Odd Problem with IR Repeater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-17-2009, 08:42 AM - Thread Starter
gte619n's Avatar
Hey Guys,
I have a iAutomate IR-350 Infrared Repeater Kit installed in my living room. The hub is connected to my cable box and my blu-ray player. I'm getting some odd behavior with the cable box and I was wondering if anyone had any experience with the kit?
Kit URL: (oops, won't let me post it. It's the first result in google if you search for "ir350 bundle". sorry for the extra step)
I'm using a Harmony 550 remote. When I sit down and hit Watch TV, the TV and cable box come on; however, for the first ~5 minutes or so, the Cable Box will not respond to the harmony remote unless I am ~3" from the eye itself. After five minutes or so, everything works as normal and I am able to control the cable box from the couch. It does not appear to be a problem if I open the cabinet and control the box directly.
Does anyone have any expeirence with this sort of behavior? Any suggestions on what I can try?
gte619n is offline
Reply Remote Control Area
