Acoustic Research XSight Remote - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #451 of 1149 Old 01-16-2012, 05:32 PM
PTV Programmer's Avatar
Quoted: 321 Post(s)
Liked: 77
I have the Xsight 18 that I'm using with an IR system that consists of a plasma-friendly IR receiver by Xantech and a connecting block by SpeakerCraft with 6 IR emitters. Right now the system works very well. I've been considering getting the Nevo RF extender and going all RF, which means eliminating the need for the IR receiver. If there any performance/range/angle/reliability advantage to switching to RF?
PTV Programmer is offline
post #452 of 1149 Old 01-17-2012, 07:04 AM
Justind123's Avatar
Originally Posted by mdavej View Post
One For All, the maker of the Xsight and other UEI (Universal Electronics Inc.) remotes. Acoustic Research and Nevo are only brands.
Vortech, thanks for the battery info!
where can i buy one in the US market?
Justind123 is offline
post #453 of 1149 Old 01-17-2012, 07:50 AM
mdavej's Avatar
Quoted: 2131 Post(s)
Liked: 942
I don't know, but if you find one, please post back. I just use bravia-link for on/off/playback and a cheap nyko bluwave type device for everything else. Radio shack has one of THESE adapters for $2, but I've not tried it myself. If you get that one, you probably just set it up as a sony DVD player on the Xsight. FWIW, the harmony PS3 adapter also works fine with Xsight.
Although I haven't seen one in the US yet, HERE's a nice review of it and a SOURCE for our friends across the pond. It's 100% compatible with the Xsight family as well as other One-For-Alls.
Enabling HDMI contol on most of my devices has pretty much eliminated the need for the PS3 adapter in my case and made the macros on my remote much simpler.
mdavej is offline
post #454 of 1149 Old 01-17-2012, 08:55 AM
Justind123's Avatar
I was thinking of going with the Logitech adapter even though it costs more but it works with power up and power down.. which is a huge plus... for 2 dollars though.... ill prob pick one up and try it out.... my local shack has them..
post #455 of 1149 Old 01-17-2012, 05:17 PM
gtcharlie's Avatar
Quoted: 16 Post(s)
Can anyone confirm which replacement batteries work? I would love to pick up a couple of spares as I have really fallen in love with this remote.
gtcharlie is offline
post #456 of 1149 Old 01-17-2012, 09:57 PM
petrovy's Avatar
As previously mentioned, look for a bat replacement for Fuji NP 60.
The latest batteries have a higher capacity than the OEM, so your best (and probably cheapest) bet is to take the old battery (or even the RC) to Radio Shack and get an exact fit. A few months ago I found some Ultralast UL-NP60, 1100mAh/3.7V/Li-Ion, dirt cheap and perfect fit....should be longer lasting than the OEM.
all is good....LNT4671 1005/1001 SQ01 w/old PS3 80G,Oppo 83 & 2400ES into Mirage OS3FS
petrovy is offline
post #457 of 1149 Old 01-17-2012, 10:05 PM
Justind123's Avatar
Just got my arrx18g today... Tried to install software and when i launch it the site wont even come up.. Yes i have internet explorer and im running windows 7... If i copy the link into firefox it comes up.. Then copy the page link into internet explorer it wont let me sign up... The "next" buttons are just grayed out ... Pretty frustrated here.. Someone help please!.... I even tried enabling all of the active settings in internet explorer and it still wont work ....
post #458 of 1149 Old 01-18-2012, 01:11 AM
steve.black's Avatar
Can you elaborate a bit, please? I am deciding on the PS3 adapter to go with Xsight 18 and the Nevo RF base.
Where do you enable the HDMI control? I have my PS3 connected to Receiver and the Receiver to TV, both using HDMI. If I use HDMI control in Receiver, will it be Ok? Again this would only be good enough for starting/shutting down the PS3? Or how do you control the PS3 in absence of a IR to Bluetooth converter? Or are you using a normal PS3 controller/Sony remote for operational purpose?
steve.black is offline
post #459 of 1149 Old 01-18-2012, 04:19 AM
Sorry. I did not read your full post carefully enough. I got it now that you use nyko bluwave adapter. Thanks mdavej.
post #460 of 1149 Old 01-18-2012, 05:11 AM
Justind123's Avatar
??? anybody??
post #461 of 1149 Old 01-18-2012, 05:20 AM
Theresa's Avatar
Liked: 51
??? anybody??
On my system it requires IE, I use Firefox mainly.
Theresa is offline
post #462 of 1149 Old 01-18-2012, 06:14 AM
Justind123's Avatar
I have tried using both.... I am running windows 7 with IE 9....
post #463 of 1149 Old 01-18-2012, 08:15 AM
mdavej's Avatar
Liked: 942
Correct. But with HDMI control (bravia link) enabled on my tv and PS3, I can send transport commands (play, stop, etc.) from my sony tv device (the buttons that came from my original sony remote) and they are received by the tv and sent over HDMI to the PS3, hence no adapter required for that. HDMI control also sets the tv to the proper input and powers up the PS3. I can power off the PS3 remotely via HDMI as well, either by navigating or selecting Off from the Sync Menu. I have a 5 step macro to power off the PS3 and a 3 step macro to power it on. It will also automatically power off when the tv is turned off. I don't have an amp in the mix over HDMI, so I'm not sure how that would work in your case. The commands should just pass thru, but I'm not sure.
