Harmony 700 - Page 24 - AVS Forum
post #691 of 697 Old 09-29-2014, 11:51 AM
idicev's Avatar
Originally Posted by frankhj View Post
I am trying to add a step to an activity, but the 7.7.0 software that I have does not have a customize this activity option. It has Settings, Troubleshoot, & Customize Buttons.
If I use the myharmony.com it tells me to open the myharmony.com desktop software which is totally useless. It does not even have any options to customize buttons.
What am I missing here?
With v7.7.0 software it's a bit more long winded:-
In Activities, Settings (select:-) > review the settings...> 'Yes but I want to add more control...' > save> next>
[ then see the options at the bottom:- ]
'Add action for...'
or
'When you leave this activity: add action for...'
idicev is offline
post #692 of 697 Old 09-29-2014, 01:45 PM
HarmonySylvain's Avatar
Quoted: 85 Post(s)
Liked: 37
In MyHarmony, to add a step to an Activity, simply select the Activity in question and click 'Customize Activity'.
The option to customize buttons is available by clicking on the 'Buttons' tab on the left side of your account.
Sylvain
I am an employee of Logitech's Harmony division.
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
post #693 of 697 Old 09-29-2014, 01:52 PM
frankhj's Avatar
Sylvain
I do not have any buttons on the left side of the account. I see some pictures of MyHarmony app on the Logitech site. My app does not look anything like it.
frankhj is offline
post #694 of 697 Old 09-29-2014, 02:22 PM
Quoted: 85 Post(s)
Liked: 37
The MyHarmony desktop app can be installed from setup.myharmony.com
However, it seems you set up your 700 using the Harmony Remote Software, in which case it's recommended to use that and follow idicev's instructions to customize your Activity.
While MyHarmony also supports the 700, it would require creating a new account and importing your Remote Software Settings in order to be used.
post #695 of 697 Old 09-29-2014, 02:52 PM
frankhj's Avatar
The MyHarmony desktop app can be installed from setup.myharmony.com?
Since you refuse to believe me I guess I have to include pictures.
Above is what MyHarmony screen looks like. Nowhere to do what is described above.
Picture above is what my Harmony Remote Software looks like. Again I cannot follow the instructions because the options listed are not available.
So what am I doing wrong?
ID:	285954   Click image for larger version
frankhj is offline
post #696 of 697 Old 09-29-2014, 03:12 PM
Quoted: 85 Post(s)
Liked: 37
Your MyHarmony account is still in setup and has not been synced yet.
Hit the sync button on the bottom right, and once synced, you will have access to all the post-setup settings.
Sylvain
post #697 of 697 Old 09-29-2014, 03:31 PM
frankhj's Avatar
Sylvain
I missed Idicev's reply to my post. Thank you, that is what I was looking for.
Sylvan, why in the world would you make anyone sync to the remote before you have anything meaningful set up? The reason I never completed the setup was because it was so Spartan.
frankhj is offline
Reply Remote Control Area
User Tag List
