Harmon Kardon AVR254 - How to use with Hotlink PRO?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-06-2009, 02:02 PM - Thread Starter
sendtoworthingt's Avatar
Hey folks, this forum has been invaluable to me, but I am having problems setting up my new AVR 254 with the Hotlink PRO IR repeater system.
??where's the IR sensor on the HK, and how do I get it to recognize the remote's signals??
So I have everything hooked up per instructions on the Hotlink PRO, and I have an emitter on front panel where the HK instruction say the IR remote sensor should be, but I can't get the HK to respond!!
The Hotlink system is working fine on my other 3 components (DVD, VCR, CD changer).
I spent an aweful lot of money on this hotlink pro system to be able to control the rest of my devices, and I hope I can get it to work with my HK.
I wonder if the HK remote operates on a different frequency that the Hotlink can't pick up, or does teh Hotlink send out IR signals through the emitter that is incompatible with the HK reciever??
Any ideas or help would be great!
sendtoworthingt is offline
post #2 of 4 Old 06-06-2009, 02:16 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Have you try swapping emitter known to be working with the other components. If swapping emitter works then one of your emitter is defective.
JChin is offline
post #3 of 4 Old 06-06-2009, 04:19 PM - Thread Starter
I had tried that, but still nothing.
Has anyone used an IR repeater system with the new HK recievers ... and does it work?
Is there something special with the HK AVR254 remote / sensor that makes it incompatible with the Hotlink pro?
Any replies would be great.
post #4 of 4 Old 06-06-2009, 04:30 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
May want to post this in the AVR254 Owners Thread also.
JChin is offline
Reply Remote Control Area
