The Harmony 1100 Owner's Thread... - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #181 of 2084 Old 05-22-2009, 09:03 AM
Tight_Wad's Avatar
Does anyone know when the will start using programmable sequences? Love to get one, but if no sequence like the Harmony ONE, then not much use to me right now.
Scott
"No, I'm not a pro theater builder, I just stayed at Holiday Inn Express!"
Tight_Wad is offline
post #182 of 2084 Old 05-22-2009, 05:53 PM
wiredca's Avatar
hi guys..
just purchased the harmony 1100.. am curious to find out how to change the activity icons and name.. right now it's set to the harmony icons and naming (eg. watch tv.. watch movie.. watch dvd.. etc)..
would seriously like to know the ins and outs on the harmony 1100.. currently i have 2 home theatre setup.. one for the living room.. the other in the basement..
would like to create 2 activities.. one for upstairs.. one for downstairs..
all replies are much appreciated.. thanks to all..
cheers...
wiredca is offline
post #183 of 2084 Old 05-22-2009, 06:29 PM
Wannabe Actuary's Avatar
Originally Posted by wiredca View Post
hi guys..
cheers...
1. you can't change the activity icons
2. to rename them, in the setup, activities tab, settings for the activity, rename activity
3. create as many activities as you want...add activity, MANUAL, then the correct activity type
Wannabe Actuary is offline
post #184 of 2084 Old 05-22-2009, 06:43 PM
as far as I know, there are no plans to add sequences to the 1100. currently, the 1100 is the only remote that doesn't support sequences (it of course does activities, just not sequences)....it's something specific to the remote...I can't say any more, logitech will explain it if they want to
post #185 of 2084 Old 05-22-2009, 08:12 PM
wiredca's Avatar
thanks wannabe..
how do i add favorites on the tv channels.. i have the sonicview 360 setup as an activity to watch tv..
thanks..
wiredca is offline
post #186 of 2084 Old 05-23-2009, 02:39 AM
thanks wannabe..
thanks..
www.iconharmony.com
select the icons you want, download the zip file of them, unzip them. then, assuming the activity type is a watch tv activity type (that's the only type that supports favorite channels, you should see the option to setup favorite channels in the setup, activities tab, options for the activity, setup favorite channels. you'll enter the channel number and then browse to where you unzipped the icons so that you can select it
post #187 of 2084 Old 05-25-2009, 02:02 PM
ekstudman's Avatar
Can anyone tell me whether the 1100 is setup to organize and control multiple zones, i.e. living room, media room, etc? One of the biggest complaints I have with my current remote (880) is that you cannot set up different activities for different rooms. Instead, all activities are grouped together on the same page, which makes switching between different rooms a pain in the ***. Does the 1100 have a button or feature to switch between different rooms so you can press "living room" and all activities for that room are displayed, then press a button for a different room and so forth?
ekstudman is offline
post #188 of 2084 Old 05-25-2009, 03:23 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Has anyone been able to hard wire a Denon 3806 to the RF Extender and get it to work?
htwaits is offline
post #189 of 2084 Old 05-25-2009, 09:23 PM
nope...but it displays 6 activities per page and you can reorder them...IMO, the purpose of a harmony remote is to take the place of all the remotes in a single setup....not the entire house...
which is why I use an 1100 and extender in the living room, and an 890 and extender in the bedroom. I personally don't advise using a single harmony for the entire house
post #190 of 2084 Old 05-25-2009, 09:26 PM
I have a direct line in from the extender to my onkyo 806...works great
I just pulled up an image from the denon site, and it looks like there is a port labeled remote control IN...so it should work...is it not working for you? are you using a mono or stereo male to male 1/8 cable? mono vs stereo can make a difference
post #191 of 2084 Old 05-25-2009, 11:54 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Thanks for the reply.
I tried it yesterday with a stereo cable and it didn't work. I expected it to work even though there is no clue in the manual that it would. It didn't work.
