No Universal codes for Viore TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-12-2009, 06:45 AM - Thread Starter
wjbinmd's Avatar
I just purchased a 32" Viore HDLCD TV model LC32VX60HDT. I contacted the Viore tech support (216-454-0868) and they informed me that there is NO universal remote control code for this TV. This TV will only work with the Viore remote control. You are expected to use two remotes if you have cable.
wjbinmd is offline
post #2 of 26 Old 11-12-2009, 07:45 AM
ccotenj's Avatar
Liked: 101
unless the remote is rf (unlikely, but i suppose possible), just learn the codes you need into your universal remote...
- chris
ccotenj is offline
post #3 of 26 Old 11-30-2009, 12:46 PM
gornza's Avatar
I purchased a 37 inch VIORE (model lc37vf55) and got the same deal from their tech line. Is there a way around this?
gornza is offline
post #4 of 26 Old 12-03-2009, 09:20 AM
blackssr's Avatar
Quoted: 1155 Post(s)
Liked: 578
Is this a US brand TV. I have never heard of it. It is a Walmart or Cosco rebrand model?
I've paid for my sins. We're even!
blackssr is offline
post #5 of 26 Old 12-03-2009, 12:02 PM
HoustonPerson's Avatar
Are there any Akai codes you can use? Those might work?
HoustonPerson is offline
post #6 of 26 Old 12-03-2009, 03:31 PM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
0054 or 1207 might work on many cable remotes. If not, try TV code 1684 (NEC1 device 96 subdevice 157) on UEI remotes like the RCA RCRP05B ($20 at best buy).
If that doesn't work, get a cheap universal and learn the half dozen commands you need. What's the big deal? A lot of tv's won't work with cable box remotes. That's why learning remotes exist.
mdavej is offline
post #7 of 26 Old 04-13-2010, 09:41 PM
astros1147's Avatar
I'm no expert on how unversal remotes work (someone mentioned something about using an IR remote and I have no idea why or what that means) but what I do know is that I have a Viore tv and got the same song and dance about there not being any universal remotes for the tv. I had long given up on finding one, but I moved to a new house and got uverse and their remote works on my tv! Now I'm not sayin that you should get uverse to solve your remote problem but instead if you (or someone who knows this stuff) were to research this perhaps we could find the code or figure what type of remote att uses. I invite anyone that knows how to program remotes to solve this conundrum.
Sunny Chace likes this.
astros1147 is offline
post #8 of 26 Old 04-14-2010, 02:18 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Help a little yourself, the code in which the viore responds to in your ATT remote, look and see if any other brands of tv use this code by looking at the att manual. Come back and post the brands of tv here. Give others a shot at trying codes for those same tv brands in their remotes.
Edmund is offline
post #9 of 26 Old 10-15-2011, 02:39 PM
Meldarko's Avatar
My 32" Viore works with my AT&T u-verse remote using the Akai code 1265.
Meldarko is offline
post #10 of 26 Old 11-09-2011, 10:05 AM
jen512's Avatar
i purchased a 24" Viore tv last 10/10 and later got RCN cable 7/11. i was told they didnt have any codes for my tv so i had to use two remotes. wellllllllllllllll... i killed the Viore remote by grapefruit juice this morning, so suffice it say I thought I was #@cked. but i didnt give up.. i went online and started searching and whala!!! i eneded up using a Samsung code 031. hope this helps
jen
P.S. at first if you don't succeed try the internet.
jen512 is offline
post #11 of 26 Old 11-12-2011, 01:24 PM
WTierney's Avatar
Surely 031 is missing one digit? Aren't all the TV codes 4 digits? I too am loooking fo the correct code to control my 26" Viore with my Uverse remote control
WTierney is offline
post #12 of 26 Old 11-12-2011, 02:03 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Just try the samsung codes in whatever list you have.
Edmund is offline
post #13 of 26 Old 11-12-2011, 03:14 PM
WTierney's Avatar
I tried the "TV' list of
1004, 1005, 1011, 1014, 1018, 1019, 1072, 1073, 1074, 1097, 1098, 1156, 1161, 1297, 1323, 1360, 1363, and 1364;
and then on the Samsung LCD TV list numbers there were
1171, 1172, 1173, 1174, 1175, 1246, and 1352. No dice!!
I talked with AT&T tier 2 support for about 30 mins; they gave me a bunch of related mfg codes, but none of those worked either. I may call Viore on Mon. but I won't be holding my breath for a working code. Any other ideas?
