Remote that can has a timer program? (change to channel X at Y time) - for SA 8600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-18-2009, 06:40 AM - Thread Starter
scottydunlop's Avatar
Hi all,
Quick background - I'm moving temporarily into the Caribbean, and the cable system there is using antiquated equipment from the early 90s. Scientific Atlanta 8600/8610 boxes without timers and only RF in/out. I'm looking to use a DVR/DVD recorder to timeshift and need to find a way to change the set top box at X time to Y channel. (analog only).
I'm wondering if anyone here can recommend a remote, older or newer that can simply be set to change the channel at a specific time, and be able to learn/control the Scientific Atlanta 8600/8610 boxes.
Thanks in advance, it'll be a lifesaver,
--Scott
scottydunlop is offline
post #2 of 10 Old 05-18-2009, 02:22 PM
hoggy's Avatar
many dvd recorders have this, and it would probably be the best way to do what you describe
hoggy is offline
post #3 of 10 Old 05-18-2009, 04:10 PM
The Robman's Avatar
Quoted: 45 Post(s)
This remote might do the trick if it has a code for your box:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220296710336
You can look up the codes here:
http://support.radioshack.com/support_video/61534.htm
Later, Rob
Select a link for questions on: Remotes, JP1, JP1 Forums
I prefer emails to PMs, my email is rob1 (at) rockabilly (dot) net
The Robman is offline
post #4 of 10 Old 05-19-2009, 08:03 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 398
Get a recorder that comes with IR blaster which can control the cable box. No remote timer needed.
Foxbat121 is offline
post #5 of 10 Old 05-19-2009, 08:28 AM - Thread Starter
yes, if only it were so easy. The local cable co does not have a DVR, nor do they have a guide available... so yes, I could buy an old TiVO and manually record, but I have a box that can record the output on channel 3, I just need to change the STB channel. I think the sony touch remotes with macro timers will work.
post #6 of 10 Old 05-19-2009, 08:30 AM - Thread Starter
the radio shack remote looks like it could do the trick!
post #7 of 10 Old 05-19-2009, 09:17 AM - Thread Starter
looks like the rs only supports 1 event to be programmed at a time... pretty funny stuff!! any other options other than the sony? hard to imagine no other remotes that have timer programs... but I guess it's not really useful other than in such limited circumstances as I find myself LOL ;-)
post #8 of 10 Old 05-19-2009, 11:31 AM
The Robman's Avatar
Quoted: 45 Post(s)
The current Radio Shack 15-100 remote has timed macros, maybe that will work for you.
http://www.radioshack.com/search/index.jsp?kw=15-100
Later, Rob
post #9 of 10 Old 05-19-2009, 12:40 PM - Thread Starter
Yes, that looks like it could do the job. Does anyone know how many timer programs I can have in there? I downloaded the manual, and it doesn't describe how many timers can coexist at once.
post #10 of 10 Old 06-02-2009, 09:22 PM
The Robman's Avatar
Quoted: 45 Post(s)
IIRC, the timed events get stored as macros, so you should be able to store quite a few.
Later, Rob
Reply Remote Control Area
