Official Logitech Harmony 650/600 remote thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #721 of 1716 Old 01-11-2013, 08:34 PM
Bri in Mtl's Avatar
Personally I like the MyHarmony. I tried both and felt it's easier to use but there are more settings you can adjust with the software version.
For my Samsung TV device there were more pages/buttons available on the LCD screen with the MyHarmony.
Bri in Mtl is offline
post #722 of 1716 Old 01-11-2013, 09:23 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Originally Posted by lovinthehd View Post
As far as I'm aware only that really crappy low end Harmony used the special site/software and pretty sure that was called myharmony, all the others use the same software...I've got version 7 myself. If you want to retain settings for a particular remote then yes you want to establish a new user id/pw for another remote; I do that for my 600/650 as there's no option (or was) for separate models in the same account.
Thanks for the quick reply. Needless to say, I'm eager to get started and got de-railed just as I got started.
While I was waiting and researching, I also found this thread:
http://logitech.lithium.com/t5/Remote-Control-Software/Do-you-use-the-software-or-myharmony-com/td-p/897910
Basically, you both say the same thing. So I will use my pre-installed Desktop v7.7.0 (yes, still the latest version) and create a new account for the new remote.
I really like their remotes (there is no equal AFAIK) but some things are pretty lame.
- None of their software appears to support multiple remotes (need separate accounts for each) ... still after all these years.
- They created new "cloud based" software (for the only the new remotes ... which is understandable) but it's not as full featured as the desktop software that it is positioned to replace.
- The 650 now uses a new proprietary cable, while the old remotes (like a 670) used a standard mini-USB connection.
Nothing I can't live with, but these ... and the current official Harmony line-up ... kinda makes you wonder what is going on over there.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is online now
post #723 of 1716 Old 01-11-2013, 09:34 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Interesting. I suppose I should withhold judgment on MyHarmony until I actually try it myself.
I am already familiar with the Desktop software. I still use it for my 670.
I suppose what it comes down to is that I would like to setup the new 650 only once. There is a XBMC MediaCenter involved (and 5 other devices), so it will be fairly complex. I would like to build the config in the definitive full-featured program that I am suppose to use for full-functionality.
post #724 of 1716 Old 01-11-2013, 11:04 PM
oryan_dunn's Avatar
Quoted: 98 Post(s)
Liked: 67
The 650 uses a standard USB called microUSB. Other than Apple, it's the global standard on cell phones as well as a lot of other equipment.
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is online now
post #725 of 1716 Old 01-11-2013, 11:19 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Thanks, not sure how I missed that ...
Ok, so they went from from Mini-USB to Micro-USB ... no biggie. I retract that bullet.  smile.gif
post #726 of 1716 Old 01-11-2013, 11:24 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Ok, so for XBMC (a popular Media Center like app) running on Windows 7 (64bit) using RC6 compatible remote (just happens to be a HP model).
I'm building it from scratch (all learning and custom). I called it Windows 7 RC6 XBMC.
Does that get uploaded to logitech.com? Can you guys use it now? Is that one of the ways the database gets built-up?
post #727 of 1716 Old 01-12-2013, 04:39 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
There's no need to reinvent the wheel. Add a new device under "Media Center PC"
Manufacturer = Microsoft
Model = Windows Media Center SE (I know that you're using XBMC, but the commands are the same)
This code set gives you the most options for commands including many keyboard shortcuts.
Dropkick Murphy is offline
post #728 of 1716 Old 01-12-2013, 05:13 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I could never get my 300 setup with the special website programming (assuming that's what is being called MyHarmony?). I had to return the 300 since I could never get on the site to set it up.
lovinthehd is offline
post #729 of 1716 Old 01-13-2013, 01:14 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
It gives enough to control XBMC pretty good, but to do things like Start XBMC and other things inside ... advanced things inside XBMC, you also need the Media Center Keyboard device .
http://www.avsforum.com/t/1295315/how-to-use-a-harmony-remote-to-seamlessly-use-xbmc-hulu-desktop-and-netflix
I'm maxed on devices already, so I can't add another (and have 2 dedicated for XBMC use).
