Acoustic Research XSight Remote - Page 33 - AVS | Home Theater Discussions And Reviews
Old 04-04-2015, 09:11 AM
mdavej's Avatar
Quoted: 1108 Post(s)
Liked: 601
Motion not adjustable. It's just a physical switch.
Volume punch thru is done by either of 2 ways, Vol device selected during activity setup or globally on the remote itself.
mdavej is offline
Old 04-04-2015, 11:33 AM
Quoted: 26 Post(s)
Liked: 1
I did it thru ezrc. I will be working thru the software a bit more. I know some info about each program. I started with ezrc because its the same one I needed for the firmware update and at that point I was struggling to get it set. In the long run I believe the rm software would be best for 2 reasons; one I hate ie and 2 I would hate to start and get the rug pulled from under me.
So lets say I start with ezrc and get it all set, then they pull it, do I have to start over?
miyanc is offline
Old 04-04-2015, 03:36 PM
mdavej's Avatar
Liked: 601
Nope. You can use either any time with the same config.
mdavej is offline
Old 04-07-2015, 10:05 AM
Quoted: 26 Post(s)
Liked: 1
I noticed you dropped the jp1 links.
miyanc is offline
Old 04-07-2015, 11:38 AM
mdavej's Avatar
Liked: 601
My signature hasn't changed. Must be a new bug in the forum software. Here's the Xsight link again, if you need it.
http://www.hifi-remote.com/forums/viewtopic.php?t=14804
EDIT: Looks like the Show Signature option gets turned off at random in some old posts.
mdavej is offline
Old 04-07-2015, 06:08 PM
Quoted: 26 Post(s)
Liked: 1
Np, I should have saved the links but know I could find it under you.
miyanc is offline
Old 04-08-2015, 01:35 PM
PhilM's Avatar
I've had an Xsight Touch for a number of years. The select, up and left buttons stopped working a while back so I reassigned them. Would it be possible to transplant the button board from a cheapo chinese arrx15/xsight color/nevo c2 ? Anyone take one apart?
PhilM is offline
Old 04-08-2015, 02:14 PM
xnappo's Avatar
Quoted: 35 Post(s)
Liked: 56
They are really hard to open. I tried on one and broke it...
xnappo is offline
Old 04-19-2015, 09:53 AM
jdmst71's Avatar
Help! I picked up one of these used off ebay. When I connect it the PC via USB nothing happens. It doesn't show up in device manager at all. No ding sound indicating something connected. The software icon stays red. I tried in a couple of Pc's with Windows 7 and 8 and no luck. Am I missing something or is the remote broken? It didn't come with a mini USB so I tried 2 different ones I have. The remote says charging when the USB is connected to the pc the same as if it's in a cradle. Any advice at all is greatly appreciated.
Sent from my VS980 4G using Tapatalk
jdmst71 is offline
Old 04-20-2015, 07:38 AM
mdavej's Avatar
Liked: 601
Could take a few minutes for Win 7/8 to find drivers an load them, at least the first time you connect, so be patient and try one more time. Win 8 requires the registry fix in my info link. Any mini USB cable should work. If the battery is dead, give it a full charge before you try again.
Does the remote function otherwise? You can do a full setup (besides activities and macros) on the remote itself.
mdavej is offline
Old 04-20-2015, 12:20 PM
Nodscene's Avatar
Quoted: 86 Post(s)
Just wanted to report that I finally got the remotes in. Wow, they are a lot bigger (in a good way) and nicer than I expected. I'm seriously debating buying another one so I'll have 2 as spare haha. I can see why it was a $150 remote at one time.
Edit: I've managed to mostly program one of the remotes. Thankfully it has everything other than my PT-7030. Now just need to figure out what to do with that PDF file mdavej was kind enough to supply to me. In some instances I also need to figure out what button does what on each device as it's not always setup logically. I'm sure if i learned the JP1 stuff more I could remap some of the buttons so it makes proper sense haha. It's a little intimidating I must say and I'm not sure how much time I want to devote to programming a remote I spend all week working on computers and software so doing more at home is a little tiresome. Maybe it won't be too bad.
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
Old 04-20-2015, 04:29 PM
jdmst71's Avatar
Mdave, My remote seems to function otherwise besides the macros that need the computer. One weird thing was a factory reset didn't fully reset the remote but kept the previous macro like play wii. Should it say charging when connecting to a pc?
I reset the remote fully by getting into the reset screen and typing a couple numbers that I found in a search. Windows isn't looking for drivers or doing anything when I plug this remote in. Not the usual pop up and driver search. No idea why. Any other thoughts?
jdmst71 is offline
Old 04-20-2015, 04:32 PM
xnappo's Avatar
Quoted: 35 Post(s)
Liked: 56
You can do a more complete factory reset by going to the reset screen, hit the button once, then type '981' and it will change to a 'Factory Reset' button.
Though... Not sure it will help..
xnappo is offline
Old 04-21-2015, 07:55 AM
mdavej's Avatar
Liked: 601
I think I would ask for a replacement. It obviously worked for the previous owner at some point (hence the Play Wii activity's existence), but isn't working now. Yet another USB cable might do the trick, but besides that, seems to be defective IMO. I don't remember if mine says charging or not when connected, I'll have to check.
mdavej is offline
Old 04-21-2015, 08:50 AM
twarren's Avatar
Quoted: 13 Post(s)
does the software icon on the desktop connect properly to the website? i.e. without the remote connected to pc if you click on the desktop icon does it go to the website and let you log in?
(Also, you might try downloading and running the open source configuration tools to see if they will connect to the remote, look at http://www.hifi-remote.com/forums/viewtopic.php?t=14804 for info on this)
twarren is offline
Old 04-21-2015, 05:27 PM
jdmst71's Avatar
Thanks for all the help. I did download the open source files previously in preparation for the remote programming. Also did the 981 facotry reset and that worked to reset but didnt help my connection problem. I plugged into 2 xp machines at work and it didnt register there either for a usb device being plugged in. I love the feel of the remote and advanced programming so i will try to get another one.
Thanks, John
Sent from my VK810 4G using Tapatalk
jdmst71 is offline
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
