Official Logitech Harmony 900 thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #361 of 2883 Old 09-02-2009, 08:07 AM
Stephen Hopkins's Avatar
Originally Posted by citico View Post
You could try this also:
http://www.radioshack.com/product/in...ductId=2102949
I'll probably end up using 3.5mm mono cables and some combination of 2.5mm-to-3.5mm adapters. I'll see what The Shack here in town has, but I'm going to have to order the emitters anyway, so it'll probably be cheaper to order the cables/adapters as well.
Originally Posted by Wannabe Actuary View Post
more than likely yes it will be cheaper.
however, my experience (from what I've seen posted mostly) is that the specs on all the logitech blasters/extenders are that they are 'mono' connections. sometimes stereo cables work, sometimes mono cables work...it almost seems hit or miss.
depending on the cost difference, it might be worth paying a little bit more (I think if they charge any more than $30 they're crazy - of course I'm assuming it'll basically be just some small cables/blaster tips) just to KNOW that it will work without the hassle of testing various cable/adapter combinations
I think knowing exactly what it is will make a difference. If it's a 2 or 3 tip eye style emitter and goes for $30, I might consider it for my devices that don't have wired IR connections and experiment with cables/adapters for those with wired IR inputs. If it's a 6 eye emitter for $30 - $40, I'll jump right on it and call it a day.
Knowing exactly what it actually is and the time frame will be the determining factors... I'll probably head off to the shack and save my receipts, but if I get something working before the Logitech solution is released, that's a sale they lost for dragging their feet. I can't imagine why they wouldn't have such a product ready at launch... did they not expect that MANY of the people buying 900s would have racks and gear with wired IR capabilities?
Stephen Hopkins is offline
post #362 of 2883 Old 09-02-2009, 08:28 AM
citico's Avatar
This is the cable I wanted to post:
http://www.radioshack.com/product/in...ductId=2102950
ED
citico is offline
post #363 of 2883 Old 09-02-2009, 08:41 AM
Ya, I'll probably use something like that, or build them so I can have custom lengths (I may need to place a PE order anyway).
post #364 of 2883 Old 09-02-2009, 10:02 AM
Wannabe Actuary's Avatar
sounds like a plan...
logitech told us they hoped to have it ready for the release of the 900...
guess that didn't happen
Wannabe Actuary is offline
post #365 of 2883 Old 09-03-2009, 11:14 AM
audiomax's Avatar
Originally Posted by waltzonice View Post
This reviewer claims that he's only getting about a 20 feet range even though the manual indicates about 100 ft.
http://www.crunchgear.com/2009/08/31...versal-remote/
To all of those who already have the 900 - Is the RF range a problem? I will need to penetrate a standard wood construction exterior wall with 6 in studs, at a range of around 25 ft.
Hard to imagine they would downgrade the RF strength of a $400 remote compared to their other remotes.
Thanks for any info.
audiomax is offline
post #366 of 2883 Old 09-03-2009, 11:26 AM
it's a different rf protocol. I go through two sheetrock walls at about 25 feet with no issues
beyond that it can be hit or miss
post #367 of 2883 Old 09-03-2009, 11:32 AM
Sorry, I can't help regarding range... I go through 1 sheetrock wall and 1 MDF cabinet at about 10'. I tried two floors directly below (about 20', through plywood decking and Berber carpet) and it worked well enough, though a few commands were missed here and there.
post #368 of 2883 Old 09-03-2009, 02:23 PM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
I tested my 900 and Blasters from outside, 40' away through a 8" Stucco wall and 2 interior sheet rock walls and was able to control eveyrthing without any problems
rehaz1 is offline
post #369 of 2883 Old 09-03-2009, 02:46 PM
whodean's Avatar
Could someone direct me to a cable appropriate to go from the 900's blaster's IR port to an ATON DLA6 which uses a 3.5mm mono plug?
whodean is offline
post #370 of 2883 Old 09-03-2009, 03:55 PM
I'm going to be trying a 2.5mm to 3.5mm mono adapter and 3.5mm mono plug... I'll report back (probably over the weekend) on how/if it works.
post #371 of 2883 Old 09-03-2009, 04:06 PM
just an FYI, the newly released harmony 700 uses a different operating platform and supports sequences...be sure to sign the petition on the logitech forums to get sequences on the 900
post #372 of 2883 Old 09-03-2009, 05:25 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
WOW they really know how to tick of customers that are willing to pay more.
