Onkyo control of DVD & 5.1 audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-12-2010, 04:51 PM - Thread Starter
HDcoyote's Avatar
I've been putting up with this issue for quite some time now.
I replaced a Sony receiver with an Onkyo TX-SR606. I can control my DVD player in a normal manner using the remote with the DVD mode selected. However, I'm puzzled as to why I must then switch to the MULTI CH mode in order to hear 5.1 audio from the DVD. If I need to pause the movie I need to switch back to the DVD mode. Using my old Sony receiver, 5.1 audio input was linked to the DVD operations.
HDcoyote is offline
post #2 of 10 Old 07-12-2010, 05:12 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
How are the player and AVR connected?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 10 Old 07-12-2010, 09:06 PM - Thread Starter
HDcoyote's Avatar
The video connection is S-video, audio is 5-monster cables.
HDcoyote is offline
post #4 of 10 Old 07-12-2010, 09:20 PM
Quoted: 673 Post(s)
Liked: 460
Well, the audio is in MULTI CH mode, so there's no mystery unless you have chosen MULTI CH as the default audio source for DVD.
Kal Rubinson
post #5 of 10 Old 07-12-2010, 09:35 PM - Thread Starter
HDcoyote's Avatar
Yes I'm not an audiofile, I don't follow. The setup is nearly the same as with the Sony I used before. What connection method should I be using? Should I toss out a perfectly good DVD unit and get one wiht HDMI connection?
HDcoyote is offline
post #6 of 10 Old 07-13-2010, 12:11 AM
cristush's Avatar
According to the User Manual of your Onkyo, you can control your DVD, CD, etc players with your Onkyo remote control. I suppose you've programmed your remote control to work with your DVD unit using (DVD) button.
I think you can program your (MULTI CH) button to work with your DVD unit also, so you can control play/pause etc. within MULTI CH mode, without needing to switch modes between DVD and MULTI CH.
That way, you can ALWAYS use (MULTI CH) mode for watching DVDs
cristush is offline
post #7 of 10 Old 07-13-2010, 08:31 AM
Quoted: 673 Post(s)
Liked: 460
I do not know the Sony or your specific Onkyo but the Onkyo/Integras that I do know allow the user to set (in the menus) the MULTI CH as the default input for a particular choice which, in your case, would be DVD.
Kal Rubinson
post #8 of 10 Old 07-13-2010, 09:14 AM - Thread Starter
HDcoyote's Avatar
It all sounds like good advise. I'll give it a go. Enabling MULTI CH with the DVD button seems to be the most logical and user-friendly approach.
HDcoyote is offline
post #9 of 10 Old 07-13-2010, 10:41 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Your current DVD player probably has an optical and/or digital coaxial output in addition to the 5.1 multi-channel outputs. Using a digital output to your Onkyo TX-SR606 (I have the same receiver BTW and love it) will also get you DD 5.1 via the receiver's DD decoder. With your current connection the DVD player is doing the decoding.
Vin
Vin is offline
post #10 of 10 Old 07-13-2010, 11:19 AM
Quoted: 673 Post(s)
Liked: 460
Good point.
Kal Rubinson
Reply Remote Control Area