In the case of the Motorola DCH3416, and the OPPO BDR-83, neither manual indicates that their ports will work either but they do. The OPPO will even pass the signal to it's OUT port.
I'm hoping that a Denon 3806 owner with more experience might have discovered a way to make it work too. The 3806 has been out long enough that most of the active owners have upgraded and moved on to new threads.
In any case, my 1000 setup is solid now, and it's time for me to learn to fine tune it.
htwaits is offline
post #192 of 2084 Old 05-27-2009, 10:59 AM
unIQue007's Avatar
Have just gotten the H1100. Did a upgrade from H1000. I'm now on my 4th Harmony remote. Been trough 885,895, 1000 and now 1100.
Just a quick Q: I have programmed my H1100 with all my activities. For example I have activity, Watch TV. Everything turns on fine, but I can't adjust my volume with the hard buttons on my H1100. To do that I have to push the component button, AV Reciver on H1100 touch screen. Then the hard button can adjust the volume. Isn't the hard buttons supposed to be able to adjust the volume just by choosing the activity? I have set up all my activities where volume controll shall be done by my Pioneer SC-LX71.
My guess is that it's just a quick config thing I have forgotten, but I can't seem to find it. :-)
Forgive my bad english (foreigner... :-) )
Edit: Solved!
unIQue007 is offline
post #193 of 2084 Old 05-27-2009, 11:25 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
You've had Harmony remotes a lot longer than I have so this may not be what you are looking for. When I created my activities I used "manual" instead of "automatic". On question for each activity was which device will control the volume. I always answered "A/V Receiver" and everything has worked as expected.
My remote is the 1000 which sat in a box for a very long time before started using it again last week.
htwaits is offline
post #194 of 2084 Old 05-30-2009, 08:49 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
If anyone here remembers I had the 1000 and loathed Logitech for not warning me I would be a beta tester for it, and for the fact that remote never worked, and never got promised fixes. It truely was the worst product I bought in relation to my 11 years in this hobby.
Recent I acquired the 1100 and must give credit where credit is due. So far it works which is all I ever wanted and in itself is a huge upgrade over the 1000. I find the interface to work much smoother, and the custom side bar logos and set up is a very good touch. I even like the look of the black casing over the silver, and thought I would be indifferent about it.
I will agree with jeorod (see we can agree), in that the lack of ability to choose logos for the activities is a serious let down especially since it would be such an easy fix. Even letting you choose from a selection of Harmony options would be great. Whats with no Blu-Ray icon?!
Here is hoping for a firmware update, but coming from a 1000 I have certainly got use to that feeling. Waiting for a "want" however is much easier then waiting for a "need".
vancouver is offline
post #195 of 2084 Old 05-30-2009, 01:51 PM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
Here are some background images sized for the 1100 if any one is interested. each image is 160 kb or less and fits the 1100 perfectly.
Below is the actual picture file used by Classe for the background of their processors, sources etc. If you have any Classe equipment and a 1100 you will likely want to match the remote to the display on the processor Again formated perfectly for upload to Harmony.
post #196 of 2084 Old 05-30-2009, 02:28 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Awesome Vancouver!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #197 of 2084 Old 05-30-2009, 10:16 PM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
All sized for 1100.
Christmas
post #198 of 2084 Old 05-31-2009, 12:47 AM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
The Charlie Brown one is perfect!!!
joerod is offline
post #199 of 2084 Old 05-31-2009, 12:49 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
My wife's fav.
We are suckers for holiday stuff. There are at least 20 movies we only watch during holiday times.
post #200 of 2084 Old 05-31-2009, 08:10 AM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Originally Posted by vancouver View Post
My wife's fav.
Same here. We even have certain scary movies we watch all thru October!
joerod is offline
post #201 of 2084 Old 05-31-2009, 09:35 AM
squareeyes's Avatar
anyone interested, i just finished the new music choice favorites icons for the harmony 1100. the new icons were made from scratch and correspond to the network's new channel lineup. site in signature below...
