Logitech support for the Harmony 1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-07-2009, 03:48 PM - Thread Starter
JOMAST's Avatar
Hi,
I'm thinking of buying a harmony 1000 but are new released devices still supported by the hamony 1000? Where can i check witch devices are supported by the harmony 1000? On the logitech site there is only such a page for the harmony 1100. Thanks
JOMAST is offline
post #2 of 10 Old 08-08-2009, 12:09 PM
StevenZ's Avatar
Originally Posted by JOMAST View Post
...are new released devices still supported by the hamony 1000? Where can i check witch devices are supported by the harmony 1000?
Harmony's IR database is shared across all of their remotes, so when a new device's code gets added, the 1000 should have access to it. You used to be able to (maybe you still can) test-drive a Harmony from their website, by setting up an account. That should confirm that your devices are all covered. Even if they're not, the remote can learn new codes.
All that having been said, and even though I've been a Harmony fan for years, IMO the 1000 was the worst remote they ever put out. Touchscreen seems cool, but it becomes a pain to look at it to find the right place to poke it, while you're looking at the TV screen to see the results of play/pause/skip/rewind.
You might also check out the long thread on the 1000, especially the posts from #214 onward (when the runaway-volume problems and remote-freeze complaints started surfacing).
StevenZ is offline
post #3 of 10 Old 08-12-2009, 11:55 AM - Thread Starter
JOMAST's Avatar
Thanks Steven
JOMAST is offline
post #4 of 10 Old 08-15-2012, 05:44 PM
taxman48's Avatar
Quoted: 304 Post(s)
Liked: 297
I have a Sony mega changer that I am not satisfied with the controls on the 1000. I do not have the remote, should I delete the activity and re install the activity? Specifically , I cant put in a # disc and go to it.. thanks in advance, otherwise a great remote..
taxman48 is offline
post #5 of 10 Old 08-21-2012, 06:52 AM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I have done this several times. You have to manually assign the correct buttons to make this work. Use your original remote and figure out the process to do what you want, then assign the buttons that you need. It's usually something like this.
DISC / (Disc #) / ENTER <- In this example you would add "DISC" to one of the buttons in your activity.
Dropkick Murphy is offline
post #6 of 10 Old 08-25-2012, 02:53 PM
taxman48's Avatar
Quoted: 304 Post(s)
Liked: 297
thanks for the reply, but as I posted, I don't have the original remote. How do I program a button to go to disc #, which I can't do now? thanks in advance
taxman48 is offline
post #7 of 10 Old 08-26-2012, 07:09 AM
Quoted: 71 Post(s)
Liked: 89
The buttons you need should be in the Harmony database, you just have to assign them properly. With your Harmony remote go to "devices" page and choose your CD jukebox. Look for a button called "Disc", or maybe "Program". Press that button and then type in a disc number, then "enter". If that works then you just need to add those buttons to your activity.
post #8 of 10 Old 12-17-2012, 01:57 PM
kahlilj's Avatar
Does anyone know if the Harmony 1000 sends RF signals along with IR? Also does it need additional device like the RF extenders in order to work?
kahlilj is offline
post #9 of 10 Old 10-27-2013, 08:35 AM
taxman48's Avatar
Quoted: 304 Post(s)
Liked: 297
just got a pair of monoblock amps and would like for the Harmony 1000 to turn them on . How do I go about programming the remote? thanks in advance..
figured out that you have to set up each source and turn on trigger in AVR
taxman48 is offline
post #10 of 10 Old 03-12-2015, 10:19 AM
taxman48's Avatar
Quoted: 304 Post(s)
Liked: 297
I have the 1000 and enjoy every minute of it. I would like to listen to Pandora from computer to reciver via optical. How do I setup Harmony for that activity? It is not going to turn on computer but I need a command to put AVR on using DVR 2 input.. thanks in advance..
taxman48 is offline
Reply Remote Control Area
Logitech Harmony 1000 Advanced Universal Remote Silver , Logitech , Harmony 1100 Remcontrol
