Acoustic Research XSight Remote - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1051 of 1057 Old 02-01-2016, 04:53 PM
mdavej's Avatar
Quoted: 1766 Post(s)
Liked: 817
You asked if it still worked. It does. I agree with Ed that it is no longer "supported".
I just created a new account myself and immediately received an e-mail confirmation from admin@ez-rc.com. So check your spam folder or try again, in IE. Your login may even work without ever following the confirmation link.
mdavej is offline
post #1052 of 1057 Old 02-01-2016, 10:59 PM
CEDTV1999's Avatar
Thanks for the confirmation that the e-mail notification system works. I'm in using another e-mail address I did check the spam bucket.
Carl
CEDTV1999 is offline
post #1053 of 1057 Old 02-05-2016, 02:57 PM
Dre325's Avatar
Quoted: 57 Post(s)
Xsight Touch
I picked up a Touch (18g) today, and now need to grab the RF base. I'm a bit worried about getting the software to work with the hardware with the need to update registry settings and use old IE emulation modes, but hopefully I can figure it all out :-). Thanks to those in this thread for the info on these remotes. Saved me a lot of money over the RF setups I had quoted to me by 3 different AV installers which ranged from $500 to over $1000 all in for the URC brand remotes. On top of it, I'll only be into this for about what it would have cost to have my non-RF Harmony One repaired! I just moved my gear into a cabinet and needed RF anyway.
Edit: For the RF bases, I assume the different versions (Nevo, AR) are both compatible with any of the versions of the touch remote (Nevo C3, ARRX18G). Is that correct?
Dre325 is offline
post #1054 of 1057 Old 02-05-2016, 06:16 PM
quamosa's Avatar
Quoted: 61 Post(s)
Liked: 54
I believe the C3 base and 18G base are the same just with different branding. However I'm not sure why Nevo C3 prices on eBay are through the roof. I would guess they would run about the same cost as a comparable 18G.
Sent from my XT1254 using Tapatalk
My First Build Ever in progress
quamosa is offline
post #1055 of 1057 Old 02-05-2016, 06:32 PM
mdavej's Avatar
Liked: 817
Correct, identical and compatible with both. Look for ARRE433B or REX-433.
mdavej is offline
post #1056 of 1057 Old Yesterday, 12:56 AM
Dre325's Avatar
Quoted: 57 Post(s)
Thanks for the help, guys. Much appreciated!
Dre325 is offline
post #1057 of 1057 Old Today, 08:10 AM
hammerdwn's Avatar
Quoted: 124 Post(s)
Liked: 44
Got a new remote. Have 2 ARRX18G remotes for sale:
1. EXCELLENT condition FULL Package with RF base, blasters, charging cradle, high gain RF antenna. (this remote sat in drawer as spare)
2. Heavily used remote and charging cradle only.
SEE AVS Classified > Accessories section or PM
hammerdwn is online now
Reply Remote Control Area
Acoustic Research , Harmony 1100 Remcontrol , Remotes And Controllers