,r
follow icon updates, av & remote info on facebook and twitter.
http://www.iconharmony.com
squareeyes is offline
post #202 of 2084 Old 05-31-2009, 09:39 AM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Nice work!
joerod is offline
post #203 of 2084 Old 06-04-2009, 09:42 AM
TomsHT's Avatar
Since this is touchscreen and missing many of a regular controls buttons/keypad etc, Im curious to see what the screen may look like for navigating different things such as cable tv. What does the number keypad look like on the screen, how much trouble to hit the guide and menu type buttons etc? Would anyone happen to have any pictures showing anything similar?
Thanks, Im anxious to pull the trigger now but would like to see this first and confirm things such as display, menu, guide, and number buttons are easy accessible per device.
TomsHT is offline
post #204 of 2084 Old 06-04-2009, 09:46 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
I almost never use the number keys when watching TV. The hard buttons on the side are enough to navigate through menus. In addition you can program your favorite channels using logos.
One thing you will have to get used to with an LCD screen remote is you have to look at your remote a lot more. LCD remotes are less ergonomic then standard remotes IMO. On a positive note LCD screen based remotes are very good if you have a lot of remotes to use and like to switch between them and get to specific and disctrete commands. Its offers more of an interface or extension of your system then a traditional remote.
post #205 of 2084 Old 06-04-2009, 09:54 AM
TomsHT's Avatar
Thanks for the quick response
I almost never use the number keys when watching TV. The hard buttons on the side are enough to navigate through menus. In addition you can program your favorite channels using logos..
Not sure I would agree with that, im not gonna use a single up down button to flip thru hundreds of channels. Is what you are saying, its not easy to bring up a numeric pad type screen and just type the channel you want to flip too?
That seems logical that it will take time getting used too instead of the feel off buttons. Im more concerned about pointing and aiming it though, my equipment rack is behind me and I wonder if that gonna make it problematic with not being able to feel the buttons.
TomsHT is offline
post #206 of 2084 Old 06-04-2009, 10:15 AM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
Depends on the interface of your cable box I guess. Mine is set up to navigate menus rather then type channels.
Dont point and shoot...get the RF extender.
post #207 of 2084 Old 06-04-2009, 11:16 AM
TomsHT's Avatar
Thanks again for the responses V but the evasive answers of whether or not it was easy to type in a simple channel number was really putting me off.... I had to quick buy the darn thing before ya scared me away from it for good. On order from Amazon now, hopefully it will be here tomorrow.
As for the RF extender, ya I know but lazy me the last RF extender kit I bought is still sitting at home in the box not installed...
TomsHT is offline
post #208 of 2084 Old 06-04-2009, 11:55 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
... but the evasive answers of whether or not it was easy to type in a simple channel number was really putting me off ...
If the 1100 is anything like the 1000 you should like the way you enter channel numbers. I find it much improved over my DCH3416's remote.
I've just added the extender because I've moved our components to a rack on the other side of the display's wall. It's wonderfull. It's especially great if your components allow you to hard wire the IR signal instead of using the IR blasters.
For instance, the DCH3416 frequently missed commands using it's IR receiver, but with a wire connection to it's service port, it's never missed a command.
The biggest problem I've had with the extender is teaching myself that I don't need to point.
htwaits is offline
post #209 of 2084 Old 06-04-2009, 12:09 PM
I'll take and upload a photo in a minute of both the favorites screen and the channel entry screen...it's quite easy to both enter channel numbers and easy to move through the guide...remember, there are hard buttons for 'page up' and 'page down', so you don't have to scroll one by one through your guide
post #210 of 2084 Old 06-04-2009, 12:17 PM
TomsHT's Avatar
Heyya thanks, as I said i placed the order anyway so either way I will find out soon but if its not to much trouble I would still enjoy the pics and Im sure others will also enjoy learning more about the remote too
TomsHT is offline
Reply Remote Control Area
Directv , Harmony 1100 Remcontrol , remote control , repair advice , Sony
