Newbie looking for some advice on IR Extenders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-19-2010, 01:27 AM - Thread Starter
gmoniey's Avatar
I'm hoping to add some IR extenders to fix some issues in my home, but I'm pretty lost on what I need, so I was hoping some of the gurus on here could help me out.
As for my setup, I have a few boxes (HK AVR 3600, Sony Blue Ray & Scientific Atlanta HD Receiver) inside an entertainment center. Unfortunately, the way the entertainment center is positioned, you there is no line of sight from certain areas on the couch. To make matter worse, the boxes are on different ends of the entertainment center.
In addition, I have my AVR 3600 powering a second zone (outdoor patio), and would like to extend the signal to their as well.
I know the AVR 3600 has an IR input, but the HK built IR extender is $80, and doesn't handle sending signals to my other boxes.
I don't mind buying multiple IR Extender setups for different boxes/areas, but I would like to keep my budget somewhat reasonable.
Thanks in advance!
gmoniey is offline
post #2 of 9 Old 07-19-2010, 05:49 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
oman321 is offline
post #3 of 9 Old 07-19-2010, 08:02 AM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
How exactly would this work from 2 separate locations?
mdavej is offline
post #4 of 9 Old 07-19-2010, 08:43 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
My mistake I missed the part about the 2nd zone control. The above should have enough slack for either side of the entertainment center, however it will limit the necessary control for the other zone.
2 options add a wireless IR extender ie. the X10 Powermids available on Ebay. I have a pair which I use for my deck/patio zone 2. I simply bring the receiver outdoors and plug it to an outdoor outlet. The transmitter I position in front of my receiver and voila! Outdoor IR control.
If you want a more permanent solution and don't mind running some cat5 to both locations then you can look into a more permanent solution such as an IR extender kit which will allow you to daisy chain 2 IR receivers and have the connecting block and emitters at the equipment.
Xantech Kit,
http://cgi.ebay.com/XANTECH-48095BKI...item415145ddd0
Extra IR receiver.
http://cgi.ebay.com/Xantech-49095-PL...item4aa2f90465
If that's not enough emitters for all equipment, you can buy dual head emitters as well.
oman321 is offline
post #5 of 9 Old 07-19-2010, 09:00 AM
hardax's Avatar
I LOVE my Hot Link Pro. If you can run some Cat 5 cable they have a kit for long runs and a splitter so you can control 2 zones. Check out their website:
http://www.hot-link.com
hardax is offline
post #6 of 9 Old 07-19-2010, 11:41 PM - Thread Starter
gmoniey's Avatar
Thanks for all the responses. The Hot Link looks nice, but from what I understand, it doesn't support the second receiver, so i guess I can go with the Xantech set.
I don't mind running cable, as I can do it through the attic or the sub floor.
Also, is there a noticeable lag with the IR extenders? I remember being at a friends house in 2004, and he just got a Tivo, and it would relay the IR signal to the cable box, but the lag was so frustrating he ended up returning the tivo.
gmoniey is offline
post #7 of 9 Old 07-20-2010, 01:11 PM
hardax's Avatar
No lag at all with the Hot Link. As a matter of fact my button presses seem faster. I am pretty sure they have a kit to do exactly what you want. Isn't this it?:
http://www.hot-link.com/pages/access...tid=2&mrchid=3
hardax is offline
post #8 of 9 Old 07-20-2010, 05:36 PM - Thread Starter
gmoniey's Avatar
I believe your right.
gmoniey is offline
post #9 of 9 Old 07-24-2010, 04:05 AM
syner's Avatar
you could use the IR unit we support in our iphone/itouch/ipad and soon android IR apps
http://totalcontrolapp.com/index.php...=108&Itemid=92
you would have to run IR to the 2nd zone. you can cheaply do this by splitting an IR and extending it with cat5 cable. our customers do this for using 1 unit around a home for IR.
Robert Conlin
syner is offline
Reply Remote Control Area
