Official Logitech Harmony 900 thread - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #2851 of 2877 Old 06-29-2015, 07:49 PM
RadYOacTve's Avatar
Quoted: 24 Post(s)
BTW, look at the picture you posted of the Logitech site, clearly shows the Ultimate remote and says to update the hub which the 900 doesn't have.
RadYOacTve is offline
post #2852 of 2877 Old 07-24-2015, 07:49 PM
AlbanyHDTV's Avatar
My 900 controls everything via RF, except turning my HDTV on/off.
The HDTV power is controlled via IR from the 900.
Within the last month, the 900 will not turn the HDTV on/off, but will control all the other components correctly via RF.
However, if I put the 900 about 12" or less from the HDTV and press "watch tv", the HDTV will power on. This leads me to believe that the IR emitter is weak.
Is there a DIY procedure to replace the IR emitter or some other form of troubleshooting to determine the reason I cannot turn my HDTV on/off while sitting on my couch?
AlbanyHDTV is offline
post #2853 of 2877 Old 07-25-2015, 04:39 AM
Gary J's Avatar
Quoted: 315 Post(s)
Liked: 183
use the mini blasters.
Gary J is offline
post #2854 of 2877 Old 07-25-2015, 05:46 AM
AlbanyHDTV's Avatar
My HDTV is mounted on a wall with no wires hanging from it.
How would I have the mini-blaster turn the HDTV on/off without leaving exposed wires?
post #2855 of 2877 Old 07-25-2015, 05:49 AM
Gary J's Avatar
Quoted: 315 Post(s)
Liked: 183
tape and imagination.
Gary J is offline
post #2856 of 2877 Old 09-01-2015, 12:27 PM
Big Picture's Avatar
DirecTv H23-600 & Harmony 900 Problems?
I can't get my Harmony 900 to control my DirecTv H23-600 via RF to IR. I have even tried entering all the H20 IR commands manually without success.
I had it working at one point by using the Harmony equipment library code for an H20-100 but for reasons unknown to me it stopped working. Everything else in my Harmony setup is working fine.
Any assistance would be much appreciated.
Big Picture is offline
post #2857 of 2877 Old 09-01-2015, 01:05 PM
deano86's Avatar
Quoted: 106 Post(s)
Liked: 74
So, you are controlling other equipment with your Harmony blaster via RF to IR just fine? I assume your Directv H23 receiver is responding to the DirecTv remote OK? Does the H23 have it's own RF remote control option that someone in your household turned ON instead of using the normal IR control?
deano86 is offline
post #2858 of 2877 Old 09-01-2015, 02:48 PM
All other equipment working fine RF to IR with Harmony 900. H23 working fine in both RF & IR mode with it's own remote, set to IR mode now.
I am using a 3rd party mini blaster to the H23 that signals visually red when it's working, seems to be working fine.
What else can I try or look into?
post #2859 of 2877 Old 09-01-2015, 02:55 PM
deano86's Avatar
Quoted: 106 Post(s)
Liked: 74
I am using a 3rd party mini blaster with the H23 that signals visually when it's working, seems to be working fine.
I assume you double checked your RF device assign settings in your Harmony remote menu? Make sure the your H23 didn't get toggled to OFF. When you press commands that are just for the H23, what icon flashes at the top of your remote display? the IR wave icon or the correct RF antenna symbol? If your RF device assignment is correct, maybe try removing and re adding the blaster.....
deano86 is offline
post #2860 of 2877 Old 09-01-2015, 03:00 PM
deano86's Avatar
Quoted: 106 Post(s)
Liked: 74
I would disconnect/take off the mini blaster from the H23 and see if the main blaster works OK. I never need the mini blaster in my equipment closet as the main blaster sprays the IR signal just fine.... and just because the indicator light works on your 3rd party mini, doesn't necessarily mean that the IR emitter is working properly in it...
deano86 is offline
post #2861 of 2877 Old 09-01-2015, 07:44 PM
My H23 is in an ajoining room so I need a mini blaster there. Whats vexing is that the setup was working and now it's not. I am suspecting maybe a problem with the RF setup, is there some sort of RF master reset somewhere in the H900 system?
post #2862 of 2877 Old 09-01-2015, 08:06 PM
deano86's Avatar
Quoted: 106 Post(s)
Liked: 74
Check out this article... there is some great troubleshooting tips and at the bottom is a procedure to re-initialize the Blaster..
http://www.harmonyremoterepair.com/H...roubleshooting
NODES likes this.
deano86 is offline
post #2863 of 2877 Old 09-01-2015, 09:08 PM
Thanks. I'll keep plugging away until I find the answer.
post #2864 of 2877 Old 09-01-2015, 09:35 PM
Does anyone here know of any universal DirecTv set top box code(s) that might work with a variety of set top HD boxes? I recall reading somewhere that they exist but I can't locate them thus far.
post #2865 of 2877 Old 09-02-2015, 03:30 AM
Edmund's Avatar
Quoted: 42 Post(s)
Liked: 30
The Directv IR codeset hasn't changed since 2005. What are asking for, you want an universal that has multiple addresses for directv receivers? The discontinued philips sru-5106, 5107, and 5108 has preset codes for directv addresses 00001(philips code 1278), 00003(1378), and 00004(1478).
