Official Logitech Harmony 650/600 remote thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1231 of 1769 Old 06-07-2014, 02:54 PM
akrover90's Avatar
Thanks you guys very much for the info!
akrover90 is offline
post #1232 of 1769 Old 06-10-2014, 11:30 AM
herts101's Avatar
Wonder if someone can help me in relation to buying the 650 from Amazon.
They list it twice:
The 'Logitech Harmony 650 Universal Remote - Refresh' model no. 915-000161, which despite it's name is listed as the older item; and
The 'Logitech Harmony 650 Remote' model no. 915-000229.
The old one is cheaper (currently £47 vs £62). No other sites seem to specify which one they have.
Is there a real difference between the two? Not sure which I should buy.
Any help appreciated. Thank you.
Peter.
herts101 is offline
post #1233 of 1769 Old 06-12-2014, 10:22 AM
HarmonySylvain's Avatar
Quoted: 106 Post(s)
Liked: 52
Originally Posted by herts101 View Post
Wonder if someone can help me in relation to buying the 650 from Amazon.<br><br>
They list it twice:<br><br>
The 'Logitech Harmony 650 Universal Remote - Refresh' model no. 915-000161, which despite it's name is listed as the older item; and<br>
The 'Logitech Harmony 650 Remote' model no. 915-000229.<br><br>
The old one is cheaper (currently £47 vs £62). No other sites seem to specify which one they have.<br><br>
Is there a real difference between the two? Not sure which I should buy.<br><br>
Any help appreciated. Thank you.<br><br>
Peter.
Hi herts101,
There is no difference between the 'regular' 650 and the refresh. Both will get the latest firmware during setup and will allow you to control 8 devices.
As for the difference in price, the £62 model states it is 'dispatched and sold by Amazon' whereas the £47 model is sold by a seller called oko's.
Sylvain
HarmonySylvain is offline
post #1234 of 1769 Old 06-18-2014, 11:48 AM
Liked: 0
Navigation problem
Hi everyone, hoping someone has come across this before
I've just set up my first 650 and all went well except for one thing... I have set up sequences to jump to particular apps through a roku 1 and a sony bd player. The remote goes through the necessary steps but when I arrive at say, iPlayer, the navigation buttons no longer work.
All I can think of is that once the app in question has been started up, the control has been given back to the TV while it should be with the streaming device. Any ideas how I can change this?
Thanks in advance!
Dodo13 is offline
post #1235 of 1769 Old 06-18-2014, 12:34 PM
mdavej's Avatar
Quoted: 2183 Post(s)
Liked: 958
Each activity has certain groups of keys associated with different devices. In your case, you should make activities for each case and choose the appropriate playback device accordingly. For example, make a Roku or iPlayer activity that uses the Roku as the playback device. Make a different activity for your Sony apps with the Sony as the playback device. Then rebuild your sequences in each new activity.
If this is not the problem, and it's really an HDMI control issue (CEC), then just turn that off in all your devices. CEC isn't going to work well with Harmony anyway.
mdavej is offline
post #1236 of 1769 Old 06-18-2014, 01:04 PM
Liked: 0
Thanks, I'll give that a bash when I get home!
Dodo13 is offline
post #1237 of 1769 Old 06-18-2014, 03:55 PM
Liked: 0
The problems still remains I'm afraid.
Just to clarify using one example - I have an activity called iPlayer that switches on the Sony TV to the correct input, then turns on the Roku, then selects the right input on the av switcher, then performs a couple of navigation moves on the Roku to start the iPlayer app.
This all works fine, but then when I try to play anything in the iPlayer app, the remote does not have any effect on it. However, any buttons I press now control the Sony TV, changing channels etc.
What I find I then have to do, is manually change device on the remote to Roku, and the control comes back.
Hopefully that's a bit clearer!
Dodo13 is offline
post #1238 of 1769 Old 06-18-2014, 04:01 PM
mdavej's Avatar
Liked: 958
So the physical buttons in the activity never worked. In that case, customize the buttons in your activity and assign each to the Roku. The activity setup should have taken care of that automatically when you chose the Roku as your playback device, but apparently the wrong choice was made or it failed for some reason.
mdavej is offline
post #1239 of 1769 Old 06-19-2014, 12:58 AM
Liked: 0
Cheers mate, I'll give that a bash!
