URC MX-980 Not sending RF signals anymore?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-30-2010, 07:32 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
My MX-980 was working fine. Then two minutes later when I went to pause the movie, it just wasn't working?
I've done some troubleshooting. It will send IR signals fine. I can control anything I want via IR.
But RF is not working, despite the indicator on the MX-980 saying it's sending a signal. The MRF-300 and RFX-150 don't sense any RF at all. Their respective RF status LED's don't light up at all. If I move the MX-980 right on top of the RFX-150, then its indicator just barely flickers (as expected due to typical interference), but not in sync with my button presses.
Power LED's are lit on both devices.
IR output is set to "all" so it includes the front blaster. Signal is set to "IR & RF" for troubleshooting.
Any ideas?
"The boom is dead, long live the bass"
CZ Eddie is offline
post #2 of 9 Old 12-01-2010, 05:43 AM
bryansj's Avatar
Quoted: 1338 Post(s)
Liked: 625
I'd assume it is the RFX-150 that is bad. Sort of hard to troubleshoot if you don't have any replacements to test.
bryansj is online now
post #3 of 9 Old 12-01-2010, 04:43 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Doesn't the MRF-300 also light up when it senses RF? I unplugged the 150 and the 300 still didn't register any RF acknowledgement.
CZ Eddie is offline
post #4 of 9 Old 12-01-2010, 07:22 PM
bryansj's Avatar
Liked: 625
The MRF-300 gets the signal through the RFX-150. The 150 is the antenna. Without the 150 the 300 will not work. The MRF-260 has the antenna built in, the 300 does not.
post #5 of 9 Old 12-01-2010, 07:24 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
I didn't know that.. thanks, Bryansj!
I'll order another 150 tomorrow. I agree it's the most likely suspect, now that I know the 300 doesn't get RF signals independently.
CZ Eddie is offline
post #6 of 9 Old 12-02-2010, 07:22 AM
hoggy's Avatar
get an rfx-250, it is a direct replacement and will suffer less interference than the 150
hoggy is offline
post #7 of 9 Old 12-10-2010, 06:20 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Bummer, the replacement RFX-150 didn't do the trick. No change at all in the behavior.
I'll call URC on Monday to inquire about cost of repair.
CZ Eddie is offline
post #8 of 9 Old 12-14-2010, 08:25 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Well I called tech support at URC and as usual, someone stateside picked up quickly. I talked to Miguel and he impressed me, but the price of repair was a bit steep.
I ended up disassembling the MX-980 and re-soldering a few flaky looking joints. Put it back together and so far... RF is working properly!
Hope it stays this way!!!
CZ Eddie is offline
post #9 of 9 Old 07-28-2014, 10:18 AM
BADZ1969's Avatar
I have the same problem. My remote is not working as I was told that the internal antenna must have been jarred from shock of being dropped from my installer (he tested it). I will try and open it up and do some repairs myself. You might as well buy a new one for the cost of what URC wants for repairs. ;(
BADZ1969 is offline
Reply Remote Control Area
