IR control for RF devices? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 12-22-2010, 07:52 AM - Thread Starter
Swancoat's Avatar
Quoted: 47 Post(s)
I recently bought one of those motorized tv stands to keep my living room a little more de-cluttered. It was a good deal, so I didn't really pay attention to the control protocol, but now that it's here I realize the lifting mechanism is controled by a junky little RF remote.
Does anyone sell any kind of 'universal remote' for RF devices that I can control with IR? I really want to control this cabinet with my Harmony One, and put the little RF remote in a drawer. (Every kind of search I do with 'IR' 'RF' and 'Control' comes up with the many RF extenders for IR control like a Harmony 890, etc...).
Swancoat is offline
post #2 of 36 Old 12-22-2010, 07:57 AM
ccotenj's Avatar
Liked: 101
nope...
sure would be nice if there was though...
- chris
ccotenj is offline
post #3 of 36 Old 04-30-2011, 12:23 PM - Thread Starter
Swancoat's Avatar
Quoted: 47 Post(s)
Ok, I REALLY wanted to not have that extra RF remote sitting around just to run the TV lift and was determined to make this work.
This is my story.
Step 1: Buy extra TV Lift remote from the company that sells it. It was remarkably cheap. $15, and they even paid for the shipping.
Step 2: Buy electronics kit that can use IR to close a relay. (Velleman MK161) I originally thought this kit could use any IR code, but it can't. You need to also buy the 2-button remote control (Velleman MK162). These kits are just parts and need to be soldered together, but it's through-hole soldering and not too tough.
Step 3: Assemble this stuff, and then take apart the remote and wire the relays to the button contacts on the remote. Basically, when the relay closes, I'm effectively 'pushing' the button on the remote (make sure MK161 is set to close relays only momentarily rather than toggle them off and on).
Unbelieveably, this thing actually worked. All I had to do now was make it nice. I bought a project box, and some little nylon stand offs from Fry's, then ordered the required power supply from DigiKey (and instead of just using the bare wires, I decided to also get a couple of jacks so I could just plug it in). I also picked up some IR window plastic so I could make the box look nice.
Step 4: Set to putting all of this stuff together. (Note, I was able to ditch the battery for the remote, since it was the same voltage as the power supply and required by the MK161. I just wired them up in parallel.
Step 5: Drill a hole in the box for the power supply jack and cut another hole in the front for the IR window (Dremel is handy here). Then you just use the standoffs to stack the boards a bit (I'm a bit of a hack, so I just glued them down).
Step 6: Add the MK162 remote to my Harmony. I made a new device, called it an 'Appliance' and set the two buttons as discrete on and off signals. Then just tell the Harmony software that you want the 'Appliance' on in every activity, and when you start up it will send the 'on' (up) signal, and lift the TV.
All Assembled, it's just a black box with a power supply jack in the back. Plug it in and basically make sure it has IR line of sight to your remote. Done.
Believe it or not, this thing basically works like a charm. Been running it for about a month now with no problems.
Just wanted to share in case other people have similar problems.
Swancoat is offline
post #4 of 36 Old 04-30-2011, 12:26 PM - Thread Starter
Swancoat's Avatar
Quoted: 47 Post(s)
Swancoat is offline
post #5 of 36 Old 05-01-2011, 09:23 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
'Swantcoat', in script lettering, white color on black label, taped to the corner of that, would make it perfect.
Nice job!
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 36 Old 05-02-2011, 05:32 PM
jrwhite's Avatar
Good job Swancoat. You are officially a hacker.
Jonathan
jrwhite is offline
post #7 of 36 Old 09-17-2011, 03:20 PM
cmm004's Avatar
Many thanks to Swancoat for this solution. I ran into a similar problem with the Mustang screen from Amazon - which was supposed to be IR, but turned out to be RF controlled.
For anyone who is going to try this for a Harmony remote without buying the Velleman remote to learn from I found by trial and error that the Velleman K8049 light controller is in the Logitech database and is compatible with the MK 161. It was just a matter then of going through the 15 commands downloaded to the Harmony to find out which ones worked. The "Power Toggle" and "Light 2" commands did the trick. Then it was just a matter of customizing those two on the Harmony for "Screen Up" and "Screen Down".
As Swancoat said, it works like a dream.
Mike
cmm004 is offline
post #8 of 36 Old 12-29-2011, 04:04 AM
itayr's Avatar
great thread, i have looking for it a long time...
one question - can this work with more modules? to control light electric windows,etc.
this way its possible to automate the living room area with the harmony one control to shutdown the light and windows.
itayr is offline
post #9 of 36 Old 12-29-2011, 04:05 AM
itayr's Avatar
will a module with more relays do the trick?
itayr is offline
post #10 of 36 Old 12-29-2011, 04:06 AM
itayr's Avatar
is this module the same as MK-161 module but with more relays?
itayr is offline
post #11 of 36 Old 12-29-2011, 04:07 AM
itayr's Avatar
itayr is offline
post #12 of 36 Old 04-18-2012, 12:55 PM
ernie1500's Avatar
Wow this worked like a charm!!!
I can now use my Harmony with my projector screen
keep up the good work!!
ernie1500 is offline
post #13 of 36 Old 04-18-2012, 01:56 PM
DGF
DGF's Avatar
Liked: 39
FWIW, I have a slightly larger Velleman module that I use to control my screen masking system. I pulled the IR codes into my Roomie configuration and can now control the individual masks from my iTouch (as well as all the other HT components) - all very cool!
