Official Logitech Harmony 650/600 remote thread - Page 45 - AVS Forum
 2Likes
post #1321 of 1336 Old 11-24-2014, 11:55 AM
jcalabria's Avatar
Quoted: 40 Post(s)
Liked: 50
Originally Posted by kkpro View Post
Is there a way to make the volume buttons default to control just 1 device? The reason is if I switch to my Oppo to make a change, then the volume control will not run my Denon receiver. I have the "Watch a movie" macro set up and it asks you what you want the volume buttons to control. So, if I don't have to go into the Oppo to control more than just the basics (play, ff, etc) I am okay. But, if I make a change, then I have to hit "watch a movie" again to have the volume button default to the receiver.
Just teach the Denon volume controls to the Oppo device. This will give what seem to be asking for.
Alternatively (and normally my preference), you could add the extra Oppo setup commands that you need to the Watch movie activity. That way, you won't have to go into device mode at all.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.2.0_11
jcalabria is offline
post #1322 of 1336 Old 11-24-2014, 03:39 PM
kkpro's Avatar
Quoted: 12 Post(s)
Thanks ,will try.
kkpro is offline
post #1323 of 1336 Old 11-27-2014, 05:40 AM
ClaptonsGhost's Avatar
Simple question. My old 650 (which I wore out) would default to my favorite channels on the LCD screen when I chose to watch tv. My new, "Advanced" 650, however, defaults to the "Devices" screen, which I'm not used to, so when I go to press the button for MLB Network, a huge menu for my tv pops up on screen and there's no way to exit it, I have to wait until it goes away itself. Is there a way to make the new remote default to the LCD screen where my favorited channels show up?
ClaptonsGhost is offline
post #1324 of 1336 Old 12-09-2014, 05:09 PM
Charles Tintera's Avatar
Quoted: 40 Post(s)
Just got a 650 to use with our (new) Vizio 55m TV. Biggest disappointment to me is the amount of time it takes the TV to respond to the Harmony commands. Maybe 2-3 seconds where the cable network (Brighthouse) supplied controller, Clicker5, is right now.
Charles Tintera is online now
post #1325 of 1336 Old 12-09-2014, 05:45 PM
mdavej's Avatar
Quoted: 629 Post(s)
Liked: 448
That's definitely not normal. I'd pick a different Vizio model from the database (all use the same codes). Failing that, turn down the interkey delay.
mdavej is offline
post #1326 of 1336 Old 12-09-2014, 06:59 PM
Quoted: 40 Post(s)
Thanks I'll give that a look.
post #1327 of 1336 Old 12-12-2014, 04:33 PM
pndiku's Avatar
My 650 resets every time it drops and with a 2 and 4 year old, this happens hourly. So, I press the activity I was on, with the remote behind my back.
However, I wanted to use an RF transmitter, but my wife will get frustrated if she has to first power off all devices everytime the remote resets.
Any ideas? Am I better off getting a remote higher in Logitech's series?
pndiku is offline
post #1328 of 1336 Old 12-12-2014, 08:50 PM
mdavej's Avatar
Quoted: 629 Post(s)
Liked: 448
No Harmony fares well with Toddlers. RCA RCRP05B is about as capable and will work if run over by a truck. Just takes a little more effort to program.
mdavej is offline
post #1329 of 1336 Old 12-13-2014, 11:47 AM
Liked: 0
Using a Harmony 650 with a Naim Nait 5i. It worked wonderfully over the past year, but recently switched my TV and updated the remote. Now the remote works with the AMP for about 30 minutes then loses the ability to control the amp, until I power off/on the amp manually. Anyone else experience anything like this, any solutions?
mountain_hi_fi is offline
post #1330 of 1336 Old 12-15-2014, 04:54 AM
kkpro's Avatar
Quoted: 12 Post(s)
Purchased a refurbished 650. Are the buttons (Watch a Movie, Watch TV) above the LCD screen backlit? Mine are not. Also, I can have the macro Watch a Movie, but not Watch TV. Are you able to just have 1?
kkpro is offline
post #1331 of 1336 Old 12-15-2014, 06:24 AM
mdavej's Avatar
Quoted: 629 Post(s)
Liked: 448
Not backlit, unlimited activities.
mdavej is offline
post #1332 of 1336 Old 12-15-2014, 01:00 PM
kkpro's Avatar
Quoted: 12 Post(s)
kkpro is offline
post #1333 of 1336 Old 12-17-2014, 04:22 PM
Quoted: 40 Post(s)
It appears I didn't do something. Missed a step? Overlooked something? My 650 will control the Cablebox/TV/Soundbar after they are on. And it will turn them off it just won't turn them on!
What to do? Wipe and reset (can I do that?) everthing?
post #1334 of 1336 Old Yesterday, 08:35 AM
ahmadka's Avatar
Guys, I recently got my Harmony 650, and I had a questions below:
I'm planning to setup a HTPC soon on which I'll primarily use TMT6 for Blu-ray playback, and MPC (Media Player Classic) for all other files (MKV, AVI, etc.)..
Is there any way to map the same Harmony button to different key combos under different applications ?
For example, in TMT, the key for forwarding is 'F', but in MPC, the key for the same function is the Right Arrow '>'.
How would I accomplish this ?
I have not bought an IR receiver yet, so open to suggestions on which to buy which will allow me to do the above.
ahmadka is offline
post #1335 of 1336 Old Yesterday, 10:43 AM
mdavej's Avatar
Quoted: 629 Post(s)
Liked: 448
Different activities, different mappings.
mdavej is offline
post #1336 of 1336 Old Today, 06:51 PM
bourmb's Avatar
I have a Mitsubishi HC-8000 projector. Is there a way to add a double Power OFF command in the Harmony 650? My Mits projector requires two pushes on the Power OFF button to shut it off. Secondly, is there a way to reorder the Activities on the screen? I have searched on the internet and it appears the latest software does not allow this feature. Help?
bourmb is online now
Reply Remote Control Area
