AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Remote Control Area (http://www.avsforum.com/forum/93-remote-control-area/)
-   -   Need to control Denon AVR-4310, having no luck with Xantech (http://www.avsforum.com/forum/93-remote-control-area/1233811-need-control-denon-avr-4310-having-no-luck-xantech.html)
shanghai2004 03-09-2010 07:28 PM
Hi,
I use a Denon 4310 receiver's multi zone function.
The receiver is in the living room. Zone 2 is the bed room.
I bought a Xantech IR set to control the Denon receiver, a cable box and a DVD player in the living room from by bed room.
These I use:
- Hidden Link Designer IR Kit, Plasma & CFL Proof - Black
- Shelf-Top, BLAST-IR Emitter
However I have no luck getting this to work. When I use the kit with the blaster, nothing works. The yellow LED of the connector block blinks and the red LED on the blaster blinks when I press a button on the remote, but none of my equipment responds, even if I put the blaster as close as 1 meter from the equipment.
For test I use the original remotes of the equipment.
The IR kit contains 4 emitters. When I use one of those instead of the blaster, then I can control the cable box if I hold the emitter in front of it, but the Denon receiver still doesn't respond.
Anyone has a modern (xx08 or xx10) Denon AVR working with the Xantech set?
I'm trying to figure out if I do something wrong, maybe the Xantech is defective somehow or if it is not compatible with the Denon.
Any hint would be highly appreciated.
EDIT: Now also got the Denon 4310 working with the Stick-on emitters, but the Blaser still no luck
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
