Acoustic Research XSight Remote - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #721 of 1200 Old 01-04-2014, 10:17 AM
curtlots's Avatar
Quoted: 94 Post(s)
Liked: 119
Thanks to all who contributed to this thread. It helped in my decision to go from my URC R40 remote with the Next Generation RF adapter to the XSight Touch remote with the AR RF extender. I'm really liking this remote, I think it truly combines the best of both worlds of the Logitech and URC style of remote.
I've had several URC remotes over the years, with the R40 being the latest. The R40 is a nice remote, but I really missed the RF capability I had with my previous MX850. I could never get the Next Generation RF adapter to work consistently.  This issue led me to the AR remote. I had considered it when I bought the R40, but it had quite a few negative reviews, most of which centered around the online programming. I didn't realize at the time, that those reviews were for the early versions of the online software. I haven't had any issues dealing with the programming. In fact I think it's very easy, especially in comparison to the URC software for programming their better remotes.
It's a shame AR no longer makes this remote! I hope I get several years of use out of this.
Cheers!
curtlots is offline
post #722 of 1200 Old 02-07-2014, 06:39 PM
RKCRLR's Avatar
Quoted: 12 Post(s)
I purchased a refurbished ARRE433B RF extender for use with my Xsight Touch remote. My Touch remote works fine with my Toshiba TV, Harmon Kardon AVR325 receiver, Panasonic DMP BD85, and Dish ViP622 DVR. The extender without the LED cables also works with them. However when I try to use the extender cables they only work with the Harmon Kardon receiver. The extender cables do not work with the Toshiba TV, Panasonic DMP BD85, and Dish ViP622 DVR. Has anyone successfully uses the extender and cables with a Toshiba TV, Panasonic DMP BD85, and Dish ViP622 DVR? I'm trying to find out if I have a defective unit or compatibility problem.
Sterling
Samsung UN65JS8500 TV
Samsung UBD-K8500 UHD Blu-Ray Player
Onkyo TX-NR646 Receiver
RKCRLR is offline
post #723 of 1200 Old 02-07-2014, 07:57 PM
dalto's Avatar
Quoted: 1239 Post(s)
Liked: 633
Where are you attaching the cables?
Try moving them around and see if that helps. Sometimes if you put them directly on top of the ir receiver they will not work.
dalto is offline
post #724 of 1200 Old 02-07-2014, 08:29 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 986
They may also be broken. They are very thin and fragile. Check for output with a digital camera. I have no issues with mine.
mdavej is offline
post #725 of 1200 Old 02-08-2014, 10:01 AM
RKCRLR's Avatar
Quoted: 12 Post(s)
I looked at them with a digital camera and they are emitting blue light. They flash brighter when they are sending a signal. I tried several positions and held them directly if front of the device IR window and they still didn't work. I suspect it is the extender unit itself since all of the extender cables would work with the receiver but none of them would work with the other devices. Also, it almost seemed like they were blocking the signals from the remote. I.e., sometimes I had to unplug the extender to get the remote to work normally.
RKCRLR is offline
post #726 of 1200 Old 02-08-2014, 02:06 PM
mdavej's Avatar
Liked: 986
Try moving the base far away from all your electronics. It seems to be very sensitive to interference. You shouldn't see any blue light unless you are pressing buttons on your remote.
mdavej is offline
post #727 of 1200 Old 02-08-2014, 02:34 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
Yes, it picking up RF interference and putting out junk IR signals.
Edmund is offline
post #728 of 1200 Old 02-08-2014, 05:16 PM
RKCRLR's Avatar
Quoted: 12 Post(s)
I tried moving it as far away from the devices as the extender cables would allow for testing. Same problem.
RKCRLR is offline
post #729 of 1200 Old 02-08-2014, 05:38 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
try removing the antenna? Keep the IR cables away from HDMI cables!
