Harmony 700 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 809 Old 09-27-2009, 07:09 AM
ubercool's Avatar
Quoted: 17 Post(s)
Originally Posted by Anubys View Post
2. the OK (select) button is WAY too small...half the size of any other button...so you have to make your thumb "small" to press it without pressing the direction buttons. Only 45 minutes with it, and my thumb was tired...
3. if you're used to the 676 layout, the Exit button was on top of the Menu button...on the 700, it's the reverse...so every time I tried to press Exit, I pressed Menu...why in the world would they change that?!
Sorry to hear about the small OK button, that's stupid design. In terms of the Exit button below, it's a more accepted norm coming from other remotes.
I'm sure the price will go down eventually...this should be $90...I would have waited for the price to go down but my 676 had too many buttons not working anymore so I bit the bullet...
here's hoping the 6 device limit is purely software and they can increase it to 8...this would be my perfect remote at 8 devices...
It would be a perfect remote with an eight-device limit agreed, but the good news is that it's already $115 on eBay, where I will purchase it this week.
ubercool is offline
post #32 of 809 Old 10-03-2009, 09:05 PM
Babaganoosh's Avatar
The reviews say that the same cable that's used to connect the 700 to a computer (USB) is also the cable that hooks into the charger. So can this thing charge *from* the computer?
Meaning this: If I leave the cable connected to a free USB port on my computer (an iMac), can I charge the 700 from there? So technically I wouldn't need the wall unit at all then, would I?
"I bought a new camera. It's very advanced. You don't even need it."
- Steven Wright
Babaganoosh is offline
post #33 of 809 Old 10-03-2009, 10:24 PM
Anubys's Avatar
I think you can...I'm going to test it as soon as the battery runs out...but I've had it for over a week now and it's still going strong...I just know it will run down tomorrow while I need it for the NFL games...
I'll report back either way as soon as they need a recharge...
Anubys
Anubys is offline
post #34 of 809 Old 10-06-2009, 06:01 PM
Anubys's Avatar
batteries finally ran out...I plugged it into my laptop and it gave me a message that it's ready to learn a command from another remote (?)...I plugged it into the wall and it gave me the icon for charging the battery...
so my guess is you cannot charge the battery from the USB port on a computer...I do have a usb hub with a power plug to charge things...but it's not on a computer that is convenient to use as a charger...easier for me to just plug it into the wall...
Anubys
Anubys is offline
post #35 of 809 Old 10-09-2009, 10:42 PM
Anubys's Avatar
After playing with the 700 now for a while, I finally figured out what was bothering me about the layout and re-mapped the buttons to fix it...
if you have and use the DirecTV remote in another room, you're going to have trouble...on the DirecTV peanut, you have:
the skip/slip button is on top of the FF
the repeat (skip back) button is on top or Rewind
this is the opposite on the 700 (FF is on top of skip forward and rewind is on top of skip back).
the DirecTV layout makes more sense (or maybe I'm just more used to it)...I kept pressing the wrong thing on the 700...so I remapped the 700 to match the layout of the DirecTV peanut...
Anubys
Anubys is offline
post #36 of 809 Old 10-18-2009, 02:53 PM
joe221's Avatar
Quoted: 67 Post(s)
Liked: 26
I got my 700 on Saturday from Amazon Vine. My first observations are , what's up with the cable? I've had a bunch O Harmony's and they all use a standard USB cable. Why change now? Also why no battery indicator? It'd be nice to know? Maybe it turns on when it's needing a charge but still it's comforting to see it. The build seems cheap, in my book $150 is not $19.95, it should be better built. If the One is priced anywhere near this, get the One, IMHO.
I'll post a full review on Amazon when I'm done testing.
Joe in West Los Angeles, CA
joe221 is offline
post #37 of 809 Old 10-18-2009, 04:37 PM
black_macleod's Avatar
I just got one too, replaced an older model. I think the build is fine, and it works great -- imported my old settings, and I was good to go.
BTW, the USB is just a standard Micro-USB instead of Mini-USB .. I have plenty of both laying around the house. Its not a huge deal. Both are standards.
black_macleod is offline
post #38 of 809 Old 10-19-2009, 06:22 AM
yaser220's Avatar
nice
yaser220 is offline
post #39 of 809 Old 10-23-2009, 09:53 PM
img eL's Avatar
How is usb charging with the 700?
img eL is offline
post #40 of 809 Old 10-23-2009, 10:30 PM
It won't charge off a computer. Has to be plugged into the AC power brick. But it works fine
post #41 of 809 Old 10-23-2009, 10:44 PM
img eL's Avatar
So no usb charging at all?
img eL is offline
post #42 of 809 Old 10-24-2009, 12:30 AM
Anubys's Avatar
no usb charging...
Anubys
Anubys is offline
post #43 of 809 Old 10-28-2009, 03:04 PM
img eL's Avatar
How do u know when the 700 is done charging?
img eL is offline
post #44 of 809 Old 10-28-2009, 06:08 PM
img eL's Avatar
When the green battery on the screen is all filled up with a check mark in the center
img eL is offline
post #45 of 809 Old 11-03-2009, 07:29 PM
Anthony A.'s Avatar
what are the 4 color buttons? are they self-assignable for whatever you want?
