Harmony for PS3 is here - AVS Forum | Home Theater Discussions And Reviews
post #1 of 104 Old 05-11-2009, 12:40 PM - Thread Starter
Ericdj's Avatar
Best Buy
Distributor: Logitech
Model: 943-000029
Sku: 9274714
Upc: 0-97855-05916-1
Street date: 05.31.09
Ericdj is offline
post #2 of 104 Old 05-11-2009, 01:29 PM
RYANtheTIGER's Avatar
Quoted: 288 Post(s)
Liked: 30
Is there a link for it?
RYANtheTIGER is online now
post #3 of 104 Old 05-11-2009, 04:50 PM
TedSeattle's Avatar
Quoted: 86 Post(s)
Liked: 203
TedSeattle is offline
post #4 of 104 Old 05-11-2009, 05:35 PM
Quoted: 288 Post(s)
Liked: 30
So the Harmony remotes only work with the PS3 if you have the adapter?
post #5 of 104 Old 05-11-2009, 07:07 PM
bairda's Avatar
You can get a Harmony to work with a PS3 but you will need an external bluetooth to IR remote (like the Nkyo Blu-Wave) to make it work. It works most of the time but it is clunky and doesn't give you some options, like using the PS button.
A direct bluetooth adapter for the Harmony will be great assuming it works right.
-Alex-
bairda is offline
post #6 of 104 Old 05-11-2009, 08:23 PM
Quoted: 288 Post(s)
Liked: 30
gotcha. why doesn't the ps3 just use IR? why make things difficult??
post #7 of 104 Old 05-12-2009, 12:59 AM
Darkneo's Avatar
Quoted: 18 Post(s)
Liked: 26
Ask Sony lol
Darkneo is offline
post #8 of 104 Old 05-12-2009, 03:52 AM
najaboy's Avatar
-Alex-
To correct and clarify, the Nkyo is not BT to IR. It is merely an IR remote and dongle that utilizes a usb port to provide limited control of the PS3. The commands are transmitted via the usb port and are not converted to DT packets.
Numerous IR to BT converters are already available that provide full control of the PS3 via IR remotes such as the Harmony. Logitech is only the latest player to the game. What they will have going for them, besides brand recognition, is the lowest overall price point at $59.99, save for perhaps the IR4PS3.
najaboy is offline
post #9 of 104 Old 05-12-2009, 04:47 AM
bairda's Avatar
I stand corrected!
-Alex-
bairda is offline
post #10 of 104 Old 05-12-2009, 05:35 AM
acegamer's Avatar
The logitech is up for sale on Amazon now!
logitech adapter
acegamer is offline
post #11 of 104 Old 05-12-2009, 06:28 AM
stephenju's Avatar
logitech adapter
Ordered one. Thanks.
stephenju is offline
post #12 of 104 Old 05-12-2009, 09:24 AM
coopasonic's Avatar
I read an article on engadget about this and they said it would only work for with harmony remotes. Is that even possible?
I have a harmony 550 I use in my family room and an URC MX-900 I use for my media room (where the PS3 is the BD player). If I programmed my 550 with the controls for the harmony ps3 adapter, I should be able to learn the commands on my MX-900, right?
coopasonic is offline
post #13 of 104 Old 05-12-2009, 09:37 AM
averse's Avatar
The logitech is up for sale on Amazon now! [IMG]http://www.*****************/trafficreport/img/3721/k08t1221bbuq/gdsmile.gif[/IMG]
logitech adapter
confirmed.
Visited the site.
Planning to have one.
averse is offline
post #14 of 104 Old 05-12-2009, 10:08 AM
chufly29's Avatar
the blog post states that it wasn't designed to work with other remotes, but didn't specifically say it won't work with other remotes (maybe it's Logitech's version of a disclaimer)
chufly29 is offline
post #15 of 104 Old 05-12-2009, 10:14 AM
bryansj's Avatar
Quoted: 1137 Post(s)
Liked: 561
I'm sure it just has unique IR codes already in the Harmony database. It is just a matter of either learning them from any Harmony remote or someone dumping the hex codes.
bryansj is online now
post #16 of 104 Old 05-12-2009, 11:49 AM
MikeSRC's Avatar
Which already has been done. Get them here.
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #17 of 104 Old 05-12-2009, 12:27 PM
focker240's Avatar
Ordered one as well. Thanks!
______________________
PSN: ShengLongDong
Xbox Live: ShengLongDong
focker240 is offline
post #18 of 104 Old 05-12-2009, 02:30 PM
Darkneo's Avatar
Quoted: 18 Post(s)
Liked: 26
Ordered
Darkneo is offline
post #19 of 104 Old 05-12-2009, 02:40 PM
MikeCandler's Avatar
Done ordered mine as well from Amazon...anyone think this will power on and off the Wii as well?? Would think so if not now moving forward it should.
