Official Logitech Harmony 650/600 remote thread - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1771 of 1791 Old 07-04-2017, 05:50 AM
Maddog56's Avatar
Quoted: 12 Post(s)
Liked: 40
I have the Harmony 650 Remote ... I have it set to 4 activities which all turn on when button pushed. I am using a JVC RS520 Projector to view all activities. The problem is shutting down the projector. All other components shut down but the projector does not. The projector turns on with all activities. I have tried adding delay etc.. I have added the "Stand By" button too... when i add anything to the remote for projector the projector then will not turn on. Any suggestions or solutions... Thank you Mike
Maddog56 is offline
post #1772 of 1791 Old 07-04-2017, 07:23 AM
GaryPSU's Avatar
Does the projector refuse to shut down when changing activities, or when shutting all off, or both? If it's just when changing activities, try changing the order so that the projector shuts down first. Also, some devices have both power toggle and power off/on options for some reason. If that's the case, try changing options. Good luck.
GaryPSU is offline
post #1773 of 1791 Old 07-04-2017, 10:08 AM
Maddog56's Avatar
Quoted: 12 Post(s)
Liked: 40
The projector once "On" stays On when switching activities... all is good except when I wish to shut down all components... except the JVC projector.
My JVC remote has an "On" and a "Stand By" no OFF.
Mike
Maddog56 is offline
post #1774 of 1791 Old 07-04-2017, 10:42 AM
mdavej's Avatar
Quoted: 2278 Post(s)
Liked: 992
Projectors often require two commands or a longer than normal duration command to shut down. If you can't find these in the power options of your device, then you'll have to contact Logitech support and ask them to do it for you.
mdavej is online now
post #1775 of 1791 Old 07-04-2017, 06:23 PM
Maddog56's Avatar
Quoted: 12 Post(s)
Liked: 40
Yes I figured I would call Logitech... Thanks for your input.
Maddog56 is offline
post #1776 of 1791 Old 07-15-2017, 09:16 AM
Foolzatch's Avatar
Liked: 0
Need Help.
Have the Logitech 650, programmed to work with the Hopper 3 and it does when pointing directly at the Hopper 3. I'm trying to use an IR extender/blaster that runs through HDMI to the closet. Also have a Onkyo receiver that works through the IR extender, but I can't get the Hopper 3 to work through the IR extender/blaster. Is there something I'm doing wrong or would the IR extender/blaster be incompatible with the Hopper 3? I've tried several position for the extender right in front just right of the panel on the hopper and several feet away. Any thoughts? If you think its the IR extender/blaster any recommendation for one that works with the Hopper 3? The Hopper 3 is version 52, should that matter.
Foolzatch is offline
post #1777 of 1791 Old 08-08-2017, 02:45 PM
arcadius's Avatar
Need some newbie help, please. I purchased a 650 last week. So far, it is working great with my TV, receiver and Yamaha sound bar. I got my Flirc IR usb dongle today in the mail. I connected it to my htpc and ran the setup and installed the drivers. I upgraded the firmware when prompted. I added it as a device to my 650 ( Flirc/Kodi) and all seemed fine. I then mapped keys in the Flirc GUI and that process seemed to go smoothly as well. All keys reported they mapped fine as I was doing it. But still, if I launch Kodi, not a single key on the 650 is working.
Do I need to do anything else? Must the Flirc software be open for this to work? This is Kodi 17 (Krypton, btw) I have read several setup guides and I can't really see where I am going wrong.
Thank you!
arcadius is offline
post #1778 of 1791 Old 08-28-2017, 02:34 PM
avekevin's Avatar
Hello,
I am a longtime user of Harmony remotes, and I've had the 650 for several years now. Over the weekend, my son dropped it into a glass of water (don't ask). I opened it up and dried it out, and it now mostly works. Several of the buttons are now dead, though.
I see that the 650 is still for sale, but I also see there is now a 665 model. I haven't been able to find any sort of side-by-side comparison of the two.
It looks like the 665 supports 10 remotes, up from 8. It also appears to have an MSRP $10 less.
Thoughts?
Kevin
avekevin is offline
post #1779 of 1791 Old 08-28-2017, 03:10 PM
mdavej's Avatar
Liked: 992
Number of devices is the only difference. If the 665 is less, then get that one. But I buy "refurbs" whenever possible which are even less ($35 for a 650 on Amazon) and usually mint. However, a new 665 for $50 isn't bad if you need the additional devices. In spite of the higher MSRP, new 650 is selling for $44 at Best Buy and Amazon.
avekevin likes this.
post #1780 of 1791 Old 08-28-2017, 05:17 PM
avekevin's Avatar
Thanks for your quick response. It's ironic that my son is the one complaining the most about the dead buttons....
