IR Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-29-2009, 08:08 AM - Thread Starter
kkessenger's Avatar
I've read a couple posts with the same problem but no replies... Any tips would be wonderful!
My IR is no longer working. Worked perfectly for 3 years, with a IR receiver device over my TV, wire run in wall back to the speakercraft AT1-0 amplified terminator device, which then has connections to a Denon receiver and a dvd player.
All I did was remove the wires to the IR to reorganize the wiring, and I returned them, and now I can't get it to work. I replaced the Amplified Terminator Device, and still nothing. Is it possible that pulling them out fried both the emitter wires, or the receiver IR device, or are the 2 pair wires that connect the IR receiver to terminator device easily fried? Must be fairly common based on several similar posts.
Thanks for any advice!
Keith
kkessenger is offline
Reply Remote Control Area
