RTI M2 codes for Sony DVP CX995V - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-19-2009, 06:40 PM - Thread Starter
Lonnie P's Avatar
I have it working on command mode #1, but I cannot get it to work with the user options. I have 2 players & cannot control the second.
Does anyone have the alternate codes, or know what I have to do to modify them?
Lonnie P is offline
post #2 of 5 Old 10-19-2009, 10:48 PM
Glackowitz's Avatar
You will probably have to learn them from the remote with it set to ID2. Have you looked for a ccf with ID codes??
Do you have an IRPRO to learn them?
Glackowitz is offline
post #3 of 5 Old 10-22-2009, 05:29 PM - Thread Starter
Lonnie P's Avatar
No I do not have an IRPro.
I was hoping since I had codes for ID1, that a minor tweak for ID2 was all that was needed.
Lonnie P is offline
post #4 of 5 Old 10-22-2009, 08:33 PM
Glackowitz's Avatar
What IR gatabase are you using?? Have you tried other codes to see if they will work?? There are some CDP-CX90ES codes for ID1, ID2, ID3. Sony is usually pretty cood about keeping codes the same
There is the Mega code list 18 to use if you dont have it
post #5 of 5 Old 10-23-2009, 06:55 PM - Thread Starter
Lonnie P's Avatar
I'm using the Integration designer software from RTI & got everything else to work, except for the ID2 on this unit & the sony BDPS-550 Blu-ray player.
Still looking for some good code sites. I've been on remote central a few times... & I just found another section with the file you listed in it. Never saw that section before. I appreciate the info.
Lonnie P is offline
Reply Remote Control Area