I am looking at IR solutions right now instead and if I find what I like then I will return the 900. It just isn't worth that much extra money if it doesn't have all other features plus some...........
mhdiab is offline
post #373 of 2883 Old 09-03-2009, 07:31 PM
for me, the sleep feature makes the 900 a perfect bedroom remote
granted I beta tested it and I'm not sure I would pay 400 for a bedroom remote, but I would pay 300 or so for it
it's a shame, I was told a while back that it was going to go out with an MSRP less than what it did go out with...oh well
when you say you're looking for IR solutions, I assume you mean IR extender/repeater so that you can use the One like a 900, right?
if so, send me a PM when you get a chance, I don't want to "dirty" up this thread too much, but I have an idea for you
post #374 of 2883 Old 09-03-2009, 07:36 PM
whodean's Avatar
Cool, thanks Stephen.
whodean is offline
post #375 of 2883 Old 09-04-2009, 08:19 AM
mcdj's Avatar
Originally Posted by Taank View Post
Yes, the interface is extremely sluggish compared to the One. I really hope this is fixed, because so far everything else is great. The page transition is unbearably slow for having shelled out $400. When you hit a button to switch page, the screen dims, then switches slowly, then brightens, and its done. Each step feels drawn out.
No yellow tint here though.
So far only two of us with sluggish screens? Kinda makes me wonder if I have a dud, though the slowness feels software based to me. I guess it could be a faulty processor.
Any other 900 owners who own/owned the One care to chime in before my BestBuy return period is up?
mcdj is offline
post #376 of 2883 Old 09-04-2009, 09:06 AM
ZenithPete's Avatar
I'm pretty sure they all are more sluggish than the harmony one. I still have my one here to compare. But maybe yours is worse because it doesn't really bother me much even when scrolling through multiple pages. I think it's because Im not that used to using touchscreens yet, and by the time I'm ready to press again it's already loaded the next screen.
I think it's just the price we pay for the fancier screen transitions than the harmony one....if you could turn off the transitions maybe it would be faster.
ZenithPete is offline
post #377 of 2883 Old 09-04-2009, 12:09 PM
nandopr's Avatar
Quoted: 98 Post(s)
I upgraded from the "one". And yes, it is a little bit sluggish compared to the "one". I exchanged it just to have "peace of mind". The new one behaves the same.
Not really a big deal for me but if you want to be sure go to BB and exchange it.
nandopr is offline
post #378 of 2883 Old 09-04-2009, 03:48 PM
APerfect10's Avatar
Originally Posted by squareeyes View Post
I know not everyone uses favorites, but now that the remote is shipping I thought I'd repost that I'm taking requests for the 900 icons. The beta sets are currently available at [removed] I'll gladly add to those any new channels.
,R
I would like to see MASN, MASN2, and MASN HD please Donation will follow...
masnsports.com
Best regards,
Derek
APerfect10 is offline
post #379 of 2883 Old 09-04-2009, 09:22 PM
squareeyes's Avatar
masn has been made and is now up for all remotes.
,r
follow icon updates, av & remote info on facebook and twitter.
http://www.iconharmony.com
squareeyes is offline
post #380 of 2883 Old 09-04-2009, 10:10 PM
joe221's Avatar
Quoted: 29 Post(s)
I also want to again call attention to that vewwy wittle "click here" under squareeyes signature. He's almost at 50%, which you will understand if you "click there".
Joe in West Los Angeles, CA
joe221 is offline
post #381 of 2883 Old 09-05-2009, 01:16 AM
TheRatPatrol's Avatar
Quoted: 67 Post(s)
Liked: 59
Wannabe Actuary, hows the petition going?
it can NOT control any proprietary RF devices.