Edmund is offline
post #730 of 1200 Old 02-08-2014, 05:50 PM
RKCRLR's Avatar
Quoted: 12 Post(s)
I ran an extension cord so I could place the extender on a coffee table in front of my entertainment center as far away from the entertainment center as the extender cables would allow. There were no other cables around the extender other than the power cable to the extender. I tried the extender cables one at a time by holding them in different locations around the device IR windows. Each cable would operate my receiver but none of the other components. I've given up and sending the extender back for an exchange unit. Hopefully I don't have the same problem.
Thanks for your suggestions.
RKCRLR is offline
post #731 of 1200 Old 02-09-2014, 05:16 PM
RKCRLR's Avatar
Quoted: 12 Post(s)
While I'm playing around with this remote I thought I'd ask some more questions. Is there a way to create favorites for more than 1 device? I.e., I'd like to create a list of favorites for watching my Dish DVR and a list of favorites for radio stations. I was thinking about setting up profiles for both but it seems you have to choose one device or the other. Also, my tuner requires me to enter a "Direct" command prior to entering the radio station numbers. Is there a way to accomplish this using favorites? I saw there was an option for entering a command after entering the station number but not before. I realize I could make a macro for each station but I was looking for a simpler way.
RKCRLR is offline
post #732 of 1200 Old 02-24-2014, 06:03 PM
ncfoster's Avatar
I upgraded from a Tivo Premiere to a Tivo Roamio Pro, which does RF. I know that this remote will handle DirecTV HD DVR RF duty, but I am guessing that it would be a lot to ask for it to do Tivo Roamio RF, eh?
ncfoster is offline
post #733 of 1200 Old 02-24-2014, 06:51 PM
mdavej's Avatar
Liked: 986
It only does DirecTV RF. Sorry.
mdavej is offline
post #734 of 1200 Old 03-30-2014, 10:35 AM
Cakemeister's Avatar
Hello,
I have a ARRX18G and I can't get it to work right with my U-verse set top. My TV is a Panasonic 65VT60 and it has a "menu" button. The Uverse box is a VIP1200 and it also has a "menu" button. When I set up the ARRX18G to send Uverse commands, it sends most of them but the "Menu" and "Exit" buttons send VT60 commands instead of Uverse commands. This is a showstopper as it's necessary to get to the Uverse menu in order to watch recorded shows.
Any ideas/workarounds? I went to the website for Applied Research. They're supposed to have live online support but the link to it appears to be dead.
Cakemeister is offline
post #735 of 1200 Old 03-30-2014, 07:10 PM
mdavej's Avatar
Liked: 986
When you set up your activity you can pick which key groups are associated with which devices. Fix that, and you'll be in business.
mdavej is offline
post #736 of 1200 Old 04-20-2014, 08:14 AM
xnappo's Avatar
Quoted: 115 Post(s)
Liked: 107
Hi All,
Not sure if everyone is already aware, but the JP1 RM-IR software now has support for Xsight (in alpha testing - but pretty functional).
Come join us here if you are interested in helping test:
http://www.hifi-remote.com/forums/viewtopic.php?t=14804&postdays=0&postorder=asc&&start=0&sid=9567f6ed4e2ba670f6e5fe3eac8a4b19
xnappo
[EDIT] Oops - I see Dave already mentioned this last year - anyway there have been a lot of fixes in the past few weeks...
xnappo is online now
post #737 of 1200 Old 04-20-2014, 08:27 PM
Sac D's Avatar
I love these remotes, best overall functionality around. Unfortunately, as they age, a common problem begins to develop which inhibits their effectiveness. THE KEY CONTACTS begin to wear out!
I've already had to retire one and find a replacement, and the other two we have in use here are beginning to show the same symptoms. It's very sad.
Sac D is offline
post #738 of 1200 Old 04-21-2014, 08:45 AM
xnappo's Avatar
Quoted: 115 Post(s)
Liked: 107
Yeah, it was a very poor design choice to use the 'bubble' type of button here. Strange decision since UEI almost never used them in the past. These remotes are a massive pain to try to repair as well.