MikeCandler is offline
post #20 of 104 Old 05-12-2009, 03:26 PM
chufly29's Avatar
I do not believe it will, the bluetooth commands are specific to the PS3 (I have no idea how that's possible, but that's what's in the blogpost on logitech)
here's the snippet:
Can I use it to control other components that use Bluetooth wireless technology, such as the Wii game console?
No - in a nutshell, the adapter speaks a Bluetooth language using hardware and software that is specific to PS3, in the same way that Sony's game controllers are specific to the PS3.
chufly29 is offline
post #21 of 104 Old 05-12-2009, 05:07 PM
cntr_ice_junkie's Avatar
So in looking at this, it appears that the Logitech one does not have a discrete off command that is working. Is there any solution out there that has discrete on/off commands? Even this option doesn't seem to have discrete commands but attempts to solve it by "power sensing".
http://www.schmartstuff.com/ps3ir1k.html
cntr_ice_junkie is offline
post #22 of 104 Old 05-13-2009, 02:57 AM
Murilo's Avatar
Quoted: 128 Post(s)
Liked: 31
Yea im about to pull the trigger on the schmart, the power sensing is a must, i constantly accidently turn the ps3 on when i put in a game instead of using the remote, and then it gets out of sync.
I dont see a power sensing cord, or an option how the harmony would accomplish this.
Looks like Im going to go with the schmart.
Unless someone can confirm the off button wont turn on the ps3, if its out of sync, but i dont know how this would be possible, since you need to hit the ps button to turn it on, and hit it to turn it off. Unless you had power sensing like schmart.
Murilo is offline
post #23 of 104 Old 05-13-2009, 07:57 AM
here's the snippet:
Hmm that's strange, you would think Logitech would have made it so it would work in any IR to BT application...huh odd to say the least.
post #24 of 104 Old 05-13-2009, 08:58 AM
paerley's Avatar
Bluetooth is just a wireless communication layer, like 802.11a/b/g/n are. There are a few pre-defined protocols that are supported(L2CAP is likely the one used in this case, with RFCOMM being runner up, and with BNEP and OBEX being the most common), but what is spoken using those is the 'magic bits'. Just because the remote is a bluetooth device, doesn't mean it has to speak some magic common language that all bluetooth devices agree on.
Think of bluetooth as the HDMI cable between your PS3 and your AVR. Bluetooth really only requires that the devices be able to detect that the other is there. There's no requirement that they be able to work with each other in any guaranteed way. Now with HDMI being a much more targeted spec, odds are VERY VERY high that 2 devices talking to each other over HDMI will be able to work together. Bluetooth, in contrast, is a very generic spec.
Anyways, where I was going with that...
The wii may use bluetooth, and the ps3 may use bluetooth, and both may have similar features, the only thing that their bluetooth implementations likely have in common are what they're used for.
paerley is offline
post #25 of 104 Old 05-13-2009, 10:14 AM
MikeSRC's Avatar
[quote=cntr_ice_junkie;16448420]So in looking at this, it appears that the Logitech one does not have a discrete off command that is working. Is there any solution out there that has discrete on/off commands? Even this option doesn't seem to have discrete commands but attempts to solve it by "power sensing".
There is no discrete off command for the PS3 to my knowledge. That's why it's either done with an "Off" macro (like I'm doing with my IR2BT) which is not reliable in all occasions, or by using power sensing (the better option).
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #26 of 104 Old 05-13-2009, 10:37 AM
So just to be clear, something like the PS3IR-1000 which supposedly has power sensing does offer a discrete on/off code even though the PS3 does not. It just uses power sensing to detect whether it really has to do the requested discrete action, otherwise it ignores it. Do I have that right?
Just want to make sure I got it 100% correct before dropping the extra cabbage for the more expensive option.
post #27 of 104 Old 05-13-2009, 11:16 AM
Quoted: 288 Post(s)
Liked: 30
So the adaptor sits somewhere, correct? Does that mean I can place my PS3 in one of the cabinets of my media stand and still be able to control it while watching movies??
post #28 of 104 Old 05-13-2009, 11:29 AM
bryansj's Avatar
Liked: 561
Yes, you just need line-of-sight to your IR to BT adapter.
The discrete code is still just a macro, but it is built into the IR to BT device and is triggered by a unique command from the remote. The sensing tells the device whether or not to transmit the macro.
post #29 of 104 Old 05-13-2009, 01:34 PM
T100's Avatar
Quoted: 25 Post(s)
I ordered one from logitech here's what there blog said http://blog.logitech.com/
T100 is offline
post #30 of 104 Old 05-13-2009, 03:30 PM
jonathanR's Avatar
jonathanR is offline
Reply Remote Control Area
