Official Logitech Harmony 650/600 remote thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #541 of 1791 Old 01-19-2012, 08:28 AM
tipstir's Avatar
I had purchased two 600 at target on clearance (brand new in the plastic container) But both had hard time with SONY HDTV models which are brand new also. I had just ordered and got the 650 and 700. The 700 was mention it only supported 6 devices but it's 8 device. That one was able to see all the inputs on the two SONY. Where as the 600 and 650 seem to have issues. Still remotes are smart enough to do my task
Watch TV
My way: Watch CATV and Watch CATVDS (Digital Sound with the Pioneer kicks on)
I use all SONY products for Blue-Ray, Network Media Player and the HDTV except of Audio is left to Pioneer. I am just about to setup the Kitchen HDTV VIZIO White 22" just got that it has SONY Network Media Player in the cabinet attached to RCA attic or outdoor HDTV with 40 miles range. Just got the booster to increase that range from RCA. I pick all the local county and next county stations in HDTV not bad for LED/LCD VIZIO slim model.
So my only beef with Logitech is if you have more than one of their remotes like for me it's 4 but I have to setup 4 different email accounts to setup on the web. I see tv icons have to be pull in from additional source.
To bad the 600 didn't have color screen. I like the 600 over 650 and 700. But I had needed more devices connected.
tipstir is offline
post #542 of 1791 Old 01-19-2012, 12:03 PM
HDSapper's Avatar
Quoted: 49 Post(s)
Liked: 45
Originally Posted by HDSapper View Post
They just replied that they would process an exchange.
Just an update. Even though customer service responded fairly quickly and decided that my remote was defective and needed to be replaced, it's been 9 days now with no update on when and how they will replace it. I still believe it's a decent product when it's working, but their customer service is lacking. Very frustrating. I paid for next day shipping to get it two weeks ago, and haven't been able to use it yet.
HDSapper is offline
post #543 of 1791 Old 01-24-2012, 01:19 AM
tipstir's Avatar
Got my 650 and 700. Funny the 700 said it only supported 6 devices but the one I got it read 8 devices. Now that issues that started in this thread about unable to sync on 650. I just had that issue. Even resetting the H650 didn't help. I even deleted all my activities. Real pain. That didn't help. I had to change all of those 23 icons to text base that worked! So the 650 has a limited data storage for graphic icons. I am using the default size I made them myself so they use the lease of amount of memory. But everything was working until I change my DSTB over to HDMI1 and doing so it won't sync. Now it does... I should have spend the extra on the 700 or get the HONE instead. Too late..
So spending extra $10 so I can have color and most of the color is limited to red background and it's the same on the 700 too. Might as well just had purchased a couple more 600. I like the way the 600 looks day or night. The 650 is a dark grey with orange for backlight. The 600 and 700 are the best for backlight though.
tipstir is offline
post #544 of 1791 Old 01-25-2012, 10:16 AM
jeep05's Avatar
Quoted: 180 Post(s)
Liked: 217
My Samsung AV Receiver has Samsung Apps. On the Home Menu screen of the AVR they have to be accessed by selecting the Internet@TV icon on the screen. Can an activity be set on my 650 to go straight to the Apps page instead of having to select the icon on the Home Screen? The input used to get to the Home Screen is BD/DVD. I use MyHarmony and i don't think it can be done there but maybe with the 7.7 software?
jeep05 is online now
post #545 of 1791 Old 01-25-2012, 01:46 PM
mdavej's Avatar
Quoted: 2276 Post(s)
Liked: 992
Yes, with 7.7 just add more commands to the start of your activity.
mdavej is online now
post #546 of 1791 Old 01-26-2012, 05:20 AM
jeep05's Avatar
Quoted: 180 Post(s)
Liked: 217
Thank you
post #547 of 1791 Old 01-26-2012, 09:27 PM
mdavej's Avatar
Liked: 992
Radio shack has the 600 for $39.99 at the moment which is a better price than most.
post #548 of 1791 Old 01-27-2012, 04:22 AM
Oredigger's Avatar
Newegg has a refurbished 650 for $45.
