Comcast DVR Remote codes needed for Samsung HT-Z310 Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-06-2009, 06:50 AM - Thread Starter
slvbeard's Avatar
I've got a Comcast DVR Remote, need codes for a Samsung HT-Z310 Home Theater. This one takes 5 digit codes, it's the one with the on demand button.
slvbeard is offline
post #2 of 14 Old 02-08-2009, 09:18 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Try 31295, 31500, 31495, 21932, 21940, 21979
mdavej is offline
post #3 of 14 Old 02-11-2009, 05:36 PM - Thread Starter
slvbeard's Avatar
I tried but none of those work either...
slvbeard is offline
post #4 of 14 Old 02-11-2009, 05:43 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
try the following Aud codes:
30286, 31199, 31295, or 31500
Try ALL keys, the volume keys my not work because of the volume lock.
Edmund is online now
post #5 of 14 Old 02-17-2009, 12:36 PM - Thread Starter
slvbeard's Avatar
Nope didn't work, still looking...
geneisaac likes this.
slvbeard is offline
post #6 of 14 Old 03-28-2009, 08:37 PM
alden8's Avatar
I have the same issue. I am unable to find any codes even with clever google search syntax. I hope somebody solves this annoying issue.
alden8 is offline
post #7 of 14 Old 06-16-2009, 02:26 PM
jamis0n's Avatar
Anyone have luck getting this programmed?
I'm hoping my X810T Soundbar will work with the same code.
jamis0n is offline
post #8 of 14 Old 01-21-2013, 08:46 AM
steve6458's Avatar
does anyone have Comcast DVR Remote codes needed for Samsung HT-Z310 Home Theater"
steve6458 is offline
post #9 of 14 Old 01-21-2013, 09:28 AM
mdavej's Avatar
Liked: 940
I don't think there is a code built into the comcast, but you can try these: 31295, 31495, 31500, 31868. If you have any success with those, the following EFC's should work. If not, you'll need a JP1.3 cable to load the codes. Warning: Spoiler! (Click to show)
Code:
Audio        00182
Cancel  00122
ChapterNext     00123
ChapterPrev     00251
Digest  00053
Dimmer  00245
DirectionDown   00120
DirectionLeft   00216
DirectionRight  00248
DirectionUp     00056
DiscSkip        00085
DspEq   00212
Eject   00149
Exit    00006
EzView  00186
FastForward     00136
Info    00214
InputAux        00121
InputDvd        00249
InputTuner      00057
Logo    00021
Menu    00150
Mute    00025
Pause   00187
Play    00187
PowerToggle     00185
PrologicEffect  00052
PrologicMode    00180
Remain  00181
Repeat  00198
Return  00244
Rewind  00132
SD/HD   00088
Select/Ok       00184
Sleep   00217
SlideMode       00250
Slow    00152
SoundEdit       00116
Step    00024
Stop    00059
Subtitle        00054
TestTone        00148
TuneDown        00091
TuneUp  00219
VolumeDown      00027
VolumeUp        00155
Zoom    00058
0       00090
1       00169
2       00167
3       00116
4       00024
5       00054
6       00148
7       00091
8       00219
9       00058
mdavej is offline
post #10 of 14 Old 01-22-2013, 05:25 PM
steve6458's Avatar
thanks, tried thm all but no luck. There is a code because all I did was exchange remotes wtith comcast as the volume button was not working good. The prvious comcast remote had the code and was working the unit fine for volume and power.
post #11 of 14 Old 01-22-2013, 07:51 PM
mdavej's Avatar
Liked: 940
In that case you can just do a code search on the remote. See the 9xx instructions in my wiki link.
mdavej is offline
post #12 of 14 Old 01-22-2013, 09:19 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
As mdavej says, most Samsung HTs can't be controlled by the Comcast remote. However, there are some DVD codes which may work.
20573, 21470 (Aiwa, device 102) Some Samsung HTs use these.
20715, 20744, 20820, 21044, 21075 (NECx2, device 5.5) DVD
3FingeredGlove is offline
post #13 of 14 Old 01-26-2013, 02:24 PM
ed1949's Avatar
Stop. The Comcast remote with the red OK/Select button and the five-digit codes will not control the Samsung Home Theater/Blu-Ray equipment. The red-button Comcast remote cannot send the needed NECx2 device 67.83 IR protocol/signals no matter what five-digit code you program into it. The best discussion of this issue is at http://www.hifi-remote.com/forums/viewtopic.php?t=14047 . You need one of the older gray-button, four-digit Comcast remotes, and you can go to your local Comcast store and try to get one. The alternate solution is to get a universal remote like a Logitech Harmony, which I had done until I discovered how to make a Comcast remote work.
I had a stroke of luck in that I had an infrequently-used TV and DVR downstairs where my adult children used to live, and after an extended, frustrating experience of trying to make the red-button remote work with the Samsung, giving up and buying the Harmony, I finally thought to go downstairs and check the remote, and it was the gray-button one! Without swapping the DVRs (with all the associated rewiring), I simply reprogrammed the red-button (five-digit) remote to control the Toshiba TV downstairs and programmed the gray-button (four-digit) remote for the Pioneer plasma screen and the Samsung Home Theater upstairs. Works perfectly! I didn’t have to change any of the DVR/cable box settings either place. Don’t forget that AFTER programming the Aux button for the Home Theater (code 1932) you must lock the volume control to the Aux device. Press Aux, hold Setup until Aux flashes twice, enter 9-9-3, then press Aux again. You should get a two flash response, and the Volume and Mute should now operate the Home Theater even if the remote is in Cable or TV mode. Don't forget, this only works with the gray-button Comcast remote.
ed1949 is offline
post #14 of 14 Old 05-29-2013, 10:32 AM
sammy hd's Avatar
I have the HT-D5300, Sammy HDTV and xfinity HD DVR. I used the samsung codes (20199 recommended) and while I can't turn on the HT-5300, the vol buttons do work the surround sound and the tv or all power buttons turn both the TV and HT-5300 off. Little bit of a pain. I'm looking at my upstairs surround sound where I use my Harmony one (keep it simple for wife & daughter) hope this helps
sammy hd is offline
Reply Remote Control Area
Onkyo Ht S5300 7 1 Channel Home Theater Receiver And Speaker Package With Ipod Dock Black
