RF remote and best setup to control IR devices from afar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-21-2011, 08:01 AM - Thread Starter
Nifield's Avatar
Hey guys, just wondering what the best RF remote is out there, and also if im having all my devices in a media closet across the house, whats the best way to control the IR devices with this RF remote...
thanks for any help
Nifield is offline
post #2 of 8 Old 02-21-2011, 08:33 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
thanks for any help
The best remote is the one that best fits your needs and requirements within your budget. No need to recommend a touchscreen remote if you want hard buttons and vice-versa. The bottom end for cost with RF remotes would be the AVL-300 or using a "Next Generation" Extender with your current remote. Then you have the Harmony 890, 900, and 1x00. Up another notch are URC RF solutions such as the MX-880, 980, 5000, and 6000 with a RF base station.
As for how to best control the IR devices across the house with an RF remote. I'd use RF
If you are saying that it is very far away across the house then a typical entry level Harmony RF remote might not cut it due to the range. With something like a URC MRF-350 you can put the RF antenna away from the RF base to increase your range. You can also add additional RF antennas as needed. These antennas however have to be wired to the RF base using a standard cable or something like CAT5.
bryansj is offline
post #3 of 8 Old 02-21-2011, 09:40 PM - Thread Starter
Nifield's Avatar
yeah but if a device only has IR, what would you use in conjunction with the RF remote to control it? or am i missing something...?
Nifield is offline
post #4 of 8 Old 02-22-2011, 06:15 AM
bryansj's Avatar
Liked: 560
Yes you are missing something. RF universal remotes only communicate with their RF to IR base/extender. RF universal remotes will not control RF devices other than their extender. You can't control your RF ceiling fan since RF universal remotes can't learn and don't have an RF device database.
For a RF universal remote to work your devices must be IR (or possibly RS232). There are very few exceptions to this, such as one remote that can control a DirecTV DVR in RF mode and another that has the PS3 Bluetooth commands built in.
An RF universal remote has two parts. The remote which transmits IR like a regular remote or RF and the extender which receives RF and transmits IR. You put the extender with your components and it flashes IR using stick-on emitters or flashers that need line-of-sight to your devices (the Harmony 900 is an example of this).
bryansj is offline
post #5 of 8 Old 02-22-2011, 09:54 PM - Thread Starter
Nifield's Avatar
oh ok, i didnt know they worked like that, thanks for the heads up. Now i have one other question, will i be able to program an rf remote like a harmony to do multiple steps off one key, if some devices such as the projector is in the same room that the remote is being used, and the rest of the devices are in a media closet hidden away across the house with the extender? like so for instance, i want to hit one button and have my projector turn on, and then my cable box and my receiver turn on that are hidden away in the media closet?
Nifield is offline
post #6 of 8 Old 02-23-2011, 05:51 AM
bryansj's Avatar
Liked: 560
Yes, you can send a combination of IR and RF from the remote. In the setup you assign each device to be controlled by either IR from the remote or IR from the extender (which is RF from the remote).
What you are talking about is what Harmony refers to as an Activity such as Watch TV.
bryansj is offline
post #7 of 8 Old 02-23-2011, 07:31 PM - Thread Starter
Nifield's Avatar
ok sweet. also, would i have any issues because id be using it from within my media room which is completely encased in concrete? would i need some sort of rf repeater or something?
Nifield is offline
post #8 of 8 Old 03-15-2011, 05:44 PM - Thread Starter
Nifield's Avatar
bump
Nifield is offline
Reply Remote Control Area
