DirecTv HD-DVR Box discrete codes 00003 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-10-2009, 12:38 PM - Thread Starter
smitty8000's Avatar
I just added a 2nd HD-DVR box two my equipment rack and I programmed it to use code 00003. However with my URC MX-800 I was unable to download any discrete on/off codes for the 2nd box. To clarify, DirecTv box 1 using code 00001, I have discrete on/off. I'm trying to find discrete codes for box 2 under the code set 00003.
Anyone know?
Ryan
smitty8000 is offline
post #2 of 5 Old 10-10-2009, 08:39 PM
herdfan's Avatar
I think it is in the URC database as 00002 or HR20(2).
Please do not send me PM's asking for software! You will not get it.
herdfan is offline
post #3 of 5 Old 10-14-2009, 06:48 AM
kiser17's Avatar
Ryan, how did you program the DTV box to a different code? I'm trying to go down a similar path as you, and I do not know how to program the remote/box for a different code. I couldn't find anything in the DTV literature on it either.
Thanks, Ed
kiser17 is offline
post #4 of 5 Old 10-14-2009, 10:42 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Thanks, Ed
See this thread:
http://www.remotecentral.com/cgi-bin...ost.cgi?524915
Use the first set of instructions for SD & H model receivers, use the second set for the HR dvr's
Edmund is offline
post #5 of 5 Old 10-14-2009, 10:54 AM
kiser17's Avatar
Originally Posted by Edmund View Post
See this thread:
Thanks Edmund!
kiser17 is offline
Reply Remote Control Area