Edmund is offline
post #2866 of 2877 Old 09-02-2015, 09:38 AM
mdavej's Avatar
Quoted: 1746 Post(s)
Liked: 813
As Edmund said, all HR2x, HR3x, HR4x, HR5x, H2x, D1x, R1x and R2x codes are identical. Some have more or fewer commands depending on how Logitech built their database, but the individual commands all match 100%. I don't know what's causing your problem, but the codes aren't it. You must have the correct blaster assignment for you 900 and make sure IR is still enabled on the H23. Since you say IR still works from the H23 remote, next thing I'd try is to see if any IR is coming from the blaster with a digital camera. My guess is it's not. Could you have inadvertently changed the address in the H23?
If you want to mess around with alternate address anyway, you can start with this, convert to pronto hex with IRScurtinizer and email the result to datasupport@logitech.com or import using Concordance (if it supports the 900). Address zero might work on all units, but I'm not certain as I haven't had DirectTV for quite a while now. But I can tell you it won't make any difference whatsoever.
http://www.hifi-remote.com/forums/dl...e&file_id=4687
mdavej is offline
post #2867 of 2877 Old 09-02-2015, 07:31 PM
Thank you guys for the assistance.
Can I be confident that using Logitech's H23-600 code assignment will in fact operate my H23-600 or should I pick another one such as HR20-100? Can someone tell me which Logitech DirecTv HXX-XXX codes will work for sure with my H23-600?
I am using a third party mini blaster on a 6' cable added to 12' cable to control my H23 located in a room with no other media equipment. It flashes red when it's sending.
Should I only use Logitech blasters?
I have not added any delays in the H900 programming when it turns on the various devices string, should I?
How can I be sure that my H23 has the correct address?
I have enabled the H23 blaster assignment on my H900, like I did with my other equipment, and enabled IR on my H23 and confirmed it is working fine with the DirecTv IR remote.
All of my other media equipment operated by my H900 is working ok.
None of my H23 functions are working with the H900 even after I turn it on manually.
post #2868 of 2877 Old 09-10-2015, 04:50 PM
Replacing a third party IR blaster with a genuine Logitech Mini Blaster fixed all my problems.
post #2869 of 2877 Old 11-29-2015, 11:31 AM
jdmst71's Avatar
Soft buttons
Sent from my XT1575 using Tapatalk
jdmst71 is offline
post #2870 of 2877 Old 11-29-2015, 05:22 PM
jdmst71's Avatar
Sorry that last post was supposed to be a search but I messed up.
Does anyone have an issue and/or a fix for customizing the soft buttons in the individual activities. I can program them with the harmony software with words of my choosing (or a picture) but after the remote downloads they completely dissappear. If its a picture they stick but if it's words they won't program to the remote and that soft button will be blank.
I bought this remote about 6 months ago to replace my broken harmony one because I don't like the buttons available on the new models. The one had a Web browser programing that worked flawlessly. The program required by the 900 isn't being updated I'm assuming so I'm hoping someone else knows of a fix.
I tried finding the picture icons inside windows Explorer but had no luck. If so I could just create my own custom pictures with words in them to download to the remote.
jdmst71 is offline
post #2871 of 2877 Old 12-14-2015, 06:42 PM
jkasanic's Avatar
Quoted: 276 Post(s)
Liked: 103
So I just went to program a new device into my Harmony 900 only to realize I now have to use the desktop version of the software exclusively (used to use the web interface). Anyway, having some issues finding my device (Marantz AV7702 mkii). Is there a better way to search the database than selecting a product category and typing in the model? I've tried several combinations to no avail. Just looking for confirmation the device isn't in the database before I start learning commands.
jkasanic is offline
post #2872 of 2877 Old 12-14-2015, 08:51 PM
mdavej's Avatar
Liked: 813
Just pick a similar model. Most if not all codes are the same within a brand and past several models. AVRs typically have hundreds of discrete commands, only a tiny fraction of which can be learned. That would be a last resort.
mdavej is offline
post #2873 of 2877 Old 12-15-2015, 07:33 AM
jkasanic's Avatar
Quoted: 276 Post(s)
Liked: 103
I picked the original AV7702 but I'm having mixed results. Power on/off isn't working but other commands do.
jkasanic is offline
post #2874 of 2877 Old 12-15-2015, 10:12 AM
mdavej's Avatar
Liked: 813
Here are some more to try. All these have exactly the same codes according to the Marantz document below:
AV8802 AV8802A AV7702mkⅡ AV7702 SR7010 SR7009 SR6010 SR6009 SR5010 SR5009 NR1606 NR1605 NR1506 NR1504
http://www.awe-europe.com/documents/...R_CODE_V02.xls
The tricky thing about these is the RC5 protocol has a toggle bit. So if Logitech missed that fact, they'll work inconsistently.
mdavej is offline
post #2875 of 2877 Old 12-15-2015, 02:18 PM
jkasanic's Avatar
Quoted: 276 Post(s)
Liked: 103
Thanks for the info.
jkasanic is offline
post #2876 of 2877 Old 12-23-2015, 10:01 AM
Tamas's Avatar
Quoted: 12 Post(s)
HI,
I just tried updating the firmware on the remote.
The first part worked fine. When it came to update the remote, the update failed at step 2 applying settings failed and keeps failing. The software on the computer is telling me that the step failed updating region:bad region. The remote screen tells me that the firmware upgrade was successful, please update your remote with the remote control software.
Is there a fix for this or is the remote bricked.
Tamas is online now
post #2877 of 2877 Old 12-23-2015, 11:10 AM
mdavej's Avatar
Liked: 813
The last firmware for a 900 came out years ago. How are you just now updating it?
What country did the remote come from? Can you VPN to that country and try again?
mdavej is offline
Reply Remote Control Area