I was trying to do this "cleaner" than the way I setup the other machine with 670. Guess I'll fall back to the more complicated way and hack on XBMC some.
post #730 of 1716 Old 01-13-2013, 01:17 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Originally Posted by Culpepper View Post
Indeed you can. I have tweaked my 650 to control 7 devices this way. Not ideal, but it works.
Looking at this ...
Looks like you can add custom learned buttons (even from a second remote) but the keys get entered as a generic name and can't be changed. Looks like you can change the displayed name, but not the actual function. I guess you keep a list of how they are really mapped?
post #731 of 1716 Old 01-13-2013, 01:29 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
This system has a working amp and plasma, but they are 10 years old. I can't use the amp as a switcher like we normally do these days. I have to switch inputs on plasma and amp on each activity.
The plasma is having a problem selecting the proper Input, especially when first turning on. Help button fixes it eventually (but who wants to use that always).
post #732 of 1716 Old 01-13-2013, 03:18 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
This system has a working amp and plasma, but they are 10 years old. I can't use the amp as a switcher like we do these days. I have to switch inputs on amp and plasma on each activity.
Well, it wasn't what I thought. My fault because I don't actually use this TV remote much.
It seems you have to press Component button once for Comp1 and twice for Comp2. All the other Inputs have their own keys. Cycling through the Inputs (with the Source button)  is very lame and there are other problems with this way. Investigating a better solution.
post #733 of 1716 Old 01-13-2013, 12:18 PM
Culpepper's Avatar
Looking at this ...
I'm not quite sure I understand what you mean. In my case, my AVR is a part of all activities. So I learned (taught?) all needed commands for the extra 2 devices into the AVR's command list, including naming them appropriately. Then, I can create new activities using those available commands to control the extra devices. Does that make sense? Hard to explain. :-)
Culpepper is offline
post #734 of 1716 Old 01-13-2013, 01:26 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Yes, perfect sense.
It's just that when you first Learn them, it is calling them MyNewCommand1, MyNewCommand2, etc. I didn't see a way to rename them. I also don't see a way to Delete them. On same screen, if you over-ride the Database profile for a Command by learning it with the real remote ... I don't see a way to revert that back to the default Database setting.
The only way I saw to reverse or undo any learned functions was to delete device and start over.
post #735 of 1716 Old 01-13-2013, 03:25 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Amazingly, got it to work without config-ing to cycling though all TV Inputs every time. Pretty cool Harmony made allowance for this.
So you leave Samsung plasma's Input Switching on Type #2 Default (each Input has unique key).
Set both Watch TV (Component-2) and Watch DVD (Component-1) ... to Component-1 in normal setup.
Then, go back into Watch TV Activity and add a Custom Action to the list. It was something like "Change Component key State to Component 2"
The custom Activity line now reads:
4 - Samsung Plasma - SetComponentInput Component 2 - Remove - N/A
Also, moved Plasma to be turned on first (in every Activity it is a part of) just to make sure it has time to power up before Inputs are attempted to be changed, but the real problem was the toggled Component button.
post #736 of 1716 Old 01-13-2013, 03:54 PM
oryan_dunn's Avatar
Quoted: 98 Post(s)
Liked: 67
There should also be a setting for power-on delay for the TV.
post #737 of 1716 Old 01-15-2013, 05:49 PM
uclabruinn's Avatar
Has anyone set up their 650 to run the new Samsung Smart Hub?
uclabruinn is offline
post #738 of 1716 Old 01-15-2013, 06:34 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Not sure if this helps, but I setup VieraCast (a similar thing) on my Panasonic plasma as a seperate Activity. This was on my Harmony 670. but that doesn't matter (they program the same)
IIRC, you add a custom action (line item) that presses the button that gets you into the interface.
From there, you just use the TV's remote. The TV is already part of the Activity, so those keys should be available for assignment (to real keys or little display).