avekevin is offline
post #1781 of 1791 Old 09-01-2017, 09:20 AM
Liked: 0
harmony hub+harmony remote 650
can i use my remote 650 with my harmony hub
Fernando Tapia is offline
post #1782 of 1791 Old 09-01-2017, 09:58 AM
mdavej's Avatar
Liked: 992
You can use a 650 and a hub individually, but they will not connect with each other or interact in any way.
post #1783 of 1791 Old 09-16-2017, 10:29 PM
mzs22's Avatar
Quoted: 101 Post(s)
Liked: 40
I am having trouble getting my 650 remote to shut off my jvc 770 projector with the all off button after watching a movie. Have been in contact with logitech support and they tried adding additional power off commands with no luck. If I use the help button it will shut off then. Do all Harmony remotes have troubles shutting off JVC projectors?
mzs22 is offline
post #1784 of 1791 Old 09-17-2017, 08:40 AM
mdavej's Avatar
Liked: 992
If one can't do it, then none of them can. However this should be solvable with longer durations or multiple commands, especially since help works. Keep at it, try creating a new activity from scratch.
post #1785 of 1791 Old 09-17-2017, 06:27 PM
mzs22's Avatar
Quoted: 101 Post(s)
Liked: 40
Support had six power off commands with different durations. I did change it to shut off first instead of last but that did not help. I think Logitech support gave up on it, I have not heard back from them in a couple days
mzs22 is offline
post #1786 of 1791 Old 09-20-2017, 07:10 AM
richlife's Avatar
Quoted: 731 Post(s)
Liked: 856
That's correct. I use a 650 in my main HT room with a hub included that allows me to control service to another tv in a nearby bedroom with my smartphone. Both control the same setup, but are used with different end tvs.
Edit: And yes, if I try to use both, they may get conflicting results. For example, I could be watching the tv in the bedroom and if my wife used the 65 to turn off the Directv DVR or the Yamaha AVR, I would lose my picture in the bedroom. The 65 and the hub are just two different means to control the same equipment.
Atmos/DTS:X HT in Vaulted Room -- LG OLED Settings Options
Yamaha RX-A3060: 7.2.4 or 7.2.2 + Zone2 (switchable); OPPO 203; LG OLED65B6P; Harmony 650 & Home Hub
Base: Mirage OM-6 (FLR), MC-si (C), OM-R2 (SLR), FRx-nine (BLR)
Presence: ELAC A4s (FP), RSL C34Es (RP); 2 aci Titan subs; RP amp: AudioSource AMP100VS
richlife is offline
post #1787 of 1791 Old 09-21-2017, 04:54 PM
Frisco John's Avatar
Quoted: 34 Post(s)
Liked: 1
Bought the 650. It's getting delivered tomorrow. I've been reading as much as I can ahead of time. One question is there a way to turn on components in a certain order and put a few seconds between each? I have some hdmi CeC issues.
Frisco John is offline
post #1788 of 1791 Old 09-21-2017, 07:41 PM
primetimeguy's Avatar
Quoted: 623 Post(s)
Liked: 376
Yes, to both questions
Sent from my Pixel using Tapatalk
primetimeguy is offline
post #1789 of 1791 Old 09-22-2017, 08:26 AM
Quoted: 34 Post(s)
Liked: 1
Can you help me with the steps on how to put time between each component? Is it called out in the manual somewhere?
post #1790 of 1791 Old 09-22-2017, 02:29 PM
Quoted: 34 Post(s)
Liked: 1
I figured it out
post #1791 of 1791 Old 10-11-2017, 03:59 AM
Liked: 0
I posted this in its own thread but figured I may get a response here. My harmony is causing weird issues with my TV.
I am using a 700 with a Hisense 55H8C, Cisco DVR, and Vizio soundbar. Currently the watch tv activity works fine, optical from dvr to sound bar, no sound issues. Now if I switch activities and go from watch tv to watch smart tv, any app I go to has audio out of sync. TV is hooked to sound bar via optical out from tv similar to DVR. I can fix it by going into the settings and going from optical out DD to Off then back to DD. If I am in the watch tv activity, and use the Hisense remote or the device functions to go directly to smart TV functions, there are no sync issues, so it looks like somehow the remote activity switching is causing this in some obscure way, I have no idea.
Similarly, if I go from watch smart TV to watch TV, the sound output of the DVR goes from Dolby Digital to HDMI and I have to manually switch at back so that it uses the optical output directly to the sound bar rather than HDMI through the TV then to the bar.
I was on the phone with Logitech for 1 1/2 hours on Saturday trying different things, and nothing worked.
I can't for the life of me figure out what the problem might be. The best I did so far is create two sequences and mapped those to on screen functions that run through the button sequences to fix the problems using the DVR and/or TV menus.
Another unrelated issue is getting my SPDIF switch to turn off when the system powers down. It does not have discrete functions that I am aware of (options in the setup). The device always turns on perfectly, but does not want to shut down. If I use the help menu, it shuts down fine.
Any thoughts or input would be great!
06GMC5.3L is offline
Reply Remote Control Area