DGF is offline
post #14 of 36 Old 05-17-2012, 07:51 PM
meyerovb's Avatar
Anyone willing to make me one of these for a fee? This is my remote
meyerovb is offline
post #15 of 36 Old 06-17-2012, 04:55 AM
meyerovb's Avatar
Finally found it... vm122 is pre-built... no more solder fumes!!!
meyerovb is offline
post #16 of 36 Old 06-18-2012, 05:47 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
FYI, the fumes are from the flux. The solder doesn't get hot enough to vaporize.
bryansj is online now
post #17 of 36 Old 06-19-2012, 08:55 AM
Wayne7431's Avatar
Man,,,I'm amazed you guys got this to work like this!...This is deep!! I need to do this.
I have the Mustang Screen as well with an Harmony 1100.
GHEEZ - Whew!!!
Wayne7431 is offline
post #18 of 36 Old 06-19-2012, 10:00 AM
SAM64's Avatar
Liked: 78
This is deep!!
lol
SAM64 is offline
post #19 of 36 Old 06-22-2012, 08:03 AM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
No, it is NOT the same. It has 15 open collector contacts: max. 50V/50mA (that is to say 15 NPN transistors) which could be used to drive up to 15 external relays.
Wendell R. Breland is offline
post #20 of 36 Old 09-24-2012, 05:58 PM
robl45's Avatar
Quoted: 167 Post(s)
so basically this is the only way to do this? I have the same remote and while this is easily within my skill set, having two kids means all of my stuff has been packed away. has anyone found a simpler already assembled method?
robl45 is offline
post #21 of 36 Old 11-21-2012, 12:31 PM
dataz722's Avatar
Where is the best place to find this kit? All I have found is ebay and some places in the UK and I try to avoid ebay when I can.
I think it is exactly what I need to be able to control a fireplace.
dataz722 is offline
post #22 of 36 Old 04-15-2013, 08:08 AM - Thread Starter
Swancoat's Avatar
Quoted: 47 Post(s)
Update:
With a solution like this, reliability is always a concern. This thing basically worked without fail every time I used it, and actually the lift itself has now crapped out. I've torn apart the lift, and it is basically unrepairable, and looks to be kind of cheap-foreign manufactured stuff with no brand name to be found on it.
So... I've decided to replace the lift mechanism (and ordered the IR control out of the box this time around). I'm going to retire my little box now, but I'm so proud that it outlasted the lift itself!
Swancoat is offline
post #23 of 36 Old 04-25-2013, 10:09 PM
tkarns24's Avatar
Swancoat .
I could use your help and doing the same thing with my lift
1 Where do i get those parts
2 what parts do i need
3 how do i do all the soldering and setup.
tkarns24 is offline
post #24 of 36 Old 10-06-2013, 04:24 PM
hltr is offline
post #25 of 36 Old 06-20-2014, 06:41 AM
Liked: 0
IR to RF Signal Converter
All of this can be done with an Arduino board. It roughly cost me ~$20-25 for the parts.
All you need is:
1. Arduino board
http://www.ebay.com/itm/251459710321...84.m1497.l2649
2. RF receiver (to learn codes) transmitter (send learned codes). My remote used the 315MHz frequency (some may use 433MHz)
http://www.ebay.com/itm/1pcs-315Mhz-...-/261086921764
3. IR Receiver (to receive IR signals)
http://www.ebay.com/itm/400712068712...84.m1497.l2649
4. Breadboard and wires to put it together
5. Minimal coding experience in c, to program the Arduino. Most of the code is available online.
Start here:
http://www.righto.com/2009/08/multi-...e-library.html - for IR help
http://www.wes.id.au/2013/07/decodin...and-rc-switch/ - RF Help
http://forum.arduino.cc/index.php/topic,8526.0.html - Putting it together
If you want to go the relay route, as mentioned above with your included RF remote, buy this board off of ebay (it is way cheaper and comes already assembled with a remote).
http://www.ebay.com/itm/351079207703...84.m1497.l2649
Rule of thumb:
Always buy your components off of ebay unless you need them quickly (hence you can use prime).
Good luck to all and please let me know if you have any questions.
-Mario
ejerkel is offline
post #26 of 36 Old 06-24-2014, 12:47 PM
CoxyUK's Avatar
I really want to do this, but sadly I have no idea how or what to do appears too complicated
CoxyUK is offline
post #27 of 36 Old 06-24-2014, 12:51 PM
CoxyUK's Avatar
ejerkel
Would you consider building and selling one? I'd love to be able to use my Harmony remote to raise/lower my projector screen (and blinds if I get them fitted).
CoxyUK is offline
post #28 of 36 Old 06-24-2014, 01:37 PM
CoxyUK's Avatar
So I think I may have a go at the gutting a remote technique.
I believe all I need is:
1. screen remote
2. MK161 - found here http://www.quasarelectronics.co.uk/I...e-receiver-kit
3. Power supply - http://www.quasarelectronics.co.uk/I...e-power-supply
4. Power jack
But if at a later date I want to control blinds, this would not be an option as I'd already be using the MK161 IR signal? Any other alternatives?
CoxyUK is offline
post #29 of 36 Old 06-24-2014, 02:27 PM
DGF
DGF's Avatar
Liked: 39
1. screen remote
4. Power jack
You could consider buying one of the Velleman kits with more channels - Quasar does a 15-channel version - it's a little more complicated to build and more money, but will give you a lot more flexibility for future expansion....
DGF is offline
post #30 of 36 Old 06-24-2014, 02:52 PM
CoxyUK's Avatar
DGF I'm keeping it simple and have ordered the 161 and see how I get on lol. Though from what I've read you can change channels anyway so I could add another 161 on a different channel should I need to expand, is this correct?
CoxyUK is offline
Reply Remote Control Area
Logitech Harmony 890 Advanced Universal Remote Control , Velleman Mk161 2 Channel Ir Remote Receiver