Edit. But come to think of it, I only did that because I had to switch some Inputs. For you ... if you have AudioReturnChannel working, you might just be able to add the SmartHub button to the normal watch TV Activity (maybe on the little display).
post #739 of 1716 Old 01-15-2013, 08:19 PM
uclabruinn's Avatar
Thank you! I appreciate your input. Anyone else deal with the Samsung smart hub directly?
post #740 of 1716 Old 01-17-2013, 10:37 AM
Wise Man's Avatar
hi i use to have harmony 300 now i have the harmony 600 and i am having trouple setting it up, first lets say i am in a watch tv
activity, and i want to go to one device to do something with it, i press devices and chose the device i want to do the change with, now
how do i go back to watch tv activity how do i do that, if i press the watch tv activity on the remote everything would turn off??
that means if i press watch tv activity once it would turn on the devices involved, and if i press it again it would turn off the involved
devices in that activtiy , and i really dont want that, i want is when i press the activity it just turns on and never off any of the devices
involved in that activity?! activity set up
Wise Man is offline
post #741 of 1716 Old 01-17-2013, 11:46 AM
lovinthehd's Avatar
Liked: 4775
You need to go back to the activity you were in, the center button underneath the window will take you back to the activity you were in (i.e. just the reverse of how you got to the device from the activity)
post #742 of 1716 Old 01-17-2013, 12:38 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
As long as the device is part of both Activities that you jump between ... it remembers that the device is already on, so it doesn't send the PowerToggle code again. However, it might re-send any Input switching ... which should be desired (or at least not hurt anything).
This happens even when you have the Activity set to "turn off devices that aren't being used" (which should be the default).
I also suggest you add commonly used Device Functions to the Activity Screen. You can add them to "Additional" tab, and they will be on little lcd (which can be scrolled). They can be for any Device that is part of that Activity. By doing this, I hardly ever use the Device selections themselves.
Now, you can have many Activities and not just one for "Watch TV". I think that is the big difference between 300 and all the others (like 600,650, etc). Also, note that Activities and Devices have their own different kinds of Settings. Put everything on an Activity ... Watch TV, Watch DVD, Use Computer, Listen to CD, Listen to FM Radio, etc.
post #743 of 1716 Old 01-17-2013, 01:09 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Well, I got the 650 all programmed up for my WorkOut room system.
I'm really liking it. The motion detector (for screen and keys backlight) is a cool feature. On my older 670, I have to press the BackLight key (but only at night ... it's monochrome LCD is always on, and even visible in daytime with no backlight.). If it wasn't for the 5 Device limit, I would move 650 into the main room.
Not bad ... I did both rooms for $120.
post #744 of 1716 Old 01-17-2013, 06:55 PM
Culpepper's Avatar
Yes, perfect sense.
When you click the "Learn IR" button of the "host" device, and scroll all the way to the bottom to "Learn a New Command" it defaults to "MyNewCommand." Simply highlight that text and type in an appropriate name for the command. No need to delete a command -- just don't use it or overwrite it with a different command.
post #745 of 1716 Old 01-18-2013, 08:51 AM
davelr's Avatar
Quoted: 28 Post(s)
ReadMeFirst.rtf 10k .rtf file
Thought I'd revive this topic to offer another approach. You should download and install the XBMC Add-On "MCERemote". This tweaks the registry mappings of the codes sent by a MCE remote (like the Harmony with the MCE SE device loaded) to more correctly match the controls used by XBMC. Just installing and running the addon fixed a number of little quirks I was having.
In addition to the basic fixes, the addon allows you to customize the "button-to-code" mapping table. This coupled with the ability to map the Harmony should allow you to accomplish most anything you need. Even if not, you can edit XBMC's keyboard/remote map xml file to change the functions that are associated with keystrokes and button presses.
You should note that just installing the AddOn is not enough to get it to work, which was a mistake I made. Once it's installed you have to go to Programs / Add-Ons and actually run MCERemote code. There is an instruction (readmefirst.txt) file, but you need to open it in wordpad or word as it only displays in streamed text in Notepad and is hard to read. The instructions are pretty clear once you can read them. I've attached the instruction file as an RTF so it's a little easier to read.
