Acoustic Research XSight Remote - Page 31 - AVS | Home Theater Discussions And Reviews
 17Likes
post #901 of 908 Old 02-22-2015, 06:30 PM
ejhuzy's Avatar
Quoted: 13 Post(s)
Originally Posted by Stereodude View Post
I'm trying to create an account at EZ-RC, but Create Account tells me my email is already registered and Logon Forgot Password tells me the email is NOT registered. Any ideas guys?
ejhuzy is online now
post #902 of 908 Old 02-22-2015, 06:48 PM
Sense/Net's Avatar
Liked: 0
Originally Posted by mdavej View Post
Never use EZ-RC off the CD. It's really, really, really out of date. If you have Win 8.1, you must do the hack. Just go back a few pages to my post about it. If you didn't do the hack already, your remote is probably stuck in upgrade mode.
Use internet explorer. Doesn't work with any other browser. Even then you might need to use a compatibility mode. The hardware might be fantastic, but software is an afterthought at best.
Sense/Net is offline
post #903 of 908 Old 02-22-2015, 08:56 PM
Stereodude's Avatar
Quoted: 833 Post(s)
Liked: 729
I think I had that problem when I was using Firefox. IE worked. You can configure a remote from scratch with RM-IR, but I was told to set it up as much as you can with EZ-RC first to speed thing along. I haven't yet fully set mine up. I need to spend the time and get it working. My Harmony 880 still works (with a firm press on a few of the buttons) so motivation has been a bit lacking.
Stereodude is offline
post #904 of 908 Old 02-23-2015, 10:37 AM
ejhuzy's Avatar
Quoted: 13 Post(s)
Thanks guys. I'll try IE (I had tried Firefox and Safari).
post #905 of 908 Unread Yesterday, 07:01 PM
ejhuzy's Avatar
Quoted: 13 Post(s)
Thanks for all the help guys. I was able to set up an account by using IE. Hard to believe in this day and age stuff is written to a specific browser.
Anyway, my next question is can I connect my XSight remote to my PC with my Harmony One remote? If not, where do I get one of these cables?
post #906 of 908 Unread Today, 09:35 AM
mdavej's Avatar
Quoted: 886 Post(s)
Liked: 518
Your question makes no sense. If you're asking if your Harmony cable will work, then I have no idea. Try it and see. If you're asking if your Harmony remote and Xsight remote can be connected together somehow or if one cold use the other's software, then no good would come of that.
Your Touch (18G) should have come with a cable. The Touch (18G) and Color (15G) use a Mini-B cable. The Plus (12G), uses a Micro-B. Both are very common. If you have a phone, camera or MP3 player, you probably already have the right cable. Otherwise they're about a buck on ebay and Monoprice, or a few bucks more at your local gas station or drug store.
mdavej is offline
post #907 of 908 Unread Today, 10:43 AM
ejhuzy's Avatar
Quoted: 13 Post(s)
Your question makes no sense. If you're asking if your Harmony cable will work, then I have no idea. Try it and see. Need to know what model Xsight to tell you what cable to buy.
Sorry for the newbie questions. I bought this remote used and it didn't come with a cable. The model is the AARX18G. The one that supports 18 devices.
Thanks for the help.
post #908 of 908 Unread Today, 10:47 AM
mdavej's Avatar
Quoted: 886 Post(s)
Liked: 518
I hope it at least came with a charging base. See my edited post above.
mdavej is offline
Reply Remote Control Area
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
