Comcast remote codes for Sharp TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2009, 10:11 AM - Thread Starter
dodger48's Avatar
I have the Comcast working for everything but the On Demand. I can view OD, but I can't select using the A/B/C buttoms on the remote. They don't respond.
I am using setup code 11602 for the Sharp model 46D64U.
Are there additional codes for controlling the A/B/C keys on the Comcast remote? These buttons are used when entering On Demand. I think they were disabled when I did a factory reset of the remote.
dodger48 is offline
post #2 of 3 Old 01-20-2009, 05:40 PM
petern's Avatar
The Comcast website has manuals for their remotes buried in their support section... I've always used 10093 (previously 0093) for Sharp TVs for several years now.
petern is offline
post #3 of 3 Old 01-20-2009, 08:17 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Despite the title of your post, you're not asking for a sharp code, right? You just want to get A/B/C back. As you've guessed, the reset may have wiped out the comcast upgrade. So you have a few options: exchange your remote for another one, post the model of your cable box and someone may be able to give you the codes for just the missing buttons, or buy/build a JP1 cable and load the upgrade back in yourself. Option one is free. Option three will cost $15-$30 and a few hours figuring out what to do and installing some software. Post over at the hifi-remote.com forums to find the cable and file you need, if you go with the third option. The benefit of the third option is that, once you have a cable and understand the software, you can make that remote do just about anything. I'm also assuming your remote has a 6-pin connector in the battery bay. If it doesn't, then option three and probably option two are off the table.
mdavej is online now
Reply Remote Control Area