I've not tried it on Win7/IE9, but I'll give it a shot later and report back. Are you an admin on your PC or at least install the S/W as an admin? Did you install from HERE?
mdavej is offline
post #464 of 1149 Old 01-18-2012, 09:55 AM
Justind123's Avatar
Correct. But with HDMI control (bravia link) enabled on my tv and PS3, I can send transport commands (play, stop, etc.) from my sony tv device (the buttons that came from my original sony remote) and they are received by the tv and sent over HDMI to the PS3, hence no adapter required for that. HDMI control also sets the tv to the proper input when the PS3 is turned on. I don't have an amp in the mix over HDMI, so I'm not sure how that would work in your case. The commands should just pass thru, but I'm not sure.
update.... i just installed the CD on my work computer... (SHHHH) Windows 7 and IE 9 and everything worked great... so im guessing its the settings with my IE 9.. i did screen shots (SSSHHH) to compare and ill see how that goes...
I did not use that link... just the ones that are listed on the CD and controller itself... Still see if it works for yourself though... Im very curious as to what the hells wrong with my computer... HAHA
post #465 of 1149 Old 01-18-2012, 10:26 AM
petrovy's Avatar
The Nevo REX433 RF Extender should work very well with the ARRX18G, and it handles 6 devices (item ships w/6 long wire emitters). Reliability should be spot-on.
Since you state that your setup is working good, the only benefit of changing to RF is that you can hide the small Extender box in a cabinet and not have to point the RC towards the Receiver box, and may even be able to turn some equipment ON from another room (your performance may vary). Keep in mind that RF is also subject to interference from other 433MHz devices, but then again, IR may be subject to even more types of interference.
petrovy is offline
post #466 of 1149 Old 01-18-2012, 11:54 AM
Justind123's Avatar
I copied the settings from IE at work and made sure they were the exact same on my laptop... and now it works.... HMMMMMM
post #467 of 1149 Old 01-18-2012, 02:43 PM
gtcharlie's Avatar
Quoted: 16 Post(s)
Thanks much. A longer lasting battery would be a big bonus. Seems this remote spends more time in the charger than it should. I think I should probably disable the auto light sensor or shorten the time it stays lit but mw wife likes it so that isn't going to happen I guess.
post #468 of 1149 Old 01-18-2012, 03:17 PM
mdavej's Avatar
Liked: 942
Mine lasts at least a month between charges.
mdavej is offline
post #469 of 1149 Old 01-18-2012, 04:59 PM
gtcharlie's Avatar
Quoted: 16 Post(s)
Seriously?? Mine lasts maybe a week. Do you have the auto tilt enabled? I think my cats/dog/children are constantly passing by and activating the light which drains the battery. Or else my battery is defective. In any event I am getting a replacement (or 2). What would be a reasonable price for a backup battery?
post #470 of 1149 Old 01-18-2012, 05:51 PM
mdavej's Avatar
Liked: 942
Yep. Here are my settings:
- Brightness about 60%
- Timeout 10 sec
- Tilt On
mdavej is offline
post #471 of 1149 Old 01-18-2012, 07:23 PM
Quoted: 321 Post(s)
Liked: 77
Thanks, Petrovy! Good information.
post #472 of 1149 Old 01-19-2012, 06:57 AM
Justind123's Avatar
I have a few questions. When setting up the Logitech ps3 adapter what settings do i need to set in the controller for it to operate that device correctly and completely.
Also.... Where can i find the manual to get the remote to learn other remotes?
Also.... Am i capable of customizing the touch sccreen EX: I want to operate my receiver but the inputs that i use the most are scattered on different screens using the slide bar. Am i able to customize the touch screen to move all the inputs that i use the most onto 1 screen?
post #473 of 1149 Old 01-19-2012, 07:25 AM
mdavej's Avatar
Liked: 942
I've never read the manual (it's on the website). But on the remote, go to Settings, Learn, or do it from within the software. If you do it on the remote, be sure to exit the software completely and upload when you're done or your learns won't be saved.
Re-arranging is hard, but replacing is easy. So I recommend you go to Advanced in the software, and replace an existing button with the command you want. Then put the command you replaced on a screen at the end.
mdavej is offline
post #474 of 1149 Old 01-22-2012, 06:58 PM
StTMike's Avatar
Justin:
I think in IE you need to go and change the security settings to disable protected mode.
StTMike is offline
post #475 of 1149 Old 01-23-2012, 07:42 AM
Justind123's Avatar
Originally Posted by StTMike View Post
Justin:
I got it working thanks.... I havent had much time to play with it and program it... all i know is that it take much for time than an hour.... haha
post #476 of 1149 Old 01-24-2012, 07:31 AM
Justind123's Avatar
Anybody know how to correctly use the Auvio PS3 adapter with this remote... I got it working... kinda.... some of the buttons dont actually do what they are suppose to though...
Also Im hoping to be getting the Logitech ps3 adapter soon... is there any specifics I need to know for this module?
post #477 of 1149 Old 01-25-2012, 07:01 AM
Justind123's Avatar
Also does anybody know If the CISCO explorer 8652HDC has power on power off functionality....?
So far this is the only peice in my system that when i try to program with this remote that only has a "power fuction" So when i say goodbye and its already off (useing diff components on system" it turns on.....
post #478 of 1149 Old 01-25-2012, 07:38 AM
BPlayer's Avatar
It is like other SA and Cisco equipment and does not have discrete power on and power off codes.
The simple solution is to leave it on all the time as it only uses a very small amount of extra power between the on and off states. You may be able to create macro to manage the on and off states for your activities, and manually handle any out of sync instances.
BPlayer is offline
post #479 of 1149 Old 01-25-2012, 07:45 AM
Justind123's Avatar
DARN i was hoping that wasnt the answer....
post #480 of 1149 Old 01-25-2012, 07:46 AM
Justind123's Avatar
I know how to create an advanced activity... but what do the macros section do? I started creating an IR sequence but then i got to the remote and it wanted me to click on a key of control on the remote image? What is this and what am i suppose to do?
Reply Remote Control Area
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