Oredigger is offline
post #549 of 1791 Old 01-27-2012, 12:14 PM
jeep05's Avatar
Quoted: 180 Post(s)
Liked: 217
mdavej, i plan on switching my 650 from MyHarmony to 7.7 this weekend. should i clear the 650 before downloading 7.7 or will it just overwrite the settings? Also, if i decide to go back to MyHarmony, do i need to clear the 650 and just log back into MyHarmony and re-sync the remote or are all settings from there lost?
post #550 of 1791 Old 01-27-2012, 01:27 PM
mdavej's Avatar
Liked: 992
No need to clear first. Each sync will completely overwrite the old config. You can go back and forth any time. Nothing is lost since each login and associated config is unique and independent of the others.
post #551 of 1791 Old 01-27-2012, 05:50 PM
jeep05's Avatar
Quoted: 180 Post(s)
Liked: 217
post #552 of 1791 Old 01-27-2012, 08:43 PM
Nick_WI's Avatar
Quoted: 31 Post(s)
$5 more for a brand new one at BestBuy.com.
__________________________________________
Visiting since 2002!
Nick_WI is offline
post #553 of 1791 Old 01-30-2012, 09:13 AM
JMSpeed's Avatar
Good stuff in here!
Is it possible to assign one of the color buttons an activity?
For example, and a similar situation was presented earlier, I want to watch TV on a cable box and have full access to cable box settings. But, on occasion I'd like to customize TV settings, enable 2D-3D, use apps, etc. The solution presented was to create a new activity.
I was thinking, if possible, it might be easier to hit the blue button and have the remote change to TV controls, then hit the blue button again (or red/green/etc.) to switch back to default cable box controls. Has anyone been able to do this or know if it is possible?
I wouldn't mind having a button select a certain TV command, but the result is usually followed by a yes/no prompt where I need to hit the "ok" button, which happens to be linked to cable box control still.
JMSpeed is offline
post #554 of 1791 Old 02-05-2012, 10:05 AM
fatespawn's Avatar
Originally Posted by 91bball View Post
got a 650 for Christmas and set it up using the myharmony site per the instructions. Setup was smooth and easy using that interface. But the remote was very laggy on the cable box menu screens (comcast motorola dcx-3501/rng200n). After some research, I downloaded the 7.7 software and re-setup my remote. Wow, it's like a different remote now, no lag on the menu screens whatsoever. Tons of more options with the software. Just wanted to point this out to any newbies like me who used the myharmony site.
How did you set up the dcx-3501/rng200n with the 650? I can't find instructions anywhere.
I am am a long time Harmony user (720/890/650) but can't seem to find info on this Comcastic Set top box.
-fate
fatespawn is offline
post #555 of 1791 Old 02-05-2012, 03:21 PM
mdavej's Avatar
Liked: 992
Model RNG200 should work fine.
post #556 of 1791 Old 02-07-2012, 12:02 PM
rdn
rdn's Avatar
I added a WD HD Live Plus to my setup and it isn't in Logitech's database .
I set it up by learning from the stock remote but some of the commands didn't stick, although the 7.7.0.0 software indicated that it accepted the command .
To make it worse, when the data was flashed to the 650, some commands for a different device were forgotten .
I had to relearn some of these commands several times before I had everything back as it previously was. THIS IS UNACCEPTABLE!
Edit: I upgraded to the latest firmware and that appears to have helped (I wish I had thought of that first).
Bob
rdn is offline
post #557 of 1791 Old 02-07-2012, 02:06 PM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
Are you using MyHarmony or the Harmony client software?
Using the 7.7 client software, I was able to add "Western Digital" "TV Live Plus" as a Digital Music Server and it had what appeared to be a full complement of commands in the database:
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • A
  • Audio
  • B
  • Blue
  • C
  • D
  • DirectionDown
  • DirectionLeft
  • DirectionRight
  • DirectionUp
  • Eject
  • FastForward
  • Green
  • Home
  • Mute
  • NextTrack
  • OK
  • Options
  • PageDown
  • PageUp
  • Pause
  • Play
  • PowerToggle
  • PreviousTrack
  • Red
  • Return
  • Rewind
  • Search
  • Setup
  • Stop
  • Subtitle
  • Yellow
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #558 of 1791 Old 02-08-2012, 09:10 AM
rdn
rdn's Avatar
I'm using the 7.7 software on a Mac. I don't see any option under "Digital Music Server" to choose Western Digital but I'll try it with "not listed". Many of the mapped commands do not exist on the stock remote and at least one is missing but I'll use the learn mode for that one.