This really solved a number of control problems I was having with XBMC. Good luck
davelr is offline
post #746 of 1716 Old 01-19-2013, 11:14 AM
jmborah's Avatar
Hi All, just stumbled upon this forum in my frustration with my Harmony 650. I have 1 main gripe which I would like to fix, and other minor gripes about this remote. Like others, I was very excited about being able to "program" my remote, but once I tried to use logitech software to solve specific problems I found that the cookie-cutter approach they use to script activities is really annoying.
Main gripe: I am able to set each "activity" to use TV volume, but I would like to override device volumes as well, to make TV my master volume no matter what device or activity I am on. For example, if i am on my apple tv device, the remote does not use the TV volume, in fact the volume does not work at all on that device because there is no volume associated with apple tv. I mean, come on logitech, really? So basically I'd like to make TV vol my master vol.
MInor gripe: When I switch between activity it must turn on devices that are already on, usually turning them off. Again, come on logitech, really? Part of this is due to the fact that I can not disable TV on the activity because then I would not be able to control the volume later on, so it therefore can not be removed from the activity startup script. So my gripe has to do with the limited definition of devices associated with activities and lack of control over scripts and what devices/buttons can be programmed.
I would also like to add 2 more devices to my 650, but that's my own fault for not anticipating additional hardware when I bought it.
I searched for hacks, but did not find anything I could figure out on my own. I don't know how to compile, so concordance is over my head.
I apologize if these issues were previously covered in the thread, but I wasn't able to read through the entire 25 pages. Thanks in advance for any help or advice.
-Jon
jmborah is offline
post #747 of 1716 Old 01-19-2013, 05:34 PM
mdavej's Avatar
Quoted: 2127 Post(s)
Liked: 940
I share your criticisms, so much so that I won't use harmony myself. But there are a few things you can do.
Setting up your activities "manually" gives you complete control over what devices are in them. Then you can customize buttons to add vol commands or whatever you like from any combination of devices. The best course of action though is to make a couple of versions of each activity, like Watch TV with TV vol and Watch TV with AVR vol. That's how harmony is designed to work.
You have no control over the default activity macro steps, but if you use the standalone software rather than myharmony.com you can add additional commands to your activities like extra discrete on commands if the state tracking isn't reliable.
Switching activities should not turn off common devices, so I suspect something else is going on there. Do you use help to get the tracking back in sync? Are you using harmony exclusively, or do you sometimes use other remotes. If you don't use harmony exclusively, the state tracking won't work. You can also modify the power settings for each device so your macros use discrete power commands when possible.
You also need to design your activities to minimize the need to go to device mode. So add any devices you often switch to and related commands to your activities.
Concordance is really of no benefit. It won't give you additional devices. I can help import pronto hex, but that's about it. The only ways to pass the device limit are to upgrade from another harmony model with more devices or to combine devices by learning.
Hope that helps get you on the right track.
mdavej is offline
post #748 of 1716 Old 01-19-2013, 08:19 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Thanks. Yes, this is what I ended up doing (just using MCERemote in XBMC-Eden). This is also how I did the other system last year with the 670. It wasn't as hard as I remember it being.
Do you ever try to do anything from the Windows desktop (like maybe load XBMC) with the Harmony? For help with that, that's why also adding the MCE Keyboard device looked interesting.
post #749 of 1716 Old 01-19-2013, 08:32 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
-Jon
Use the Desktop software v7.7.0.
Main: Well, it asks you which device controls the Volume ... just say TV. It's the same as me using the Amp for everything volume.
Minor: You can say "leave devices on" but then you have to add the Power button as part of the Activity screen (so you don't have to visit Device screen). But if TV is always volume, just make it a device in all Activities. This would be the same as you using the discrete remotes.
More devices ? You are suppose to be able to add buttons from other remotes (see above posts). Learn buttons and put on TV or other Device that is in every Activity.
post #750 of 1716 Old 01-20-2013, 08:39 AM
jmborah's Avatar
Thanks for replies, I appreciate some of the work-a-rounds you suggested. I will likely have to add additional activities as suggested, and play around with "learning" some new devices on to existing controls. Not perfect, but still better than having a dozen separate remotes. Thanks!
jmborah is offline
Reply Remote Control Area