I am curious - it your 'List' button the first to go? I ask because it is right next to the power toggle and the USB board, and when I opened up a broken one there was obvious heat damage there.
xnappo
post #739 of 1200 Old 04-21-2014, 10:07 AM
curtlots's Avatar
Quoted: 94 Post(s)
Liked: 119
I really do like this remote, and agree that it's one of the most functional out there. You do confirm suspicions that I have had about the longevity of the buttons though. I consistently search for a good deal on ebay for a backup for just that reason.
curtlots is offline
post #740 of 1200 Old 04-21-2014, 11:40 AM
mdavej's Avatar
Liked: 986
I think they may have made some hardware change later that improved button life. A few years ago, I had one replaced under warrant that had some buttons wear out within the first year. The replacement has far outlasted the original.
Unfortunately, we don't have many other options. Harmony has the same kind of buttons that wear out pretty quickly too. Even URC has issues.
mdavej is offline
post #741 of 1200 Old 04-21-2014, 07:53 PM
petrovy's Avatar
Yes indeed. I have and use 3 of the AR18's, of which 2 have an issue with the (arrow) UP button. To alleviate this problem as much as possible, if the device permits, I put in an 'UP' button into the 'soft' keys.
all is good....LNT4671 1005/1001 SQ01 w/old PS3 80G,Oppo 83 & 2400ES into Mirage OS3FS
petrovy is offline
post #742 of 1200 Old 04-29-2014, 09:44 AM
xnappo's Avatar
Quoted: 115 Post(s)
Liked: 107
So would that be you selling 3 remotes, two with broken up buttons on eBay right now?
xnappo
post #743 of 1200 Old 05-02-2014, 05:29 PM
Sac D's Avatar
xnappo
The OK button usually is the first to have a problem with the ones we have used. Then the arrow keys UP, DOWN, etc.
Sac D is offline
post #744 of 1200 Old 05-17-2014, 08:44 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
I use my AARX18G with my WMC HTPC. I learned all the commands just fine. My problem is, I want a button to toggle WMC fullscreen/window mode (ALT+ENTER). But no such button exists on any WMC remote so I cannot learn it. How can I make a new button with keyboard action ALT+ENTER that will work with a windows RC6 IR receiver?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #745 of 1200 Old 05-18-2014, 03:05 PM
mdavej's Avatar
Liked: 986
mdavej is offline
post #746 of 1200 Old 05-19-2014, 10:43 PM
petrovy's Avatar
xnappo
Not me selling. I like my AR18's too much and will use them all until they totally self destruct, and then I will rip them apart and try to fix.
petrovy is offline
post #747 of 1200 Old 05-20-2014, 09:17 AM
xnappo's Avatar
Quoted: 115 Post(s)
Liked: 107
Well I guess this guy really proved your point that the up button fails first LOL:
http://www.ebay.com/itm/131177213596?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have have one I have taken apart that did not survive the process. I think now that I see how it goes together I could do better next time 'round. I can post some pics of how the tabs and cables work etc if you would like.
xnappo
post #748 of 1200 Old 06-01-2014, 06:57 PM
petrovy's Avatar
xnappo
If possible, pictures would be appreciated.
petrovy is offline
post #749 of 1200 Old 06-16-2014, 08:36 PM
SammyAVS's Avatar
I just picked up one of these (ARRX18G) without the charging cradle, and I was disappointed to discover that it would not charge the battery via the mini-USB. Can someone please tell me the specs of the power supply that this remote uses? I assume that the cradle is just a simple pass-through of the power supply connections. So knowing the power supply specs should enable me to contrive a way to charge it. Also, knowing which pad on the back of the remote is which polarity would help also.
Thanks in advance for your help!
SammyAVS is offline
post #750 of 1200 Old 06-17-2014, 05:14 AM
xnappo's Avatar
Quoted: 115 Post(s)
Liked: 107
I have an extra charger. Just PM me your address and I'll send it for just the shipping cost.
xnappo
Reply Remote Control Area
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
