The Harmony 1100 Owner's Thread... - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #451 of 2085 Old 09-01-2009, 03:40 PM
Wannabe Actuary's Avatar
if your onkyo is like mine, each listening mode doesn't have it's own command on the original remote. there are several buttons that scroll through various lists of modes
you of course can assign any of those commands to the LCD of the remote (either the star screen or the side bars in any screen)
I don't know that any exist, but if you found discrete commands for any of the sounds modes you could have logitech add them to the database for you
depending on your onkyo though, all of this might be unnecessary
on mine, I was able to set a default sound type for each input (which in turn is basically each activity)...so the receiver automatically switches to sound type "a" when I change to "input 3" for instance. no need for me to use the harmony to change sound modes
Wannabe Actuary is offline
post #452 of 2085 Old 09-01-2009, 05:38 PM
ser182's Avatar
Thanks WA! I have and 805. So if it has the command it is able to be done. One other thing, does it play nice with Dishnetworks remote? Main buttons used are guide and info. Thanks
Xbox live- SER 182
Mix Cloud
http://www.mixcloud.com/Ser182/
ser182 is offline
post #453 of 2085 Old 09-01-2009, 07:16 PM
as long as the box can be set to receve IR commands, you'll have no problems
you may need to use the "confirm IR commands" option to make sure the remote is using the correct IR address
other than that, it should be very straight forward
post #454 of 2085 Old 09-04-2009, 04:05 PM
joe1515's Avatar
I was wondering why I have to update the rf extender every time I update the remote? It is really annoying.
Joe
joe1515 is offline
post #455 of 2085 Old 09-05-2009, 07:02 AM
Joe
I agree. it didn't used to be that way. with software version 7.5 you could plug in the remote when it asked for the extender and it would check if the extender needed updating...it was a nice trick. but with software 7.6, it changed for some reason
I assume that future remotes will go the way of the 900 and move to the ECNet RF protocol and the blaster will get updated wirelessly from the remote after the remote is connected for updates. it is pretty sweet
post #456 of 2085 Old 09-05-2009, 08:48 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
Anyone else notice a high pitched noise coming from the display of the 1100 when its lit up? I just started noticing it yesterday. Is this a sign of things to come?
vancouver is offline
post #457 of 2085 Old 09-05-2009, 05:21 PM
it's been there on all the remotes with color screens from what I can recall. on my 1100 I can only hear it if I bring it very close to my head (ie right against my ears)
post #458 of 2085 Old 09-06-2009, 10:39 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
Strange. I only recall hearing it when the remote was charging with the screen on for both the 1000 and 1100. This is the first time I am hearing it with the remote off the base. I can hear it from 2 feet away if the screen is pointing towards my face.
post #459 of 2085 Old 09-06-2009, 04:17 PM
on the base it has to do with the screen brightness or something being turned up all the way...if you reduce it it goes away
or maybe it was there if it was reduced and it needs to be up all the way
I can't recall exactly
but off the base it sounds like yours is too loud and I would contact support
post #460 of 2085 Old 09-07-2009, 07:53 AM
Dirtold's Avatar
The transport controls for the Panny DMP-BD35 are greyed out and unusable. Is there a fix or should I just substitute the BD30 for the BD35?
I have 2 DVD players and had to add this one through other. Is there a way to add a 2nd DVD player?
Dirtold is offline
post #461 of 2085 Old 09-07-2009, 07:58 AM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I am still enjoying the 1100. I have found it really easy when it comes to switching out Activities (which I do often) when adding new components...
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #462 of 2085 Old 09-07-2009, 05:23 PM
added one through the other? you lost me there
add new device, add the second DVD player...nothing hard there
then add activity, MANUAL, watch DVD, etc
transport controls are likely greyed out based in the activity type you selected
post #463 of 2085 Old 09-07-2009, 06:35 PM
Dirtold's Avatar
Not sure what I did 1st time but per your suggestion all is OK now; thanks.
Dirtold is offline
post #464 of 2085 Old 09-12-2009, 05:13 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
G'day there.
I'm wanting to do two things with an 1100 that I'm configuring for a friend...
1. With a non-controllable bluetooth device like the Wii, a message screen appears that says something like "Please turn on the Wii".
2. Add a logo for Activites on the main screen (namely Foxtel, Playstation3, Wii).
Thanks very much, in advance.
Electric_Haggis is offline
post #465 of 2085 Old 09-12-2009, 07:10 PM
Originally Posted by Electric_Haggis View Post
G'day there.
1. can't do a custom message on the screen like that.
