I've never used the RF Harmonys, but just a question about the new 900 series....
Each "Main Blaster" can only be synced to one remote? Or can multiple 900 remotes be synced to it (not really wanting the remotes to be in sync, just use the same RF "Main Blaster").
Originally Posted by squareeyes /forum/post/16980849
i'm updating the site in the next day or two to host the new 900 favorite icons database.
i can tell you already that the screen resolution on the new 900 is much improved and the new icons look fantastic (imho). i've been using the beta product for awhile and the resolution combined with the nice animated screen transitions make for a very sharp user experience.
I just purchased a Harmony One a few days ago. I plan on taking it back and getting the 900 based on two reasons. I don't like the fact that the lcd screen is not clear enough (for my aging eyes) and it doesn't stay on long enough. These two features are worth it alone for me.
That's odd that Amazon shows four IR ports on the back of the RF extender and also a picture of a stick-on emitter pair. I can see the emitter picture being incorrect, but the four port extender would have to be photoshopped.
might be our beta models only had the two and the production version includes four. i used a couple splitters from my neighborhood radio shack to increase the number of leads out and it worked fine too.
I've read that this model doesn't support sequences. I think that's strange, considering that many want the current sequence capability on the Harmony One to be expanded to more than 5 steps.
Originally Posted by David Ortiz /forum/post/16981676
I don't see the picture you're referring to.
Wannabe: Kindly clarify "sequences". I have my 1000 currently programmed to raise the lights on a pause (sequence of raise lights command and then pause command) and dim lights on play (sequence of lower light command and then play command).
Will I lose this functionality?
Can it still be programmed to setup a device used in an activity like a lighting controller (i.e., set lights to DIM on 'Watch DVD').
Finally what appears to be a useful device and the one bit of flexibility for programming is removed. I get it, make it easy to program, restrict advanced features and thus mitigate calls to customer service; but this is too far.
Too bad about the sequences, I use them with my One as a macro to navigate my tv's menu to switch from Just Scan to 16:9 and back (soft buttons for both).
Do the master/mini blasters plug in to an outlet or are they battery powered?
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
