the time anyway. LOL
Voyeur is offline
post #145 of 150 Old 10-27-2015, 09:04 PM
SubaruB4's Avatar
Quoted: 30 Post(s)
Liked: 30
I'm looking to buy this remote to replace my Harmony 880 and wondering how easy/hard it would be to kinda get it setup the same way as my 880
SubaruB4 is offline
post #146 of 150 Old 04-03-2016, 06:26 PM
kevin75's Avatar
Hello everyone,
Since I moved into my house 5 1/2 years ago, I've been using a Universal RF20, and it's been great. However, the buttons on it are starting to not work anymore so my wife bought me a Universal R50 to replace it. I took it out of the box and it felt great and I programmed some things into it.
My problem is that all of my components are in a closet in the hallway, so the signal has to go through a wall to get to the components. With the RF20, I've been using the Universal powerblasters to help the signal go through the walls, however, I don't have enough of them left to use now. I'm not really the biggest tech guy when it comes to remotes, etc, but I would like to be able to use this through the walls. Can anyone point me in the direction of something that I can use?
kevin75 is offline
post #147 of 150 Old 04-03-2016, 06:35 PM
Edmund's Avatar
Quoted: 46 Post(s)
Liked: 30
R50 is IR only remote, the mx-450 is RF version of it. Look into Next Generation remote extender, makes IR remotes RF. Find 418 MHz version, should communicate with powerblaster MRF directly.
Edmund is offline
post #148 of 150 Old 04-21-2016, 07:25 PM
kevin75's Avatar
Edmund,
Thanks for the reply. Does it make a difference if it's the 418mhz vs. the 433mhz? I tried to get the 418 from Amazon but it seems to be long gone.
kevin75 is offline
post #149 of 150 Old 04-21-2016, 07:41 PM
"Don't PM Me Bro"
Quoted: 442 Post(s)
Liked: 741
Originally Posted by kevin75 View Post
.......Does it make a difference if it's the 418mhz vs. the 433mhz? I tried to get the 418 from Amazon but it seems to be long gone.
Here's a 418 mhz:
http://www.amazon.com/dp/B0018MFGRQ/...=ITL8IND8UI7S8
Randy
post #150 of 150 Old 04-22-2016, 05:06 PM
kevin75's Avatar
Thanks Randy! I had ordered that last week, and it got returned even before it was delivered because it was 'damaged in transit'. Then when I looked again yesterday, they didn't have any more for less than $60.
kevin75 is offline
Reply Remote Control Area
Urc