Dodo13 is offline
post #1240 of 1769 Old 06-20-2014, 01:43 PM
Quoted: 106 Post(s)
Liked: 52
As mdavej said, it does seem like your Roku should be your primary control device, but it's somehow the TV instead. Would you mind sending me your MyHarmony email ID via PM for me to see what's happening in your account please? Your password is not needed.
post #1241 of 1769 Old 06-22-2014, 08:15 PM
ProTuber's Avatar
imported settings from 880 with flaky buttons
My wife was getting tired of buttons not working reliably on the Harmony 880 we have been using for the last 6+ years. Wanted the features I had grown accustomed to but didn't really want to shell out $250+- for a new remote with similar capabilities, I was toying with the idea of a 650 but had reservations because of the 5 device limit. Was pleased to discover recent posts and web ads indicating this as an 8-device remote. Bought one this weekend and imported the settings from my 880. Most of the commands were converted correctly. The only real problem I had is that for some reason the code for InputAntenna on my Samsung plasma was really InputAB that switches between the 2 RF inputs and InputAB was not in the list of commands. Had to teach the remote InputAntenna and then add the InputAB command from the 880. I did appreciate the MyHarmony app allowing sequences longer than 5 steps as it takes more than that number of keystrokes on the Scientific Atlanta 8300 STB to program such things as turning captions on and off.
ProTuber is offline
post #1242 of 1769 Old 07-14-2014, 02:43 AM
jinxxxxxx's Avatar
Programming offline
Is it possible to program the 650 with out depending on the logitech site. Call me old but I don't like having to depend on Logitech to program this remote. I have been using computers since the 1980s and have had to retire a lot of good equipment because the manufacture has stopped support.
jinxxxxxx is offline
post #1243 of 1769 Old 07-15-2014, 06:53 AM
insync44's Avatar
Quoted: 24 Post(s)
No.
insync44 is offline
post #1244 of 1769 Old 07-15-2014, 07:17 AM
mdavej's Avatar
Liked: 958
Actually you can. But I find it very complicated, and this is coming from a JP1 guy. Your 650 will wear out long before myharmony goes away, so may as well just stick with that. If you want a remote like Harmony that's affordable and can be programmed offline, grab an Xsight Touch from ebay. They're fantastic and will run circles around a 650. Remote Master is working very well with Xsight now. So the programming website could shut down tomorrow and you could still program your remote offline indefinitely.
http://www.phildev.net/concordance/
mdavej is offline
post #1245 of 1769 Old 07-17-2014, 03:11 AM
kneo's Avatar
There's an option to map buttons from other devices to the LCD screen, but when one does this, the control of the remote does not change to that particular device. So for example, as part of the 'Watch Bluray' activity, I have the volume mapped to the receiver and the rest of the buttons (play/pause/stop/forward/reverse) are automatically mapped to the bluray player. But now if I add a custom action called 'Options' (which is actually the options screen of the AVR) to the remote's LCD screen, the control would not change to AVR if I press the 'Option' entry on the LCD. I have to manually go to 'Devices' and then select 'AVR' to have the remote control the up/down/left/right arrow buttons on the Option screen which shows up.
Any workaround for this?
kneo is offline
post #1246 of 1769 Old 07-17-2014, 07:22 AM
mdavej's Avatar
Liked: 958
You could add the arrows to the LCD as well. Realize that you can return to your activity from device mode with a simple double press of the Activities or Devices button.
Or you could make a sequence for all the steps you have to use the arrows to perform, hence no arrow buttons required.
Or you could find a discrete code to perform whatever you're navigating to in options and use that instead.
Lastly, assuming you don't use the number pad when watching blu-ray, just turn it into an arrow pad for your AVR by reassigning the arrow commands to the number keys.
kneo likes this.
mdavej is offline
post #1247 of 1769 Old 07-25-2014, 03:29 PM
THX1720's Avatar
Quoted: 70 Post(s)
Liked: 59
I just picked up a 650 the top buttons and the ones on the side of the LCD aren't lit
Should they all be lit? Here's a pic. Thanks in advance!
THX1720 is offline
post #1248 of 1769 Old 07-26-2014, 01:36 PM
davelr's Avatar
Quoted: 28 Post(s)
They don't glow on either of mine.
davelr is offline
post #1249 of 1769 Old 07-26-2014, 02:05 PM
THX1720's Avatar
Quoted: 70 Post(s)
Liked: 59
Thanks! I guess that's the way it was designed..
THX1720 is offline
post #1250 of 1769 Old 08-05-2014, 09:00 AM
butie120's Avatar
Quoted: 483 Post(s)
Liked: 85
Has there been a consensus whether the 650 works with the Next Gen remote or not? I read one post on a different forum about removing some white sleeve beneath the batteries and placing this on top, and putting the transmitter on the right hand side, but who knows. I know the RCA remotes work well with it, but the RCA's won't program to my Denon 2112CI receiver. But, if the Harmony 650 can't connect to the Next Gen I have to find a new remote.
Thoughts? Thanks!
butie120 is online now
post #1251 of 1769 Old 08-05-2014, 11:17 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Thoughts? Thanks!
Any of the two piece remote extenders should be compatible with the Harmony 650. Of course, this would require pointing the remote at the transmitter which isn't necessary with the Next Gen because the transmitter resides in the remote's battery compartment so not as elegant as the Next Gen but certainly functional if the Harmony 650 is a must.
