Optoma HD65 Hex Codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-26-2011, 09:28 PM - Thread Starter
szsori's Avatar
I'm configuring iRule and the integrated Optoma codes aren't working for my HD65. I've looked everywhere but I can't seem to find the hex codes for it. It'd be nice to have the whole set of commands, but I really only need the power code(s). Pretty sure there's no discrete on/off, so it should just be one code.
Any help would be greatly appreciated.
TheTVDB.com Founder
szsori is offline
post #2 of 6 Old 01-26-2011, 10:30 PM
BPlayer's Avatar
Two suggestions:
1. Do a wider search for any similar Optoma devices and see if you can find one that will work.
2. Buy a cheap JP1 type remote that you can easily enter in hex codes to try and see if they work. A lot a patience may be need to run through even the most common codes but all else fails what else can you do.
BPlayer is offline
post #3 of 6 Old 01-26-2011, 10:55 PM - Thread Starter
szsori's Avatar
Thanks for the suggestion. I did find a NCF file for a HD73, but I have no idea how to get the hex code from that binary file:
http://files.remotecentral.com/view/...projector.html
I do know from the Dune settings that the hex codes can be insanely long. For example, the following is mute on the Dune:
0000 006D 0022 0002 0155 00AA 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 05ED 0155 0055 0015 0E47
Would I be manually entering that into a JP1 type remote or is there shorthand for this?
TheTVDB.com Founder
szsori is offline
post #4 of 6 Old 01-26-2011, 11:40 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
This thread implies that the HD65 is in the same series as the HD70.
If that is true, we can use the upgrade for th eHD70 which is at hifi-remote.com. There are two ways.
You can buy or find one of the following JP1 remotes (made by Universal Electronics)
OneForAll URC-8820N/10820N
RCA RCRP05B ($20 at Best Buy or Walgreens)
Atlas remotes provided by several cable companies
Cox 7820B
For each of these you would use setup code TV 1403, and that will control Power, Arrow keys and Menu. The other functions can be added by entering in a 5 digit EFC. These can be used to teach a learning remote.
But if you can use Pronto Hex directly, try the following:
Power NEC2 Device Code: 79.80 (0x4F.0x50) Function: 2 (0x02)
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
If that works I can post the 22 other known Hex codes.
If it doesn't workm you could try the HD72 code:
Power NEC2 Device Code: 0.2 (0x00.0x02) Function: 0 (0x00)
0000 006D 0000 0022 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
3FingeredGlove is offline
post #5 of 6 Old 07-05-2011, 05:16 PM
Biceadam's Avatar
Cox 7820B
please post the 22 other known hex codes here or send me a pm with them please>>>>
thank you
adam
Biceadam is offline
post #6 of 6 Old 07-05-2011, 09:16 PM
Quoted: 22 Post(s)
Liked: 39
Power Device Code: 79.80 Function: 2
Mode: Change Device Code: 79.80 Function: 3
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Mode: 4:3 Device Code: 79.80 Function: 4
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Mode: 16:9 Device Code: 79.80 Function: 6
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Mode: LBX Device Code: 79.80 Function: 7
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Mode: Native Device Code: 79.80 Function: 9
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Picture: Brightness Device Code: 79.80 Function: 10
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689Picture: V Keystone Device Code: 79.80 Function: 11
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Picture: Contrast Device Code: 79.80 Function: 12
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Picture: Overscan Device Code: 79.80 Function: 13
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Picture: H Keystone Device Code: 79.80 Function: 14
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Menu Device Code: 79.80 Function: 17
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
up arrow Device Code: 79.80 Function: 19
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
down arrow Device Code: 79.80 Function: 20
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
right arrow Device Code: 79.80 Function: 21
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
left arrow Device Code: 79.80 Function: 22
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
select Device Code: 79.80 Function: 23
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: HDMI Device Code: 79.80 Function: 25
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: Source Lock Device Code: 79.80 Function: 26
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: VGA Device Code: 79.80 Function: 27
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: Component Device Code: 79.80 Function: 28
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: S-Video Device Code: 79.80 Function: 29
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Input: Composite Device Code: 79.80 Function: 30
0000 006D 0000 0022 0157 00AC 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689
Reply Remote Control Area
