Looking for A Wireless extender for Harmony 1100EU - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2010, 11:24 AM - Thread Starter
Rino21's Avatar
Hello,
I'm looking for a wireless extender for 1100EU remote,
Is there any online shop in the US that I can purchase from and?
How do i know which model is compatible to a EU model?
Rino21 is offline
Old 01-07-2010, 01:49 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Do you mean a regular IR wireless extender or propietary RF base extender from Logitech.
If the first any basic IR extender should work for you. Look at X10 Powermids or Terk for something basic in a wireless IR extender, or for more options and a dedicated IR setup you can look at a Xantech solution. That's just a couple of the many solutions other than the RF base station.
oman321 is offline
Old 01-07-2010, 03:03 PM - Thread Starter
Rino21's Avatar
I'm looking for the Logitech extender which is compatible with the remote,
Thing is that it should be compatible with the 1100 Europe version which uses a different radio frequencies than the US one,
BTW - how can other extender work with the Harmony remote?
Rino21 is offline
Old 01-07-2010, 03:06 PM
localnet's Avatar
How far are you needing to go and are you using IR or RF?
localnet is offline
Old 01-07-2010, 03:11 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Originally Posted by Rino21 View Post
I’m looking for the Logitech extender which is compatible with the remote,
BTW – how can other extender work with the Harmony remote?
Other extenders will take the signal the 1100 is sending as IR and convert to its own RF commands then back to IR at the other end where your devices are.
As opposed to the 1100 sending out the command as RF and then the base station converting back to IR.
oman321 is offline
Old 01-07-2010, 05:52 PM - Thread Starter
Rino21's Avatar
I think i want the original just need to know where to find it,
Rino21 is offline
Old 01-08-2010, 07:37 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Where else but on Amazon.UK
http://www.amazon.co.uk/Logitech-Har...8&sr=8-1-fkmr2
I know I have heard of people buying DVD's from overseas, so hopefully you can get shipped to you if your in the US.
oman321 is offline
Old 01-08-2010, 08:55 AM - Thread Starter
Rino21's Avatar
For this price , no thanks,
Rino21 is offline
Old 01-08-2010, 09:56 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Price of the product or price of the shipping? I just checked Amazon US and see what you mean though if your talking about the product. Have you checked with logitech to confirm that the RF bases are in fact different?
oman321 is offline
Old 01-08-2010, 12:59 PM - Thread Starter
Rino21's Avatar
Yes , those are different,
Cant by from Amazon US and use a remote from Europe,
Talked to Logitech support but they can't tell where to buy,
When I explained the situation the lady told me to replace my remote 
Couldn't be more funny than that
Rino21 is offline
Old 01-08-2010, 01:11 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Sorry, hope you work it out.
Ya, not a very good solution they offered you. Good luck.
oman321 is offline