Vin
Vin is offline
post #1252 of 1769 Old 08-05-2014, 11:42 AM
butie120's Avatar
Quoted: 483 Post(s)
Liked: 85
So, are you saying that the 650 should work just fine with the Next Gen Remote Extender? I'm just confused because some people say it works, others say it doesn't, and then their website says it's not compatible. I just don't understand. I would love if it could work because an IR extender wouldn't work in my situation. I need the RF capability that the Next Gen has because my devices are behind me.
post #1253 of 1769 Old 08-05-2014, 12:00 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
No, the Next Gen isn't likely to work with the Harmony 650. There are countless other remotes that it will work with though that can be programmed to control your Denon AVR.
If you're really hoping to use the 650 but don't have line-of-sight to your components a 2 piece remote extender will do the same thing as the Next Gen. The difference is that the transmitter is a separate piece that you can place in the front of your room where your TV is. The transmitter converts the IR signal from the remote to RF and sends that signal to the wireless remote receiver in the back of your room (where your components are located) where the RF signal is converted back to IR allowing your IR components to accept and carry out the command.
The Next Gen functions the same way, the only difference is the transmitter (the device that converts IR to RF) is in the remote's battery compartment instead of in the front of the room.
Vin
Vin is offline
post #1254 of 1769 Old 08-05-2014, 12:23 PM
butie120's Avatar
Quoted: 483 Post(s)
Liked: 85
Got it. Thanks for the clarification. I don't need to use the 650 but it has gotten good reviews so I thought it would be good to get. I can't get a two piece remote extender because the front of my room is a projection screen with three speakers. I'd rather not have to plug something in around that area.
Which brings me to my next question: Is there a remote, that's preferably backlit, that will work with the Next Gen and is on par with the 650? I tried two RCA 4 device from Best Buy, neither of which could pair with my Denon 2112CI. Maybe I need a remote that isn't preprogrammed and one that can add devices? I don't know.
Any ideas out there? Thanks for your willingess to help. Much appreciated!
post #1255 of 1769 Old 08-06-2014, 10:32 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I use this one with the Next Gen and it works fine...it's no Harmony 650 (which I also use in another set-up that doesn't require RF capability) but it's a backlit learning remote with macro capability and it gets the job done...personally, I really like this remote for the price. Best Buy carries this RCA with the same features and should work similarly.
Vin
Vin is offline
post #1256 of 1769 Old 08-12-2014, 03:28 AM
gkf9's Avatar
Originally Posted by jcalabria View Post
Quote:Originally Posted by akrover90
My daughter broke my harmony one screen a while back but I was hesitant to replace it because I don't want to have to reprogram and I know from my 650s that I would have to use the new software. However, after reading part of this thread is it correct I can use the 'replace remote' button in the 7 software to replace a One with a new 650? No reprogramming? Really hoping that is the case.
Yes... you should be able to do that.  The basic setup will carry over (devices, activities, inputs setups, etc), but the custom button programming will almost certainly not carry over (it just doesn't when you change remote models).  You will have to reprogram that.
How do you copy settings over from the 7.7.0 software to My harmony?
Tia
gkf9 is offline
post #1257 of 1769 Old 08-12-2014, 05:53 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 115
Tia
I don't believe that you can, except in the case of an Ultimate (my son migrated one of his Ones to an Ultimate and the Ultimate setup offers that option while "lesser" remotes do not). The OP I was responding to was concerned about being able to STAY with 7.7 software for a new 650 replacing a One... that is a straightforward "Replace Remote" in 7.7. 7.7 allows this, but does not allow a new account to be set up for a 650.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #1258 of 1769 Old 08-12-2014, 11:25 AM
gkf9's Avatar
I don't believe that you can, except in the case of an Ultimate (my son migrated on of his Ones to an Ultimate and the Ultimate setup offers that option while "lesser" remotes do not). The OP I was responding to was concerned about being able to STAY with 7.7 software for a new 650 replacing a One... that is a straightforward "Replace Remote" in 7.7. 7.7 allows this, but does not allow a new account to be set up for a 650.
Ok thanks for the info, think I'll set the new 650 up in my old account, then set the old 600 up through the Myharmony account and use that for the bedroom.
Thanks again.
gkf9 is offline
post #1259 of 1769 Old 08-17-2014, 06:51 AM
Thinker's Avatar
So I can't get the left right buttons for my Infocus IN8606HD to work. I tried teaching it by shooting at the bottom of the remote and that wont work. The left right codes are not much different than the up/downs (which do work). Any way to manually code the remote for the command (see the code disclosure below)?
http://www.infocus.com/resources/doc...IR%20Table.pdf
Thinker is offline
post #1260 of 1769 Old 08-17-2014, 07:42 AM
mdavej's Avatar
Liked: 958
I'll post the pronto hex soon which you can email to Logitech to add to your account. I added a bunch of Infocus codes to another remote not long ago.
mdavej is offline
Reply Remote Control Area