Thanks for the suggestion.
Bob
rdn is offline
post #559 of 1791 Old 02-08-2012, 09:45 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
I selected "not listed" and typed in Western Digital, then the model.
post #560 of 1791 Old 02-08-2012, 03:10 PM
rdn
rdn's Avatar
I tried that as well. There is a Western Digital entry under Media Center PC which someone on the WD forum suggested.
I think my real problem is that the settings aren't getting transferred to the remote (some do but others are missing), which points to a hardware issue. I have submitted a support request to Logitech customer support (which has been quite helpful in the past).
Bob
rdn is offline
post #561 of 1791 Old 02-08-2012, 03:55 PM
mdavej's Avatar
Liked: 992
If you are new to harmony, a common error is to make changes to a device and expect those to show up in your activities. They won't. You must customize buttons on your activities as well. And don't forget to Sync (or Update depending on your software).
post #562 of 1791 Old 02-08-2012, 09:54 PM
rdn
rdn's Avatar
That's not the problem. I have only used the 650 for six months but had a 880 for several years (until my wife spilled coffee on it and several buttons no longer worked)
Edit:
I heard back from Logitech and they wanted some more information, which I sent this morning. I tried uploading to the remote several times and got a different result (which keys worked or not) each time. I'm at a point where it is much better than at first (but at least one key doesn't work in one of the activities).
Edit (2):
After several days and numerous emails back and forth, Logitech said that the free support is only for 90 days (I have had the 650 for nearly 7 months and the warranty is for 1 year) and I would have to obtain paid support. I'm through with Logitech at this point and will try a URC R50 programmable remote.
Bob
rdn is offline
post #563 of 1791 Old 02-12-2012, 12:25 AM
katjbus's Avatar
I have had my 650 for a year this month and some of the buttons that control my bluray I have to push like 4 times replaced batteries and still does it anyone else have this problem?
katjbus is offline
post #564 of 1791 Old 02-12-2012, 05:05 PM
antneye's Avatar
damn dog at the channel button off of my remote.....any idea if those parts can be bought anywhere?
antneye is offline
post #565 of 1791 Old 02-12-2012, 05:11 PM
hydrotex's Avatar
I would like to have a single button toggle on and off "closed captions" on my digital set top box (U-verse DVR). As it now I have to go through several menus to get to this function. Any help would be greatly appreciated.
hydrotex is offline
post #566 of 1791 Old 02-12-2012, 07:00 PM
Geezer's Avatar
Quoted: 20 Post(s)
Saw new ones at Costco today for $44
Geezer is offline
post #567 of 1791 Old 02-13-2012, 07:27 AM
kpot's Avatar
Hi all,
I used to have Harmony 895 remote. It was working fine but suddenly the LCD was dead.
I plan to buy the new Harmony 650.
Do you know if it is possible to import the settings (setup) from Harmony 895 to Harmony 650?
I was using the Harmony software 7.7 to setup my Harmony 895.
If this is possible, it is complicated process?
kpot is offline
post #568 of 1791 Old 02-13-2012, 07:29 AM
rta53's Avatar
Another reason to get rid of the dog.
rta53 is offline
post #569 of 1791 Old 02-13-2012, 07:29 AM
antneye's Avatar
Those are some expensive buttons!
antneye is offline
post #570 of 1791 Old 02-13-2012, 07:53 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
Originally Posted by kpot View Post
Hi all,
You should be able to use the "replace remote" function in the 7.7 software... devices and basic activity setups should carry over but almost certainly you will have to redo your any custom button setups.
If for some reason you want to keep the old setup intact, you can request that Harmony clone the account... then you can keep one for the 895 and replace the remote in the other.
Reply Remote Control Area
