MX 880 remote/computer problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-20-2009, 08:42 AM - Thread Starter
rblnr's Avatar
Quoted: 66 Post(s)
Liked: 38
My MX880 editor program all of a sudden doesn't connect up w/my remote. Checked cables, reloaded the program and the firmware, still nothing. Ideas anyone?
rblnr is offline
post #2 of 5 Old 02-20-2009, 05:15 PM
LessisNevermore's Avatar
I had this trouble too, I brought up the Windows task manager and killed off a few programs. I'm not sure exactly which program was the culprit, but I stopped any and all iPod related programs, and TVersity. That did the trick. I would think any program running that relies on a usb port would be fair game to try ending.
LessisNevermore is offline
post #3 of 5 Old 02-20-2009, 06:49 PM
Pete_P's Avatar
That sounds like a problem I had with a customers mx-810. If it's the same problem it's a driver issue. I think I may have had the same issue with the 880, but I cannot remember.
I received these instructions from URC, change 810 to 880 and it should work for you.
Open the editor and plug the MX-810 into your PC. Now, right click on My Computer and select Manage From your device manager, look for an unknown device (this is usually accompanied by a question mark or exclamation point). Right click on it and select update driver. After that select the option for Install from a list or specific location. Now navigate to this folder:
My Computer/Local Disk (C/Program Files/Universal Remote Control Inc./MX-810/Drivers/(Your Operating System)/x86
This will update the URC USB SYNC FW1 driver.
who ever said money can't buy love never bought a puppy.
Pete_P is offline
post #4 of 5 Old 05-16-2009, 09:34 PM
Roadbike100's Avatar
Where do you download the MX-880 editor?
Roadbike100 is offline
post #5 of 5 Old 05-18-2009, 12:17 PM
MikeSRC's Avatar
You must get the program from your dealer. None of the newer URC remotes (MX-6000, 980, 880 and MSC-400) have software available for public download.
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
Reply Remote Control Area