Do you think this could change in the future? Since RF remotes are already sending out an RF signal, how hard would it be for them to work with proprietary RF devices? Is it a matter a getting the correct RF frequency, could this be updated via a firmware/software update, or could they make an adapter like they did for the PS3?
TheRatPatrol is offline
post #382 of 2883 Old 09-05-2009, 02:05 AM
datdude's Avatar
Originally Posted by bryansj View Post
The Harmony is not the limiting factor here. You need to find an IR receiver that will do what you need. Any universal IR remote will be able to control an IR receiver, but if your IR receiver is limited in its abilities then the 900 isn't going to fix it.
I'd stay away from any iMon IR solution and look into a USB-UIRT and use EventGhost or any EventGhost compatible MCE IR receiver.
Ok, so I got the 900, the USB-Uirt and instaled the driver and Eventghost.
I chose the USB-URIT device from the Logitech Remote Software interface, but I can't get it to do anything. When I set it up and it askes me for the Power settings, not options are listed. I don't have a an IR remote to control the USB-UIRT to learn IR commands, so how do I get it to do something (anything) on my PC?
datdude is offline
post #383 of 2883 Old 09-05-2009, 05:51 AM
Taank's Avatar
I think you're right about it being the price of having a fancier screen. I may be alone here, but I wish it had the old screen and faster transitions. The screen upgrade isn't that spectacular to have to sacrifice zippyness. It's like comparing Vista to XP. Vista may have some visual bells and whistles... but the slighly sluggish feeling that comes along with it makes you glady want to "downgrade" to XP and have your fast OS back.
Honestly, there is something to be said for how the old screen looks anyway. In this forum this is probably blasphemy, but I don't need buttons on my remote control to be in like HD resolution. Solid color text on solid color background button, that is easy to read, worked for me.
Taank is offline
post #384 of 2883 Old 09-05-2009, 06:40 AM
jalyst's Avatar
Hmm this sound like a better way to go overall than the 900.
Id be interested in this too; if you got a minute feel free to PM me too!
jalyst is offline
post #385 of 2883 Old 09-05-2009, 07:06 AM
bryansj's Avatar
Quoted: 1134 Post(s)
Liked: 560
With Eventghost you can just pick any remote from the Logitech profile such as an early 80s model VCR. The USB-UIRT will receive the signal and Eventghost will map it to the command of your choice. Hit Power on the remote and tell Eventghost to map it as Power. You can even map Record on the remote to do Eject on the PC. I assume the USB-UIRT entry in the Logitech software is just some sort of remote with a lot of commands. When it asks for the power button just pick something and map it to power in Eventghost.
bryansj is online now
post #386 of 2883 Old 09-05-2009, 07:10 AM
bryansj's Avatar
Liked: 560
This will not happen, especially with a Logitech remote. The closest you can get is using the Z-wave built into the 890 to control other Z-wave devices. When shopping for things with remote controls it is best to avoid the RF solutions if you plan on integrating them with a universal remote. My gas logs are RF controlled and I would love to have those in my 890, but it isn't going to happen.
post #387 of 2883 Old 09-05-2009, 08:05 AM
won't happen
the licensing fees for each proprietary rf signal that they would need to get would cost too much
unless you don't mind paying 4 digits for a remote
post #388 of 2883 Old 09-05-2009, 08:51 AM
APerfect10's Avatar
,r
Wow, you rock! I'm going to send over a donation right away.
Thanks again...
-Derek
post #389 of 2883 Old 09-05-2009, 08:55 AM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
I don't see that ever happening as each proprietary RF device operates on a different frequency, you can have 5 RF devices all the same make and model and each can only be controlled by it's own remote. If they could be controlled by the same remote, if you turned one on all of them would turn on at the same time.
rehaz1 is offline
post #390 of 2883 Old 09-05-2009, 09:28 AM
Quoted: 67 Post(s)
Liked: 59
won't happen
But technology wise, it could be done, right? If each device operates on its own RF frequency, could that frequency be uploaded into the remote via a software upgrade or is that more of a hardware thing?
You're right though, it probably will never happen, but this is more of a curiosity question if anything.
Reply Remote Control Area