Anthony A. is offline
post #46 of 809 Old 11-03-2009, 08:39 PM
joe221's Avatar
Quoted: 67 Post(s)
Liked: 26
Don't have any devices with color buttons? 360, BluRay, DVR?
Hard buttons for those now. Same on 900.
joe221 is offline
post #47 of 809 Old 11-04-2009, 05:26 AM
Anubys's Avatar
you can use them for Directv's DVR color buttons or a 360 (as posted above)...they are assignable to anything you want as well...so, really, it's an extra 4 buttons to do with as you please...
Anubys
Anubys is offline
post #48 of 809 Old 11-08-2009, 12:18 PM
I've fiddled with a 700 in the store. The buttons seem a bit squishy/soft to me. Has anyone else felt that way?
- Steven Wright
post #49 of 809 Old 11-09-2009, 08:31 AM
Meh, not really. They do feel different than my old 659 buttons, but they work fine.
post #50 of 809 Old 11-09-2009, 12:28 PM
Wesley Hester's Avatar
Quoted: 70 Post(s)
Liked: 55
Is there a way to have channel icons on the screen or not? They appear in press photos of the remote and in specification lists. If so, how?
Wesley Hester is online now
post #51 of 809 Old 11-09-2009, 01:06 PM
You can, but you have to add the icons manually. There is a nice site set up with a lot of pre-designed icons. Its a bit time consuming, but I've spent the time setting up my GF's favs so its easy browsing:
http://www.iconharmony.com/icons/wat...ory=harmony700
Follow the directions on that site, you do this from within the Harmony Remote software on your computer, then sync the remote up.
post #52 of 809 Old 11-09-2009, 04:27 PM
Quoted: 70 Post(s)
Liked: 55
Thank you. Added channels and icons in about 10 minutes. Worked great. Feel kind of stupid.
post #53 of 809 Old 11-09-2009, 05:36 PM
joe221's Avatar
Quoted: 67 Post(s)
Liked: 26
Don't feel stupid. It was new to all of us back when. BTW Randy (squareeyes) prowls these forums so if you have any icon wants just ask.
joe221 is offline
post #54 of 809 Old 11-09-2009, 06:45 PM
Yea I sat there for 20 mins at first entering channel numbers and cursing it because the FOX icon showed up for each one :-)
post #55 of 809 Old 11-09-2009, 07:34 PM
jsevinsk's Avatar
I think six devices is an artificial limit placed on this remote by the software. I had an older remote with more than six devices, including some obsolete devices that I don't even own anymore. When I switched over to the 700 with the "replace remote" option, all my devices showed up on the remote! Of course, the software complains that I'm at my device limit and won't let me add any new devices. Right now, I have ten devices on my 700 remote.
vivatech likes this.
jsevinsk is offline
post #56 of 809 Old 11-12-2009, 07:06 PM
BertBert's Avatar
Originally Posted by jtanderson View Post
$150 for a remote that only supports 6 devices. Surely they jest.
+1
Life is not what you think it is!!!
BertBert is offline
post #57 of 809 Old 11-12-2009, 07:37 PM
ubercool's Avatar
Quoted: 17 Post(s)
Originally Posted by BertBert View Post
+1
Six devices will cover the needs of 90% of all users, so what's the issue here?
1. Monitor
2. AV Receiver
3. PVR/STB
4. Blu-ray player
5. HD-DVD player
6. Internet Radio (Squeezebox)
The listing above is my system. I will eventually get rid of the HD-DVD player. And Internet radio will one day be included in all AVRs, so then I'm down to four devices. Time to put your system on a diet.
ubercool is offline
post #58 of 809 Old 11-13-2009, 05:55 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
The issue is the previous models had 12 or 15 devices for the same price or less. It's just a marketing ploy to force that other 10% to the 900. Probably a sound business decision for logitech, but bad for the consumer. I'm using 12 devices (add lights, htpc, DVD recorder, AV/Switch, etc. to your list) on my $100 harmony. If I upgrade, I'll have no other choice but the $400 model in the harmony lineup. So in my case, I'd probably switch brands altogether before I'd pay that kind of money. Even if I did, they've also crippled the 900 by removing sequences. So now they simply don't offer a model that suits all my needs. There were plenty of old models that did.
As for putting your system on a diet, I'd never build my system around a stupid remote. It's the other way around. There are plenty of remotes that can handle a system with more than 6 devices very easily, including a $10 POS remote I have. And that cheap remote can do 15 step sequences when the harmony can only do 5 steps. So just because logitech decides to cripple their new models in the name of greed, I'm certainly not going to retire any of my AV equipment to suit their misguided whims.
mdavej is offline
post #59 of 809 Old 11-13-2009, 06:01 AM
In2Photos's Avatar
I really like the look and layout of this remote. I'm looking for one to replace my DVR remote in the bedroom (using a One if the family room). I only have 3 devices in there so this would work fine, but I was hoping for something a little cheaper. Looks like I'll have to wait for the prices to come down some more.
Mike
In2Photos is offline
post #60 of 809 Old 11-13-2009, 07:36 AM
jsevinsk's Avatar
Assuming that Logitech will eventually fix the more-than-six-devices-when-you-upgrade loophole...
I wonder if I can create my own device that includes both the audio receiver and the TV. Other than changing inputs on both and adjusting the volume, there's not much else I need to control. That way, I'll be using one remote device to control two real devices.
jsevinsk is offline
Reply Remote Control Area
