Which Samsung TV code is for Onkyo remote control? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2010, 01:01 PM - Thread Starter
sis649's Avatar
Just bought a Samsung Plasma HDTV PN50B550 and Onkyo Home Theatre HT-S6200, the Onkyo remote can control other electronics, however, there are about 20 codes listed under Samsung TV category, which one should I choose?
Is it possible that more than 1 code works, but only 1 is the best which means it can control all the features of the TV, while others only works for partial features? I don't have time to test one by one.
sis649 is offline
post #2 of 5 Old 01-06-2010, 02:00 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Can't say, but when it comes to samsung tv's and the universal & oem remotes, the only thing that should count is if the volume keys repeat when held down. Many remotes have the wrong protocol when it comes to samsung tv codes, result you have to keep pressing and releasing the volume for it to change. So if test the samsung codes in the onkyo and come across a code that allows you to just hold volume key down to change, thats a keeper.
And if the onkyo remote is made by UEI, and you see codes like 10702 or 10812, those are the ones to use.
Victim likes this.
Edmund is offline
post #3 of 5 Old 01-06-2010, 07:14 PM - Thread Starter
sis649's Avatar
Just tried 10812, it works (including the vol down), thank you!
sis649 is offline
post #4 of 5 Old 05-06-2011, 04:26 PM
Twister18's Avatar
I have trying to connect my Samsung 55 inch LED TV to my Onkyo HT-S6100 remote. Any tips on doing this? I tried the codes in the thread but didnt work.
Twister18 is offline
post #5 of 5 Old 06-27-2013, 07:10 AM
Victim's Avatar
Thanks a lot mate, I have a Samsung PS51F5500 and both these codes worked, but 10812 is almost perfect.
Many thanks again
Victim is offline
Reply Remote Control Area
Samsung Pn50b550 50 Inch 1080p Plasma Hdtv