WTierney is offline
post #14 of 26 Old 12-25-2011, 09:23 PM
BIGJ1983's Avatar
try 11395 i had the same issues but found this code online and it worked for me, hope it helps
BIGJ1983 is offline
post #15 of 26 Old 06-26-2012, 06:01 PM
adisa's Avatar
SAMSUNG CODE 0060 WORKED ON MY PANASONIC UNIVERSAL REMOTE.GET THE CODES FROM THE REMOTE FOR SAMSUNG ,IT WILL WORK,YAY
adisa is offline
post #16 of 26 Old 09-13-2012, 11:32 AM
ZCatcher's Avatar
I had the same problem with a little Viore we got for the kitchen. I tried everything, then stumbled across 10812 online, and it worked! Hope you get it worked out.
ZCatcher is offline
post #17 of 26 Old 11-25-2012, 07:21 PM
ADSImages's Avatar
I have an RCA Universal Remote (RCRN04GR) and I used the Auto Code Search feature to scroll through all the TV codes. It hit on Samsung code 10251 which functions most of what I needed (ON/OFF, Volume, Mute). Haven't tried the other Samsung codes to see if they work or have more functionality, but it's enough for me that I have this ability with this remote. None of the printed Viore codes worked on my TV which is a TV-DVD combo. Note that I do still need the original remote to use the DVD. I'll post again if I find a code that does more or find a way to operate the DVD with the Universal remote.
ADSImages is offline
post #18 of 26 Old 12-13-2012, 06:31 PM
Pam Hanner's Avatar
I got it - the remote code for Viore TV is either 11903 or 10702. 11903 worked for me!!!!
Pam Hanner is offline
post #19 of 26 Old 03-20-2013, 09:07 PM
Sunny Chace's Avatar
I just recently got a 56 inch Viore tv and got my dollar store remote to program to it, when one day the batteries fell out :[
The code 1684 worked for my tv and $5 remote :] thanks
Sunny Chace is offline
post #20 of 26 Old 06-07-2013, 08:53 PM
Arturoa's Avatar
I just bought this same TV. I am trying to set it up by useing the "Menu" and buttons functions on the TV.
Have you discovered any source for the remote as of today, June 07, 2013?
Arturoa is offline
post #21 of 26 Old 07-14-2013, 03:00 PM
Akaya Anderson's Avatar
Rca remote from family dollar or the rca universal remote rcr804bfdr this one its cheap n it work one thi big ones im guessing i used a samsung code the first one in fact mine is like a 32 or 37 inch viore telvision n it onlyy uses 4 digits the digits i used were 0812 works completly Hopes this helps every body if this doesnt work try all the samsung codes
Akaya Anderson is offline
post #22 of 26 Old 07-14-2013, 10:04 PM
mdavej's Avatar
Liked: 940
Here's the full code list: http://www.voxxintlcorp.com/docs/common/RCR804BR/RCR804BR_WC.pdf
Can you do me a favor and tell me if you see a 6-pin connector in the battery bay? And what was the price?
mdavej is offline
post #23 of 26 Old 07-15-2013, 04:48 PM
i dont know what a 6 pin connector is but the price for my remote is 8.50
post #24 of 26 Old 07-15-2013, 08:04 PM
mdavej's Avatar
Liked: 940
Thanks. Something like this?
mdavej is offline
post #25 of 26 Old 08-13-2013, 06:35 PM
asotelo83's Avatar
I know this is kind of old, but I did this and it worked. Started with the very first number for Samsung 258. It worked for Viore LE24VF25D smile.gif YAY
asotelo83 is offline
post #26 of 26 Old 10-27-2016, 11:17 AM
Liked: 0
I have a Viore PLCD10V59 Portable LCD TV/DVD and the remote crapped out on me. I had a purchased a Sony universal remote RM-VL600 years earlier that I still had hanging around
so I decided to give it a whirl. After trying many different codes I decided to try the Samsung codes as so many others had success. Voila, after say 6 or 7 tries the Samsung code 8026 worked.
And it's a good thing, because the cheapest cost for a Viore Replacement remote was 44 bucks! Forget that!
Thanks for everyone's help, I know some of these replies are years old but they sure helped me out!
teedee911 is offline
Reply Remote Control Area
Viore , Displays , Viore Lc37vf55 37 Inch 1080p Lcd Hdtv Black
