Harmony 700 - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #751 of 762 Old 05-02-2016, 11:22 AM
NickSteel's Avatar
Finally just ordered a couple $199 Newegg Yamaha SRT-1000's. Easier than figuring out stuff and they fit under the TV's and work with our Xfinity remotes.
Thanks for you advice.
NickSteel is offline
post #752 of 762 Old 05-08-2016, 02:56 PM
jimsfield's Avatar
I can't find how to delete my ROKU 2 and add my ROKU 3 using MyHarmony. Help.
jimsfield is offline
post #753 of 762 Old 05-08-2016, 04:48 PM
mdavej's Avatar
Quoted: 2068 Post(s)
Liked: 927
Codes are exactly the same. Leave it alone.
mdavej is offline
post #754 of 762 Old 05-09-2016, 09:41 AM
jimsfield's Avatar
post #755 of 762 Old 12-02-2016, 03:21 PM
philmck2's Avatar
A couple of questions:
Programmed a second device with Zone 2 on my Yamaha RX-V775 and not all the commands are available (unlike Zone 1). Want to setup an Activity to listen to Pandora in Zone 2 and the only input option is Net which toggles the input if it was already on Pandora. The Zone 1 has a command = Input Pandora. Is there a fix?
In any activity can I set the initial volume to a certain level? Not just up or down but a starting level - say 20dB.
Thanks in advance,
P
philmck2 is offline
post #756 of 762 Old 12-02-2016, 04:08 PM
mdavej's Avatar
Liked: 927
Can that be done with the Yamaha remote?
I'll have to check on the fixed level.
mdavej is offline
post #757 of 762 Old 12-03-2016, 05:17 AM
philmck2's Avatar
No it can't be done on the Yamaha remote without toggling the Net. Zone 1 or Zone 2, but the Zone 1 has a command.
philmck2 is offline
post #758 of 762 Old 12-03-2016, 09:38 AM
mdavej's Avatar
Liked: 927
Good news is that discretes probably do exist for volume memory presets and recall as well as Pandora for Zone 2 based on some older code lists I managed to find. Bad news is I can no longer access the site where I used to get Yamaha codes, so I don't know what the codes are for the 775. If you manage to find any and any format, I can help format them for submission to Logitech support. You may be able to ask Yamaha to email them to you. They used to post them on their website, but I can't find them.
For now, email the following to datasupport@logitech.com and ask that they add the volume memory and recall commands for all zones to your account and give them a try. You have to join the site in order to download. You'll have to look in your manual to learn how to set and use volume presets, then add the appropriate commands to the start of your activities. I've never used a Yamaha receiver.
http://www.hifi-remote.com/forums/dl...&file_id=13126
mdavej is offline
post #759 of 762 Old 12-04-2016, 05:58 AM
philmck2's Avatar
Thanks. I will pursue the leads with Yamaha and Logitech and report back to the forum so others can learn.
P
philmck2 is offline
post #760 of 762 Old Yesterday, 03:19 PM
jsmiddleton4's Avatar
Quoted: 531 Post(s)
Liked: 180
My Harmony One went out, got really hot, something shorted. Tried the new IR 950. It is not in my humble opinion a replacement for the Harmony One and at 250 it is pricey.
Sent it back. Picked up a 700 at Best Buy for 49.99 today. No its not as fancy. Has a few less tweaks like arranging activities, etc. Doesn't show as much on the LCD screen. I did not like the 950 swipe screen, etc., anyway.
The 950 only allows Favorites for one activity. That's nonsense.
The 50 dollar 700 allows Favorites based on the Device which means I have Favorites for multiple activities.
Back lit. Rechargable. Lots of hard buttons. 8 Devices. High degree of wife factor approval.
Thinking about buying another as a backup.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is online now
post #761 of 762 Old Today, 07:04 AM
frankhj's Avatar
I thought they stopped making the 700. I have 2 of them, charge one while using the other. Great remote. Thinking about buying a couple as backups at that price.
frankhj is online now
post #762 of 762 Old Today, 08:48 AM
Quoted: 531 Post(s)
Liked: 180
"I thought they stopped making the 700."
Apparently. No word on what is replacing it if anything.
The only thing that I see that keeps it from being a near perfect remote at its price point and for those who like hard buttons more than a touch screen would be to have the Activity keys at the top also be illuminated.
At 49.99 its a steal.
I have rechargeable batteries. I just swap them out. Those enlope ones. They work great. I have a 650 for the spare bedroom TV, etc. It was in that niche, out of sight and mind, so I didn't think about testing it in the front room main home theater. My wife said something and I gave it a try before getting the 700. A duh moment......
I've put rechargeables in it too. It won't recharge them but uses them just fine.
And for the 200+ dollars I've saved, that's the cost of an Nvidia Shield. Have a remote that just works but isn't fancy AND a Nvidia Shield or have just a fancy remote that is too fancy for how its used?
Kinda a no brainer.
Watching for sales now on a Shield.
Reply Remote Control Area
