The Harmony 1100 Owner's Thread... - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #271 of 2085 Old 06-26-2009, 07:10 PM
Wannabe Actuary's Avatar
just to add some more information... the 1100 supports 3 extenders
there are profiles for media center pcs... but you may still have to tweak it based on your specific programs that you're using
as far as the lights Tom is right about rf lights
they have to be ir based (most people end up using x10 lights with the IR543 interface or lutron lights) in the case of the ir543 interface you can place that near the rf extender so that for all intents and purposes it works like rf lights
if Tom hadn't gotten upset about the icons and bailed from the logitech site he would have heard our suggestion to swap the lights power on and off commands so that when you enter the activity the lights turn off and then when you leave the activity they turn on
Wannabe Actuary is offline
post #272 of 2085 Old 06-26-2009, 10:04 PM
TomsHT's Avatar
How does that remove them from automatically being turned on or off from ANY activity as my comment states? :rolleyes
TomsHT is offline
post #273 of 2085 Old 06-27-2009, 04:43 AM
lights will only be included in the activity IF you put them in there. if you don't put them in the activity, then they won't power on/off automatically.
you can also change the power commands to none, so that what it sends is nothing....then place the light controls in the activity button customization.
I was suggesting something that many people want, the light automation, but in the right direction. most people want lights off when using an activity, and then lights on when ending things...putting the power on command where the off is supposed to go and vice versa, gets you to that goal. but if you want the lights in the activity but not powered on/off automatically, then see the other suggestion I just made
post #274 of 2085 Old 06-27-2009, 07:33 AM
Crispyclot's Avatar
"I see JoeRod placed his theatre logo onto the remote. Is this done thru a hack or is it easy enough to choose a "desktop" picture"
I know its maybe off-topic , is Joe's logo thru his PJ or is it on the remote or some other component ie. HTPC ?
Crispyclot is offline
post #275 of 2085 Old 06-27-2009, 12:52 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I actually had someone design it so I have it as a pic as well. It starts my intro dvds when I have guests over. Makes it more fun.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #276 of 2085 Old 06-27-2009, 01:14 PM
Crispyclot's Avatar
So its just an image burned onto a disc ? In a carousel type setup where it plays the dvd you want to watch after intro ?
post #277 of 2085 Old 06-27-2009, 02:39 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Oh no, I have my own theater intro dvd that says Welcome to JoeRod Home Theater. It shows a flying dvd that explodes into a movie theater screen. Then there is a countdown with movie posters and trivia questions. I have 4 or 5 different ones. This is usually when I am making popcorn and getting drinks ready.
joerod is offline
post #278 of 2085 Old 06-27-2009, 03:14 PM
Crispyclot's Avatar
....wow , now thats something !! 11/10 for your theater room as well .
post #279 of 2085 Old 06-27-2009, 03:18 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
joerod is offline
post #280 of 2085 Old 06-29-2009, 04:21 PM
Crispyclot's Avatar
Got my 1100 yesterday , very pleased so far . Easily setup and tweaking comes easy with a lil time . A few minor bumps with activities but after getting the hang of it ( do it manually ) and order of devices/delays in check it was all good . Thanks to Wannabe and Hhatkin for the help!
Now i got Babes and Horror movie carnage for a Slideshow and the Joker's ugly mug for my wallpaper , i would highly recommend !
post #281 of 2085 Old 06-30-2009, 01:39 PM
drpete12's Avatar
Quoted: 105 Post(s)
Liked: 44
Can someone post some screen pics of the 1100 showing their Windows Media Center Control (see what is looks like) and also if they have any lighting controls , show how and where they put them.
drpete12 is offline
post #282 of 2085 Old 06-30-2009, 01:49 PM
TomsHT's Avatar
Not sure what ya mean about lighting controls, add them as a device and then add them to an activity, in the activity create a custom button that links to the lights power button.
TomsHT is offline
post #283 of 2085 Old 06-30-2009, 06:29 PM
JaGee's Avatar
Hello All,
I need help setting up a Huntington Bay fan. I found the model # and set it up on my 1100 but cannot get it to react to any commands. In devices I see the fan but there are no function buttons on the touch screen. Do I need the RF extender for this?
Thanks in advance......this is my first time posting on any forum so if I have not stuck to the rules please correct me
Jay
JaGee is offline
post #284 of 2085 Old 06-30-2009, 06:41 PM
TomsHT's Avatar
Welcome Jay, is your fan RF controled or is it an IR remote? The 1100 doesnt actually transmitt to any RF devices except the logitech rf wireless extender, and that converts and controls IR devices.