2. activity logos/icons on the screen are set based on the activity type you select when creating it. so, even though you can't control your Wii, add it to the setup, and you can set it up in a play game activity...the result is a nice 'game controller' image for the activity
post #466 of 2085 Old 09-14-2009, 11:38 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
I just got my H100 today and I want to loose all the automatic stuff in the ACTIVITIES. Meaning I want buttons on the front screen for all my components so that when I click on the receiver icon I get the control for it without the H1100 powering up anything. I want total manual control of everything, I just want to use the H1100 instead of the pile of original controls. Is this possible? The manual I found online wasn't very comprehensive so it didn't help me with this.
Tried to email Logitech but they are having tech difficulties.
Gurba is offline
post #467 of 2085 Old 09-14-2009, 12:28 PM
you can of course use it as a device level control, but you're overpaying if you're only using it that way
also, keep in mind that logitech intends the use to be via activities, so they're not going to make it easy to use device mode
you'll have to press the "wrench" icon from the main screen and then select "devices" and then keep going from there
post #468 of 2085 Old 09-14-2009, 02:03 PM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
That's exactly what I'm going to use it for. I'll give it a shot. Tnx.
EDIT: Not what I had in mind. Can I at least turn off the power on/off function and the switch input function?
Gurba is offline
post #469 of 2085 Old 09-14-2009, 02:53 PM
you can set the power and input commands to none and then setup activities...they won't do anything for you automatically but you will be able to control multiple devices at once
post #470 of 2085 Old 09-14-2009, 10:59 PM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
OK. I'll start digging into the settings. TNX.
Gurba is offline
post #471 of 2085 Old 09-15-2009, 02:06 AM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Real easy. There are plenty of extra options under the device area. I can easily switch from Blu ray and say DirecTV (watch TV) and not have anything turn off. I have it set to "leave devices ON" when not in use. Also, you can have light and other commands set under Blu ray (watch a dvd) like dim lights or close masking system. And lastly, don't forget that you can assign page UP and page DOWN (hard buttons) to do commands. I use mine for POp Up Menu and Display. Makes life very easy when you jus want to see what's going on quickly. Same for the channels (Up and Down) which I use for LIght Dimming or Raising and channel back which I use for sound modes from my receiver... You can be very creative with this remote. The more creative you are the more easier life is...
joerod is offline
post #472 of 2085 Old 09-15-2009, 05:36 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
When I'm inside an activity and go to the main front, how can I go back into the activity without the remote trying to turn on everything that's already on?
Gurba is offline
post #473 of 2085 Old 09-15-2009, 05:53 AM
press the activities button a second time (note, I'm not saying reselect the activity, but rather to press the button "activities" when the activity list is showing) and you'll return to your current activity with no commands being sent
post #474 of 2085 Old 09-15-2009, 06:10 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
TNX. I guess I should read the manual, but...
Gurba is offline
post #475 of 2085 Old 09-15-2009, 06:30 AM
not sure that stuff like that is in the manual...but that's what I'm around for
post #476 of 2085 Old 09-15-2009, 09:44 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 194
I wouldn't know since I haven't read it, but I appreciate the knowledge of the members here and on the Norwegian forum I'm a member of.
EDIT: The H1100 is looking better now that most of my customization is in.
Gurba is offline
post #477 of 2085 Old 09-15-2009, 10:52 AM
I'm on the newer side here, but I bring with me the experience of 12,000+ posts on the harmony forums (currently on hiatus from there), three beta tests and an inside source or two at logitech
obviously there are things I can't talk about, but there isn't too much I'm not capable of ansewring so long as my NDAs don't prohibit it
post #478 of 2085 Old 09-15-2009, 11:26 AM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Glad to have you here...
joerod is offline
post #479 of 2085 Old 09-19-2009, 01:30 PM
marting98's Avatar
Hi all - I'm looking for advice on the best way to approach this and/or a workaround. When in an activity - say "watch PVR" I want to be able to access my TV's Menu in order to change the picture mode. Unfortunately when I bring up the TVs Menu my up/down/left/right buttons still send commands to the PVR (still in that activity, remember) How have others deal with this? Do you create additional up/down/left/right tv buttons in the PVR activity?
marting98 is offline
post #480 of 2085 Old 09-19-2009, 01:39 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Oh yeah, under the "Star" section of the activity just create a page that has the directional buttons. I do that with a VP I am currently Beta testing. It is very easy. I also added the Info command to. You can also add a light control button (Dim or bright) as well as a Masking System page...
joerod is offline
Reply Remote Control Area
Directv , Harmony 1100 Remcontrol , remote control , repair advice , Sony
