Acoustic Research XSight Remote - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #991 of 995 Old 08-21-2015, 06:57 AM
xnappo's Avatar
Quoted: 47 Post(s)
Liked: 60
Dave - on this topic I have some Nevo C3s as 'backups' that I haven't used much. Have you had any problems loading a Touch image into the C3? It seems to work fine even though it complains the IDs do not match, but I haven't done this long term.
xnappo is offline
post #992 of 995 Old 08-21-2015, 08:21 AM
mdavej's Avatar
Quoted: 1385 Post(s)
Liked: 685
As long as it runs, you should be ok. I don't think I have any C3's myself, only C2's. But I haven't seen any differences between those and the Color. One issue I had with my Nevo's was that they needed a firmware update from EZ-RC to work properly with RM, otherwise some strange things would happen, mainly related to the "Assist" buttons.
mdavej is offline
post #993 of 995 Old 08-21-2015, 09:21 AM
xnappo's Avatar
Quoted: 47 Post(s)
Liked: 60
Yep - in general even if you are going to use RemoteMaster you should connect once to EZ-RC to get the latest firmware.
xnappo is offline
post #994 of 995 Old 08-22-2015, 10:22 AM
Drakul's Avatar
Alright it's pay day so I ordered the Touch with the extender. Wish me luck!
Drakul is offline
post #995 of 995 Old Today, 06:27 PM
mdavej's Avatar
Liked: 685
mdavej is offline
Reply Remote Control Area
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