TomsHT is offline
post #285 of 2085 Old 06-30-2009, 06:52 PM
JaGee's Avatar
Thanks for the quick reply. I am not sure I have searched the web for the answer but under every description I can find it does not say if it is IR or RF. I will find this out and get back to you. I do plan in getting the extender anyway so I guess i should do that first then it wont make a difference.....correct?
Again thanks
JaGee is offline
post #286 of 2085 Old 07-01-2009, 04:10 AM
TomsHT's Avatar
Again thanks
Hi Jay, IR are line of sight remotes where you have to point the remote at the device your trying to control. My remote fans/fireplace and some lights usually are RF which means it can still control the device even if it cant see it. So an easy test is just to use your normal remote for your fan and see if you can control it while say your hand is in front of it (blocking the would-be IR beam) or from a different room)
TomsHT is offline
post #287 of 2085 Old 07-01-2009, 05:08 PM
jagee...if the fan is RF, you won't be able to control it even with the RF extender. the RF extender let's you control IR devices without line of sight...in short, the remote sends RF to the extender, which converts it back to IR...no proprietary RF devices can be controlled
post #288 of 2085 Old 07-03-2009, 08:33 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
For some reason my cable box no longer responds to my 1100. I use it with a RF extender and without notice it just completely stopped repsonding. I have reloaded the firmware and software without any luck.
Any thoughts?
vancouver is offline
post #289 of 2085 Old 07-03-2009, 08:43 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
rather then delete my post above I thought I would post the issue I discovered because I am sure others will face the same issue. After trouble shooting I found that the cable died. I guess the eye can short out or die after time?
post #290 of 2085 Old 07-03-2009, 08:45 AM
TomsHT's Avatar
How old was the cable?
TomsHT is offline
post #291 of 2085 Old 07-03-2009, 09:55 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
1 month
post #292 of 2085 Old 07-03-2009, 10:53 AM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
I've added an activity to setup my receiver and display for using our computer. The only functions that I want the remote to control are power (for display and receiver), connections, and volume control.
I tried several different activity configuration including adding the computer as a device. I was unable to get the Harmony to control volume until I did a manual activity for watching TV. Then I lied about the connections. So far that's worked, but I'm wondering if there is a cleaner solution. I'm using version 7.5 of the remote software.
htwaits is offline
post #293 of 2085 Old 07-04-2009, 07:01 AM
for a PC based activity, the most common 'base' activity to use is "Show Presentation"
post #294 of 2085 Old 07-04-2009, 10:56 AM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
That's one I didn't try.
htwaits is offline
post #295 of 2085 Old 07-04-2009, 08:55 PM
joe1515's Avatar
Is there a way to set up the 1100 to control my remote controled hunter douglas blinds? The blinds remote is a basic 1 or 2 zone remote.
joe1515 is offline
post #296 of 2085 Old 07-05-2009, 05:31 AM
TomsHT's Avatar
Sorry Joe, Unless im mistaken all douglas blinds are controled by "RF" remotes. The 1100 does NOT control RF devices only the RF wireless extender which itself only controls IR devices not RF.
TomsHT is offline
post #297 of 2085 Old 07-07-2009, 07:58 PM
pdn
pdn's Avatar
Could any 1100 owner please confirm/deny that the remote can be operated while in the dock? Must the remote be pointed at the components (in IR mode) or could I use the dock to prop up the remote for single-hand operations? Thanks!
pdn is offline
post #298 of 2085 Old 07-07-2009, 08:02 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
It does not work when plugged into the dock. It is charging. I do have a little "trick" though. I just unplug the cord from the dock when I (we) are watching movies. I did follow cconklin1 and just purchased an extra dock to put it in. This will come in handy if I am not in my main seat or if I do his cool trick and build it into my cupholder.
joerod is offline
post #299 of 2085 Old 07-08-2009, 04:51 AM
pdn
pdn's Avatar
Thanks joerod for the quick response! A second dock is a good idea...however, I'm concern with the strength and directionality of the IR signal. My components are below the TV and with the remote pointing roughly 45 degree up (while in the dock), I wonder if the IR signal will have enough strength to bounce off the ceiling and get to the components.
pdn is offline
post #300 of 2085 Old 07-08-2009, 04:55 AM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
The signal is very strong but each environment is different. Is there a reason you couldn't do the RF Extender?
joerod is offline
Reply Remote Control Area
Directv , Harmony 1100 Remcontrol , remote control , repair advice , Sony
