The Harmony 1100 Owner's Thread... - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2071 of 2084 Old 01-22-2016, 01:57 PM
mak99's Avatar
Quoted: 27 Post(s)
Originally Posted by htwaits View Post
Am I the last person at AVS who still owns a Harmony 1100?
Add another "nope!" to the responses!
I have two 1100's for two separate systems - a main level "everyday" system, and a dedicated basement media room that's typically only used on the weekends. And a friend of mine also has one, which he bought quite a few years ago via my recommendation.
I only use the RF feature in the media room, for controlling the Lutron Maestro IR dimmer switch. All other signals are IR, which are send to the remote equipment rack via a Xantech repeater system. About the only RF issue I have is when the cleaners might bump the stand where the blaster is...
BTW, I see you're in Palo Alto. I worked on a project at Stanford shopping center back in 2010, so was onsite a few times...you live in a great area!
still one of my favorite bumper stickers of all time...
FREE TIBET! *
* with purchase of equal or lesser Tibet
mak99 is offline
post #2072 of 2084 Old 01-23-2016, 07:17 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Seattle is great too.
RF is essential in our setup because everything except the Kuro is in another room.
htwaits is offline
post #2073 of 2084 Old 01-23-2016, 09:09 PM
mak99's Avatar
Quoted: 27 Post(s)
Maybe not this week - weather's been crap!
I remember your posts over in the 9G Elite thread - I'm also a 141 owner which is part of my everyday system, and even that is not used often enough (only ~4300 hours on the panel).
For the media room, I had thought about going full RF since all gear except the PJ is in another room, but instead installed the Xantech setup for quickest response. Glad to know your RF works well so I might have to try that option down the road...
FREE TIBET! *
mak99 is offline
post #2074 of 2084 Old 01-27-2016, 03:02 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
All of our components are on a rack behind the same wall where the TV is hung. I brought a IR blaster back through the wall and pasted it to the TV's receptor. I'm at the point where I don't mess with anything that works reasonably well.
htwaits is offline
post #2075 of 2084 Old 06-01-2016, 11:47 AM
davisnub's Avatar
Quoted: 135 Post(s)
the dimmer switch that you are using, is it currently dimming led or incandescent?
davisnub is offline
post #2076 of 2084 Old 06-20-2016, 09:15 PM
mak99's Avatar
Quoted: 27 Post(s)
Sorry for the late reply, haven't been online here for a bit...
Incandescent BR30's, unfortunately - which is what the IR switch was designed for. I tried using LED bulbs (six @ 13-watt ea) but they would flash, so no go there . I called Lutron and asked if they had any LED-compatible IR dimmers coming out but they indicated "no".
What I haven't tried is using a combo of incandescent and LEDs to see if that might work..might just give that a try. Of course since the media room lights are only on for maybe ten total minutes whenever I do use the media room (once/week at most), sneaking in a few LEDs probably won't make a noticeable dent in my electric bill...
FREE TIBET! *
mak99 is offline
post #2077 of 2084 Old 06-20-2016, 10:58 PM
JimShaw's Avatar
Quoted: 277 Post(s)
Liked: 296
I have a Lutron dimmer tied to a 7 watt LED in the ceiling that my wife uses as a reading light.
What I did to make it work correctly: In the attic I attached a 60 watt incandescent to the LED power line. When the LED comes on, so does the 60 watt in the attic. The LED works perfect and when I need an attic light, that also works.
I control it with my 1100
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 6 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Samsung UN78JS9500, mLG OLED55E6P
Oppo UHD-203 player, Denon 4311CI, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
post #2078 of 2084 Old 06-22-2016, 11:33 PM
mak99's Avatar
Quoted: 27 Post(s)
^^ Jim, interesting workaround! When I have some time I'll try a combo in my media room to see if that makes any difference...
Re: your attic light, just make sure your wife doesn't turn off her light while you're in the attic! I installed a separate circuit/outlet in the attic and installed a set of construction lights (100' long, 10 lights total) - talk about being the best-lit room in the house!
FREE TIBET! *
mak99 is offline
post #2079 of 2084 Old 10-11-2016, 10:52 PM
Liked: 0
Greeting all,
I have a Harmony 1100, has worked great for years, since I replace an earlier Logitech Model with this one. It is inoperable at the moment. I Had call TS they had me go thru all the Troubleshooting and had me twist the remote, and it lit up and started working as long as I had this twisted pressure applied.
I am a disabled vet, and had been hospitalized for a replacement for my Spinal Cord stimulator, and lost my contact information for this gentleman. He had suggested that the solder joints needed re-pointing.
I am looking to get this finished but have had no luck in locating him, or another to have this completed, I really want to get it back up and running.
Any replied and assistance would be greatly appreciated.
Best regards,
Ed Harry
Meadville PA
shadowtraker is offline
post #2080 of 2084 Old 10-11-2016, 11:27 PM
JimShaw's Avatar
Quoted: 277 Post(s)
Liked: 296
Contact "Q" at
info@harmonyremoterepair.com
Originally Posted by shadowtraker View Post
Greeting all,
Best regards,
Ed Harry
Meadville PA
JimShaw is offline
post #2081 of 2084 Old 11-25-2016, 03:35 PM
bxbigpipi's Avatar
Quoted: 53 Post(s)
Liked: 39
Still use mine too. Like others, prefer it to a regular remote.
bxbigpipi is offline
post #2082 of 2084 Old 12-29-2016, 05:59 AM
lalawyer's Avatar
Still use mine in two different homes. They both continue to work perfectly.
lalawyer is online now
post #2083 of 2084 Old 12-30-2016, 03:05 PM
Liked: 0
This is great information thanks!
julianw is offline
post #2084 of 2084 Old 02-07-2017, 10:07 AM
SoulOfUniverse's Avatar
Quoted: 117 Post(s)
Liked: 35
The owners, will it work with Lumagen Pro series? I know it supports Lumagen XD, but will it work the same with Lumagen Pro? As I'm looking to buy that one universal remote.
Video: OPPO UDP-203 -> Lumagen Radiance Pro 4444 -> JVC RS400 -> Elite Screen 135'' 16:9 1.1 Max White;
Audio: Sony BDV-n9100w
SoulOfUniverse is offline
Reply Remote Control Area
Directv , Harmony 1100 Remcontrol , remote control , repair advice , Sony
